Old 10-29-2014, 05:08 PM   #1
Winemaker
rgwatkin's Avatar
2012 28' Flying Cloud
Avila Beach , California
Beware.. unlockable door!
I have a 28ft 2012 FC and when I recently returned from a relatively smooth 500 mile trip I could not open the door. With both locks seemingly unlocked the door would not budge. After some careful prying I was finally able to get it open. The problem was that both screws on the dead bolt had walked out and almost made the door unable to open. Interestingly these screws had no lock washer on either one of them nor was it possible to put one on as it would put the head of the screw too far out for the door to operate. Nor was there any sign of any lock tight type material on the screws. My solution was to apply lock tight to the screw thread and put the screws back using an impact screw driver. I suspect this will work but...if you have a new trailer you might want to check your screws just in case.
rgwatkin is offline   Reply With Quote
Old 10-29-2014, 05:30 PM   #2
terryV's Avatar
2002 31' Classic
Monroe , Iowa
I will. Thank you.
terryV is offline   Reply With Quote
Old 10-29-2014, 06:25 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Make sure you use the blue (low strength) Loctite. The red (high strength) stuff will be immovable when it dries, and you won't be able to get the screws out if you need to.
Old 10-29-2014, 06:34 PM   #4
interstateflyer's Avatar
2017 25' International
Los Osos , California
Good info. Thanks
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 10-29-2014, 07:25 PM   #5
Winemaker
rgwatkin's Avatar
That's what I used.
Unlockable compartment locks bkahler Argosy Motorhomes 25 10-27-2009 07:58 AM
Buying mattress pad? beware of Camping World false ad. femuse Our Community 5 03-19-2003 06:55 PM
