Old 02-03-2013, 12:08 PM   #1
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Cutting down the dinette width??
The width of the dinette on a 28 foot FC is wider than the comparable layout of an International model by about 4". I want to trim mine down by the 4" making it the same width as the bathroom wall like the International layout. This results in more floor space in the kitchen.
This means cutting/modifying the benches which are upholstered and also trimming the table. The table is a piece of cake but the bench work is likely a bit more complicated because of the upholstery.
I know some folks have done this and maintained the full height covered storage under the seats versus going to the aluminum frame dinette of the Internationals.
Would appreciate any insights and experience with doing this.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 02-03-2013, 12:27 PM   #2
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
I'm not sure what yours looks like but keep in mind that 4" of flooring that has been covered will now be exposed. If there are holes, no flooring etc this will have to be addressed. I want to do the same to our international, just need to get my wife's ok first
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 02-03-2013, 08:24 PM   #3
Alphonse's Avatar
Lower Alabama , USA
Flooring is there under the benches and the trailer has had little use so there should be too big of a problem uncovering another four inches of it. As you point out, there may be a screw hole or two. I am thinking I could rob some flooring from under the rear most bench to patch any holes as needed.
Alan
Air #64439
TAC AL-8
2018 Canopenian
Swapping the dinette for a sofa bed CMSmith Interior Restoration Forum 7 02-27-2012 05:34 AM
Why no rear dinette on the shorter trailers? snakyjake Boondocking 22 02-15-2012 05:50 PM
Replacing Dinette Seats? garythawk General Interior Topics 11 10-09-2011 01:54 PM
Mismatch of floor and outrigger width MtnMDStan Repairing/Replacing Floor &/or Frame 3 06-19-2011 02:44 PM
uh, oops. original Tradewind dinette design? SpaceEgg 1959-69 Tradewind 4 01-21-2011 08:54 AM
