Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Flying Cloud > 2009-2015 Flying Cloud
Old 03-27-2012, 09:33 PM   #61
dznf0g's Avatar
Oswego , Illinois
Originally Posted by Hibby View Post
No boogers in the Airstream!
Don't look under my couch!!!!!
-Rich-
Old 03-30-2012, 12:46 AM   #62
cptfish's Avatar
2014 27' FB International
salem , Oregon
We received our Arvika rack for our 25'FB 2010 in a week. Took about 2 hrs to install. Love it! Have traveled from Oregon to CA to AZ in snow And rain and bikes are secure and clean on arrival!
cptfish is offline   Reply With Quote
Old 03-30-2012, 07:46 AM   #63
Ed rottinger's Avatar
2005 16' Safari
2006 25' Safari SS SE
1996 30' Excella
Iron River , Michigan
Check out this link. http://www.airforums.com/forums/f44/...ier-89244.html. I made this rig last week with the help of my local welder. The rack is a Yakima swing daddy. and it works Great!!! No problem turning or backing up.
Ed rottinger is offline   Reply With Quote
Old 04-01-2012, 09:49 AM   #64
Ladylongwinger
Ladylongwing's Avatar
1999 27' Safari
McAllister , Montana
Hello, I am trying to install the Airstream bike rack on the back of my 1999 27' Safari, and am stymied at making sure there is access to both the back luggage compartment as well as the bumper storage. The back luggage compartment seems wider than the frames for the bike, and there won't be enough clearance to open the door. Anyone else tried this and had success (or failure?) Thanks! Anne in VA
"Some people try to turn back their odometers. Not me, I want people to know why I look this way. I've traveled a long way and some of the roads
weren't paved."
Ladylongwing is offline   Reply With Quote
Old 04-02-2012, 08:37 AM   #65
Geezer
1991 25' Excella
Sapulpa , Oklahoma
I am sure that we will all have to buy new ones.
LRPorter is offline   Reply With Quote
Old 10-31-2012, 01:47 PM   #66
Winemaker
rgwatkin's Avatar
2022 25' Flying Cloud
Avila Beach , California
Airstream/Fiama Bike Rack
I recently purchased a Fiama Bike rack from AS and installed it on a 2012 FC. It took me about 3 hours and was fairly straight forward. If installed correctly the rear access/storage door clears the rack. It is however very difficult to access the storage with either the bikes on or the rack not in the folded up position.
rgwatkin is offline   Reply With Quote
Old 12-06-2012, 06:20 PM   #67
Ladylongwinger
1999 27' Safari
I bought the Fiama bike rack just before going full-time, and although I should have checked this before I departed, there was so much going on I only worried about the luggage compartment. The bigger issue is the emergency exit through the back window, which is blocked with the bike handlebars and unless you finagle the support arms, possibly the rack itself. I have several pictures I will try to post. The fix was to work the top support arm over the curve in the rack and to a position where it would not interfere with the open window. The bike needed an allen wrench to loosen and move the stem/handlebar to point behind the trailer. It will need to be readjusted every time you use the bike or store it for travel. I haven't posted pictures before so someone help me through this and you can see what I mean.
weren't paved."
Old 12-07-2012, 10:27 AM   #68
Winemaker
rgwatkin's Avatar
I installed a Fiamma on my 2012 Flying Cloud without issue. There is a YouTube video that shows the installation procedure. Search under Fiamma bike rack and I think you will find it. It is pretty thorough.
Old 12-07-2012, 11:59 AM   #69
1975 31' Sovereign
Durango , Colorado
go to https://picasaweb.google.com/1065285.../BambiBikeRack#
and see what we did for a trip to Alaska on our Bambi. Getting the bikes up and down requires some strength. We took a 3 step folding ladder which helped with that and getting the kayaks off the top of the Landcruiser.
We purchased a Thule rack for 4 bikes, but only put three on because making tight turns with 4 was risky. You take the horizontal bar off of the rack so you can mount it vertically in the new one on the Airstream. Take all of the parts along and you can switch the rack to your car if you want to go on an expedition and leave the Airstream at camp. This worked great and you can keep an eye on the bikes and not worry about them when backing up!
Folding 3 Bike Towing Rack for 2" Trailer Hitches - Swagman XP Swagman Hitch Bike Racks S64955
and here is another option, but it says for bikes and a lightweight trailer, but you could also have this fabricated.
bbmombo is offline   Reply With Quote
Old 10-10-2014, 01:50 PM   #70
mike28's Avatar
2005 28' Safari S/O
Lakeland , Florida
I was just reading your post on your bike rack. What brand is it? I see that it folds down for rear compartment access, is that correct?
Mike
mike28 is offline   Reply With Quote
Old 10-11-2014, 09:50 AM   #71
Ladylongwinger
1999 27' Safari
The Fiamma does not fold down for compartment access. Sure wish it did, as it is a PITA to get stuff in and out, but I have gotten used to it. My biggest issue was emergency window access as I described earlier, and I just have to loosen and move the handlebars to face back and I have (just barely) clearance.
weren't paved."
Old 10-11-2014, 10:49 AM   #72
1975 31' Sovereign
Durango , Colorado
bike rack
Here was our solution. We had a vertical receiver hitch welded behind the propane tank storage to accept the bike rack. We carried a compact step ladder to get them up and down. It worked great all the way from Colorado to Alaska and back.http://www.airforums.com/forums/atta...1&d=1413046078
Old 10-11-2014, 11:37 AM   #73
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I'm jealous of folks who can overload the tongue weight of their trailer, possibly the axle weight of their truck, use no weight distribution hitch and never get in trouble. I would never be that lucky.
Doug and Cheryl
Old 10-11-2014, 10:11 PM   #74
1975 31' Sovereign
Durango , Colorado
Wink Karma
Either we have better Karma than you or my husband did all of the engineering
Old 10-12-2014, 10:15 AM   #75
Winemaker
rgwatkin's Avatar
I also have a Fiamma which blocks access to the storage space. Going forward Fiamma should either come up with a design that swings away or since Airstream is the only source for the rack they should make the storage access to the sides as some earlier have. I would be willing to give up the lower portion of my closets to get better access to the larger storage area.
Old 10-12-2014, 07:23 PM   #76
TCwheels's Avatar
2019 25' International
Traverse City , Michigan
I'm adding an angle iron cross member to the frame just behind the bumper under the bumper storage box. Then attaching a Reese hitch receiver to the angle iron piece. This will hold our hitch-type bike rack. I DID consider the Fiamma unit, but we often transport our bikes to trail heads using our TV. With this setup I can move the bike rack to the TV and don't have to carry another bike rack. I'll post pics when the install is complete.
WBCCI #7246
"Don't let perfect be the enemy of better."
TCwheels is offline   Reply With Quote
Old 10-12-2014, 07:50 PM   #77
silverbp's Avatar
2014 25' FB Flying Cloud
LaMarque , Texas
Well TCWheels I did the very same thing. I weld so I made a frame that I bolted between the frame under bumper. Got the 2" receiver at Walmart and it bolts to my frame. My rack holds three bikes and it looks good there as well. Good luck with yours.
Sent from my iPhone using Airstream Forums silver bp
silverbp is offline   Reply With Quote
Old 10-12-2014, 08:00 PM   #78
silverbp's Avatar
LaMarque , Texas
Name:	ImageUploadedByAirstream Forums1413165623.750398.jpg
ID:	224250Click image for larger version
Name:	ImageUploadedByAirstream Forums1413165640.494462.jpg
Old 10-12-2014, 08:21 PM   #79
Originally Posted by silverbp View Post
Attachment 224250Attachment 224251
I feel that the back end of your Airstream, is headed for trouble.
Contrary to opinion, the "shell" holds up the frame.
When adding weight to the frame, you adding an addition load on the fasteners that hold the frame up to the shell.
Unless you add additional fasteners, in time, you will find that the frame will separate from the shell. That in itself, causes many other issues.
Adding that extra piece of metal between the frame, actually makes the issue even worse.
Then take the weight you have added.
Measure from the center of the rear most axle, back to the rack you have added, in feet. Guessing in your case about 8 feet, times the weight of the bikes, lets say 100 pounds.
The total moment arm weight, sitting still then is 800 pounds. When you hit a bump, that weight multiplies depending on the severity of the bump. Therefore very easily, you can get up to 2000 pounds or more. The rear end hold down fasteners were never designed to handle that weight.
Moment arm is the principle of a crow bar, and is exactly the same on any overhang, such as the bumper.
In the case of the Fiama bick rack, it's also attached to the shell, which minimizes the problem.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-12-2014, 11:43 PM   #80
TCwheels's Avatar
Thanks Silver bp. Nice bike BTW!
If it's not too much trouble could you post a couple of pics from the underside? I'd love to borrow your successful design.
WBCCI #7246
Anyone have a Thule Xsporter Truck Rack? bike_addict Tow Vehicles 8 10-20-2011 04:59 AM
Tire Rack $70 Reward Card my3sonsdad Tires 1 08-02-2011 11:22 AM
Vintage Magazine rack Dan G Cabinets, Counter Tops & Furnishings 2 05-11-2011 02:54 PM
Bike Rack Option the ponz On The Road... 5 04-19-2011 07:01 AM
Rollout spice rack in 25SS Rivet3177 Cabinets, Counter Tops & Furnishings 0 01-26-2011 10:00 PM
