Old 05-07-2014, 08:00 AM   #1
2016 30' Classic
2009 25' FB Flying Cloud
Dade City , Florida
Brake Light Replacement
I need to replace the brake light on our 2009 Flying Cloud. I have removed the 4 screws but fixture still seems attached and reluctant to force. Should be a simple operation but could use some help. Thank you, Dave
dbaur is offline   Reply With Quote
Old 05-15-2016, 06:24 PM   #2
Same issue did you find a solution?
Please let me know if you solved this one. I have the same issue 25 ft Flying cloud. Thanks
ras.robshort is offline   Reply With Quote
Old 05-15-2016, 07:50 PM   #3
Burnside Bob's Avatar
1973 31' Sovereign
Mt Angel , Oregon
I have a 2009 FC 25FB. You should be able to remove the brake lamp without removing the large metal housing from the trailer.
Each lamp has a plastic decorative bezel covering it. These are held in place by four integral tabs located at each end and at center of top and bottom. With a flat bladed screwdriver you should be able to pry these off gently. A warm day may help prevent breakage of the tabs. But if you do break the tabs, you can get replacements.
Once you have the bezel off, you will see that each lamp is secured by four screws. Remove the screws and gently pry the lamp out of its seat. The wiring uses bullet connectors--just pull to unplug the lamp.
Here's a photo of two of the lamps. I've cleaned the lower lamp in the photo:
Sorry, I didn't take a photo of the bezels, but here's a photo of the housing with bezels and lamps removed:
I wanted to re-clear coat my tail light housings, but decided I was too likely to scratch the trailer's skin in removing all the aged caulk holding the housings on the trailer body. So I decided to strip and clear coat in place. The last photo shows the completed mask job prior to stripping the old clear coat.
Hope this helps.
Best, Burnside
"To err is human, to air is devine."
Burnside Bob is offline   Reply With Quote
Old 07-07-2017, 11:33 AM   #4
2007 25' International CCD
Lexington , Kentucky
Brake light replacement
Where did you buy replacement bulbs?
I have 2007 25' international that needs new ones.
Thanks, Jack
jtchinoe is offline   Reply With Quote
Old 07-07-2017, 11:47 AM   #5
dznf0g's Avatar
Oswego , Illinois
Check with Dan at led4rv.com. he has developed replacement assemblies for a number of models. My OE ones failed quickly and his have lasted 6 years so far.
-Rich-
Old 07-08-2017, 11:46 AM   #6
Rich, thanks for reply.
The Trailer Shop, Leola, PA 717-556-8452 seems to be good source also. No website but you can find them on ebay.
You know anyone who has replaced towing wire harness? I can't find where the wire connects in the trailer.
Jack
Old 07-10-2017, 06:14 AM   #7
2016 30' Classic
Dade City , Florida
Replacement Lamp
Great information. Thank you.
Dave
E53 w/ Tekonsha brake controller lights 3rd brake light when manual lever applied warmrain Brakes & Brake Controllers 10 11-14-2013 09:35 AM
'71 safari tail light/brake light issue TGK Lights - Interior & Exterior 8 08-20-2011 05:45 PM
2005 Safari tail light (brake) replacement.... photo-travel Lights - Interior & Exterior 1 12-25-2009 11:03 AM
Brake light assembly replacement Stinky Lights - Interior & Exterior 0 10-27-2003 04:59 PM
