Old 09-22-2013, 03:02 PM   #1
2005 30' Safari
Bothell , Washington
Blue Light Shore Power Lid
2013 Flying Cloud 23d
Had a problem with no power to the outlets coming from the inverter. Found a lose wire (white) coming out of the inverter. Fixed that and we now have powered (inverter plugs).
Wrapping things up and noticed the cool blue light on the shore power lid was not glowing. Figured I blew the breaker in the garage but nope. All of the power is working fine in the trailer. Checked the microwave just to be sure.
Any thoughts about the not glowing blue lid?
Chuck
charlesk is offline   Reply With Quote
Old 09-23-2013, 07:50 AM   #2
Snaken49's Avatar
2010 28' Flying Cloud
Fort Worth , Texas
i suspect that the led light in the cover may be out. But recommend that you also make sure the polarity is correct on the shore power supply and outlets inside your trailer.
This link provides detailed instructions.
RV Services Online - Troubleshooting - Power Converters
I've found problems with improperly wired shore power supply cords and bad wiring inside trailers. Hope this helps!
Old Cobra AH-1G Pilot
WoundedWarriorsFamilySupport.Org
http://www.highfivetour.com/
Snaken49 is offline   Reply With Quote
Old 09-23-2013, 08:38 AM   #3
Snaken49's Avatar
Fort Worth , Texas
Exclamation
I just checked the Furion web site and the lack of a blue light can also indicate a power outage or fault. Since you have power inside your trailer mot likely you have a polarity issue.
The tester in the previous reply is the easy way to determine if the polarity is correct.
F30INS-PS - Power inlets - RV Camp Power - Electrical
The link above is to the Furion site.
Old 09-23-2013, 09:28 AM   #4
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
I've had issues with the light on our 2011 as well. Sometimes when I'm plugged in at home, which I know is wired correctly the blue light doesn't come on. So in my case it seems to be a faulty or finicky light............
Landrum is offline   Reply With Quote
Old 09-23-2013, 09:44 AM   #5
2005 30' Safari
Thanks everyone. I'll check the polarity and go from there.
Chuck
Old 10-12-2013, 07:55 PM   #6
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
Originally Posted by charlesk View Post
Thanks everyone. I'll check the polarity and go from there. Chuck
Mine went out after the dealer installed our solar panel on our 2012 20 flying cloud. The fridge fan light is also out
subfan1 is online now   Reply With Quote
Old 10-18-2013, 08:22 PM   #7
Caledonia , Michigan
we had ours replaced on our new 2014 FC 30, and dealer mentioned there were other units that had same problem. Told us just a bad batch-now works fine, and as expected replaced under warranty.
Shipboy is offline   Reply With Quote
