Old 10-26-2015, 12:09 PM   #15
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I wouldn't override a safety device in this way, probably there to keep the motor from burning out, possibly igniting something, or just ruining the motor.
Like everything else in RV's, serves most of the people most of the time. If not adequate our particular use, then we have to install a heavier duty appliance. Or stay within the design parameters of the product. We do plenty of this, better tires, better seating, bedding, tongue jack, hitches, and operate our medium duty pickup within it's limits.
Doug and Cheryl
Old 07-05-2016, 03:29 PM   #16
From Beautiful Egg Harbor
2016 25' Flying Cloud
Egg Harbor , Wisconsin
Beraldi Range Hood Failure
Interesting to read a year old thread about same safety problem we're having today. 2016 FC25 bought two months ago. One burner and oven on fan stops. (Vent open). AS customer service guy said the galley is for "camp cooking" like one is not to use the range except for heating hotdogs. Told to take to a dealer which is a reasonable suggestion. However by passing the heat sensor does not resolve the fact that AS continues to use a fan not intended for their installation. The Beraldi owners manual states hood must be 30" min above range. Ours has 21" clearance.
efaehw is offline   Reply With Quote
Old 08-16-2016, 11:14 AM   #17
We are having same Baraldi fan problem. 2016 FC25. Use stove. Fan trips off. Has no pass worked for you
Old 08-17-2016, 12:35 PM   #18
2014 25' FB Flying Cloud
Monroe , Washington
The by-pass of the heat sensor has worked really well for us. The fan is working fine and it's been 9 months since we had the work around done. I use 3 burners all the time and have no problems.
saraschurr is offline   Reply With Quote
Old 08-23-2016, 03:38 PM   #19
2016 20' Flying Cloud
Hot Springs , Arkansas
It is August 2016 and I am having the same problem with Baraldi vent fan. My problem is that it didn't come back on! Yes, the exterior flap is opened while cooking and the light works fine! If we except the work around and there are problems after warranty ends , then what? Airstream should replace the unit with another brand that does work no matter how many burners you use!!!
ljsigman is offline   Reply With Quote
Old 08-26-2016, 09:52 AM   #20
Baraldi Range Hood
Would you be so kind to post a picture of owners manual where it states the above? For some reason it was not included in my Airstream information.
Linda
Old 08-26-2016, 11:05 AM   #21
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Wow, I was considering swapping out my clunky looking but reliable Ventline for the Baraldi. Guess I'll reconsider.
Kelvin
Old 05-29-2017, 06:28 PM   #22
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
We've never had that problem in our '12.
2012 Dodge Durango Hemi/AWD
Old 05-30-2017, 08:12 AM   #23
kpayne
2015 28' Flying Cloud
Shreveport , Louisiana
Maybe LED lights will help cut down heat
Just replaced the original halogen bulbs on my Baraldi with LEDs from the Airstream Store. They emit much less heat and produce good light. Maybe this will help cut down on the excessive heat around the hood.
kpayne is offline   Reply With Quote
Old 09-30-2017, 12:19 PM   #24
J-Dog's Avatar
2014 27' Flying Cloud
Fullerton , California
Originally Posted by kpayne View Post
...Just replaced the original halogen bulbs on my Baraldi with LEDs from the Airstream Store...
You wouldn't happen to remember the part number by chance?
Our fan shut down yesterday using only two burners...once things cooled, we were back in business.
I would like to switch the lights to LED's first and if that doesn't help us, I will find the overheat switch and by-pass it.
J-Dog is offline   Reply With Quote
Old 10-10-2017, 06:27 PM   #25
2018 28' Flying Cloud
Broken Arrow , Oklahoma
Same problem here with our brand new 2018 Flying Cloud. Exhaust fan shuts off after a few minutes. Smoke alarm has gone off twice as a result. Removed the smoke alarm battery. Very annoying problem as I cook quite a bit when we are camping.
futzman is offline   Reply With Quote
Old 10-10-2017, 08:31 PM   #26
2008 19' Bambi
Carlsbad , California
It seems like the temp safety switch should shut the stove off, not the fan. The fan helps to remove heat, not create it. The small electric motor creates so little heat on its own as not to be a problem. I'll remove the useless safety switch and keep that hot air flowin out.
Russ
Ruscal is offline   Reply With Quote
Old 11-06-2017, 11:51 AM   #27
Kensington , Maryland
FWIIW 2017 FC FB
Fan stopped working and was howling loudly than only made a humming sound. My dealership has promised the part for sometime, in the meantime I diassembled the fan to see what the cause is. The plastic squirrel cage is pressed onto a small diameter shaft (fan motor). The squirrel cage is held onto that shaft with a ring clip built into the fan cage itself...you can not see it. This clip/detente mates with the end of the shaft were a groove is machined.
The "issue" is that the fan was never seated properly or it managed to wiggle off the detente. I've reseated it (firmly) and is working same as it did when Patrick showed us the trailer.
I'm not confident this will remain secure, it is a fragile setup. The "fix" if this comes apart again will be to simply put a dab of JB weld on the shaft and call it a day.
It is what it is, I'm ok with that.
PS - does anyone have a link to spare parts for this?
Too tall is offline   Reply With Quote
Old 11-06-2017, 12:03 PM   #28
2007 22' International CCD
Originally Posted by Ruscal View Post
It seems like the temp safety switch should shut the stove off, not the fan. The fan helps to remove heat, not create it. The small electric motor creates so little heat on its own as not to be a problem. I'll remove the useless safety switch and keep that hot air flowing out.
Russ
The general reason the over-temperature switch is there is to shut off the fan to remove a source of draft in case of a fire...on a typical home or restaurant ducted hood, keeping the fan running during a nice grease fire is an easy way to ignite the grease in the ductwork and get a very stubborn fire started... Been there, done that, put it out with a fine spray of water...Navy firefighting training saved the day again...
And yes, it would make a heck of a lot more sense to shut off the stove as well, but obviously the current sensor is a bit too sensitive for normal use...
KE4GNK/AE
rmkrum is online now   Reply With Quote
Baraldi Vent Hood power switch ghaynes755 General Repair Forum 12 10-16-2017 10:53 PM
Baraldi Vent Easy to Install? KJRitchie Stoves, Ovens & Microwaves 13 11-07-2014 02:20 PM
Baraldi Stove Fan Repair Spudnik01 General Repair Forum 0 07-29-2013 10:47 AM
Baraldi fan basket Spudnik01 General Appliance Topics 0 07-27-2013 08:27 PM
Problems Problems Problems pjude General Motorhome Topics 6 09-03-2007 08:25 AM
