Old 08-18-2016, 04:27 PM   #1
DarrellT's Avatar
Longview , Texas
Battery monitor for NEW 26U
We'll be taking delivery on a 26U in a couple of weeks. I assume there is no battery monitoring panel supplied by Airstream.
Have decided the Bogart TM-2030RV is the way to go ...
http://https://www.solar-electric.co...rYYxoC4Z7w_wcB
Is there reasonable room in the battery box to fish wiring into the trailer to feed the control panel? Anyone doing this and want to share your experience?
Darrell
DarrellT is offline   Reply With Quote
Old 08-18-2016, 04:41 PM   #2
2015 30' Classic
Pleasanton , California
You could repurpose the CAT5 cable that's pre-installed for solar. I installed a Blue Sky controller with the IPN Pro remote that acts as a battery monitor. I was able to repurpose the 4 twisted pairs in the CAT5 wiring for my installation and still have one pair left over.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 08-18-2016, 07:27 PM   #3
2016 28' International
Redmond , Washington
I would check out the the Victron Energy BMV-702, it's smaller and has a Bluetooth add on. Also using a 2" hole saw makes installation a snap.
If you only care about monitoring voltage and not temperature you can connect to the bus bars on the inside of the trailer. If you want to direct connect I'd pull the rtv out that holds the wires where they enter the floor then recaulk it after running the wires.
Lastly if you plan on doing solar using the BMV-702 saves money later if you installed Victron parts.
Mgieselman is offline   Reply With Quote
Old 08-19-2016, 05:09 AM   #4
DarrellT's Avatar
Longview , Texas
Thanks guys!
Old 08-19-2016, 03:20 PM   #5
2000 30' Excella
2014 30' Classic
Princeton , Iowa
Have a '16 26U and it has a battery monitor. I have used mine about 65 days and 7500 miles and we sure like it.
larryglarson is offline   Reply With Quote
2016 Flying Cloud 26U TG2500 2016 - Current Flying Cloud 520 09-11-2022 11:36 AM
26U Macerator Toilet - What do you think? Plan-B Sinks, Showers & Toilets 39 07-12-2017 03:07 PM
A/C problem in new 26u Bgibbs Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-25-2016 02:27 PM
New 2016 26u Trees01 Member Introductions 1 01-17-2016 10:01 PM
26U Floorplan is Sweet! Bewell Airstream Lifestyle 1 09-25-2015 06:30 PM
