On the Airstream support site, go the the 2011 Flying Cloud parts catalog into the plumbing section on page Section IV-37 and get the toilet part number (that will typically be for a pallet of 12 toilets).
http://www.airstream.com/files/libra...98f5ce7ddc.pdf
Part # 690495-03 is an Aqua Magic V, High Profile used in 28' 27FB, 25FB and 30'
Put the part number or brand name into a search engine and find who made (makes) the toilet and go to their site and look at the measurements.
Aqua Magic V Foot Pedal Flush
Since I do not know the trailer in question, the link above should get the OP into the correct brand to do research.
I was curious about our soon to be built Classic's "facility" and did the procedure above. The enclosed image is the information I found for the Dometic 18" tall toilet used in a Classic and also used in our 2013 25FB International Serenity. Check out the measurements. Camping World had a special on this model Black Friday.
Hope this helps.
