08-24-2014, 11:34 PM
2012 20' Flying Cloud
Anchorage
, Alaska
Battery Disconnect Switch Questions
I could use some clarification on how to use the battery disconnect switch on our 2012 20ft Flying Cloud.
1) When our trailer is sitting in the driveway, plugged into our outside outlet (110v), should I have the battery disconnect switch in the "use" or "store" position?
2) When we are out boondocking, using our Yamaha 2000W generator in the morning to make coffee, and possibly in the evening to charge up electronic devices, should the battery disconnect switch be in "use" or "store" position?
Just trying to get the most out of our battery, especially when out boondocking.
08-25-2014, 06:37 AM
2009 30' Classic
Melbourne, FL
, Searsport, ME
Usually the converter is wired between the battery bank and battery disconnect switch so that when you're on 120v AC, i.e.when shore power is plugged in or the generator is running, the converter keeps your batteries charged. Therefore, the only items affected when in the "Store" position are those on your 12v DC circuit. It's okay to leave your trailer plugged to shore power or on generator power with the disconnect switch on either "Use" or "Store" because the 12v and 120v items are on separate circuits.
What you don't want to do is leave the switch on "Use" when you're not on either shore or generator power because the converter is 120v and cannot charge the batteries. They will become depleted at a rate dependent upon how much 12v current is being used. Even when the trailer is sitting and not in use, there are parasitic loads which will slowly drain the batteries. So the bottom line is always switch to "Store" when not plugged in to 120v.
08-25-2014, 08:26 AM
2012 25' Flying Cloud
Battle Lake
With external power (shore or generator) the converter/charger will be charging the batteries in the "USE" position, the batteries will be isolated from the converter/charger in the "STORE" position and cannot charge.
Trouble is the factory converter/charger is a single stage charger than will put too high continuous voltage on the batteries over long periods, and shorten battery life.
As an interim you may want to get a small portable three stage charger for use at home leaving shore power disconnected. While boon docking and using the generator sparingly you have little choice but to put the battery switch in "USE" so the batteries can recharge.
The longer range answer would be to replace the Airstream converter/charger with a quality three stage charger so it can properly charge your batteries with the switch in "USE" position.
Doug and Cheryl
08-25-2014, 11:41 PM
2009 30' Classic
Melbourne, FL
, Searsport, ME
I beg to differ with your statement. Maybe your converter/charger is wired after your disconnect switch, but mine, and I believe most are wired before it. I suppose it' could be different with different years and models. So I stand with what I said if the converter/charger is wired before the disconnect switch.
I suppose the OP will need to check to see where in the 12v circuit his is wired.
I agree regarding the advantages of a 3 stage charger, but that's another topic and not what he's asking.
08-26-2014, 09:52 AM
Battle Lake
Maybe best to quote the Owners Manual:
"The disconnect switch is used to separate the batteries from the 12-volt distribution panel and converter charging system.
When the switch is turned "Use" (on) and the trailer is plugged into a 110-volt shoreline, the 12-volt distribution panel will receive power from the converter and the batteries will be charged through the converter charging system.
When the switch is turned to "Store" (off) and the trailer is plugged into a 110-volt shoreline, the 12-volt distribution panel will still receive power from the converter, but the batteries are disconnected from the system. The batteries will not be drained with the switch in the "store" position. The converter will not charge the batteries with the switch in this position.
The charge in the 12-volt batteries is replenished when towing from the tow vehicle alternator through the 7-way cord. This charge will go to the batteries no matter which position the Battery Disconnect Switch is in."
Doug and Cheryl
08-26-2014, 10:19 AM
2009 30' Classic
Melbourne, FL
, Searsport, ME
Maybe something's been changed over the years. I know that on my 2009 Classic, the converter is wired to the same + and - bus bars as the batteries. In my manual, they call the disconnect switch the "kill" switch. The kill switch, to use their term, is between the + bus bar and the 12v fuse panel. With this arrangement the batteries are maintained whenever on shore power whether the kill switch is on either "Store" or "Use." With this arrangement, the kill switch only "kills" the 12v circuit.
08-26-2014, 10:34 AM
2014 25' Flying Cloud
Cuddebackville
, New York
In "Store" the LP detector is still running on the batteries, but that should be the only load.
2019 Ford Expedition Platinum
08-26-2014, 10:42 AM
2013 28' Flying Cloud
Central
, Canada
Interesting - When I asked my dealer the question about leaving the switch on
"use" while plugged in (for a long period of time) they told me it really does not make any difference one way or the other.....
It has always been my understanding that you want to have the switch turned to USE when you first plug in to shore power. This will charge the batteries and make sure they are topped up.
Then after a day or so, turn the switch to STORE as that will take the batteries offline as they have been charged. Leaving the switch on USE would only have the system continue to put a charge into batteries that are already holding a full charge. That might not be the best for the batteries.
Is this correct?
Trying to use my camera to create memories - not photographs!
08-26-2014, 10:46 AM
2009 30' Classic
Melbourne, FL
, Searsport, ME
That's right. In my electrical system I can see the LP detector wire is attached to the + bus bar which is before the disconnect or "kill" switch
08-26-2014, 10:59 AM
2009 30' Classic
Melbourne, FL
, Searsport, ME
This statement implies that the converter/charger is wired before the disconnect switch and that your batteries will be charged whether the switch is on or off.
Ideally, you should leave it on shore power as much as possible so the batteries are maintained by the converter/charger at full capacity by a "float" charge. To do this requires a 3-stage charger as Doug stated above. Airstreams usually come with a single stage Parallax converter/charger and this will sulfate your batteries if left on all the time. Thus, the dealer statement to fully charge and then take the batteries "off line."
08-26-2014, 02:45 PM
2009 30' Classic
Melbourne, FL
, Searsport, ME
I meant to say will cook your batteries over time as the Parallax charges at a constant 13.6-13.8 which is more than a fully charged battery needs. A float charge is normally about 13.2 volts.
08-26-2014, 03:02 PM
Oswego
Mine operates this way as well.
-Rich-
08-26-2014, 05:53 PM
Durango
If the Converter was wired before the "Kill switch" , then as long as you were plugged in the Parallax single stage converter would cook your batteries assuming you left the shore power connected while stored. The store position would not disconnect your batteries from the converter.
So if you were to store in a cold climate. The only way to do that and not have your batteries freeze would be to regularly connect to shore power to keep a charge but not long enough to cook the batteries.
Is that what you are saying? I guess I don't see why you would ever need to put the switch in "Store" mode if that were the case.
08-26-2014, 07:34 PM
2009 30' Classic
Melbourne, FL
, Searsport, ME
The only reason would be to reduce as much 12v parasitic load as possible so that the battery is not being depleted by say something like a light or fan left on.
Let me say, I'm not advocating one method versus another only stating that's the way it works when the converter/charger is wired between the battery bank and disconnect switch. Obviously, there's no pat answer to the question the OP was asking. The correct answer is, "It depends on how your converter/charger is wired."
I think the lesson from this discussion is regardless of what the manual or dealer tells you every AS owner owes it to himself to personally check to see if their converter/charger is wired before or after the disconnect switch. By knowing which it is, the owner can know for certain the implications for the switch being on "Store" or on "Use" with the goal being to keep the batteries as fully charged as possible and as frequently as possible.
08-29-2017, 02:51 PM
2016 25' Flying Cloud
Albuquerque
, New Mexico
OK, I try not to repeat questions that have been covered on the forum previously, but after reading many of the posts, I'm still confused about the "Use/Store" switch on my 2016 Flying Cloud. I know it has a single stage charger which can be hard on battery life, so when I have it parked at the house it is connected to shore power. I keep the switch in the store position and place a trickle charger on the batteries.
My assumption from previous posts is that the store position eliminates the single stage charger to the battery. I know it serves to keep parasitic voltages from draining the battery, but am unclear as to whether i need to physically remove the positive terminal from the battery or if the store switch essentially does that for me.
'17 Ford F-150 Ecoboost, max tow package
'13 GMC Yukon Denali 6.2L V8
'04 GMC Yukon SLT 5.3L V8
08-29-2017, 03:03 PM
2007 22' International CCD
Corona
Unfortunately, some Airstream trailers (mine included) have a propane leak detector that is wired straight to the batteries, bypassing the installed use/store switch relay. That and the sub-woofer could possibly cause a fairly stout parasitic load. That little quirk, befor I got smarter, killed a nice set of batteries in a year...
My rig is now (DIY) wired so that the solar panel charge controller is tied direct to the batteries, so my use/store switch does not cut off the charging I get from the sun. This allows me to keep my batteries well-charged all the time, and keeps the solar charger from lighting the red power LED on the use/store switch even if the batteries are in 'store'. That eliminated some confusion on my part (grin).
Now, if the red LED is lighted, either I am actually running on batteries, or my convertor is powering the 12v bus from shore power. In either case, the batteries are always maintained by solar power...
01-23-2018, 11:30 AM
2015 30' Flying Cloud
Travelers Rest
, South Carolina
Light on Battery Disconnect Switch
Related question: I have a Battery Disconnect Switch in my 2105 30 Flying Could. It has a red light on it that stays on all the time. Should the light go off when the switch is in the off position? Does it make any difference that it is plugged in to power source?
01-23-2018, 02:32 PM
Tampa
The LP detector, the CO detector, the radio memory, the TV antenna booster (if on) and the subwoofer if you have one. Over the course of a couple months it will drain the batteries.
My plan is to install a battery disconnect at the battery box, then leave the wiring harness for a NoCoGenius 3500 inside the battery box. When stored, go to "store", switch the disconnect to "off" and plug in the trickle charger.
In theory, I should be able to plug into shore power with the battery disconnect "off", but the "Use/Store" switch in "use" and have all internal power except the inverter.
It's hard to remember that the converter is feeding power INTO the battery, while the inverter is taking it out.
The converter changes 120 v AC into 12 v. DC while the inverter changes 12 v. DC into 120 v. AC.
01-23-2018, 03:02 PM
Corona
The light on the use/store switch panel just tells you that there is 12 volt power available in the coach. It is unable to tell you if it is battery or shore power.
If your trailer is plugged in to shore power, the light will be on. If the trailer is NOT plugged into shore power, and the use/store relay is in 'store' the light should go off..
The only way to be sure the batteries are turned off is to press the 'store' side of the switch, and hear a 'clunk' from the relay. That means the relay has switched to 'store'.
No 'clunk', no idea what might be going on...the relay is mechanical, and does not control the red light at all...
