Old 07-01-2015, 04:33 PM   #43
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I like what you did! I'm just too afraid to drill through the Tin Goat.
I put mine on the top of the belt and have it set up so the power supply is water tight in a water bag (smaller version of the roll bag we use for kayaking) and all outside. It's easier than setting up strings of lights on the awning and much easier if winds start blowing and you need to shut the awning quickly. I love them!
Name:	ImageUploadedByAirstream Forums1435789938.696899.jpg
Old 07-01-2015, 05:50 PM   #44
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
Great info thanks!
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 03-29-2016, 03:49 PM   #45
2015 23' Flying Cloud
Livermore , California
Assume the Diamond multicolor LED strings are similar?
cactusjk is offline   Reply With Quote
Old 03-30-2016, 07:31 AM   #46
2015 23' International
Charleston , South Carolina
Yes, as far as I know size, shape and installation would be exactly the same.
FollySteve is offline   Reply With Quote
Old 03-30-2016, 07:42 AM   #47
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
The factory will do the install, but I was told by someone at sometime last fall that it's expensive.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 03-30-2016, 08:14 PM   #48
W , New England
$600 - I asked....I'm sticking with my version 😀
Old 03-31-2016, 04:25 AM   #49
Bogeylights.com awning lights also look good.
Old 04-03-2016, 10:03 AM   #50
I am looking for a good picture showing how the OEM awning lights are mounted in the awning cover.
Old 04-03-2016, 11:17 AM   #51
moosetags's Avatar
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Attachment 242055
Your version is the same as mine, Steve, except that I put mine below the belt trim.
When an unexpected rain caused the AC transformer to short out and explode (literally), I found that I could wire the exterior lights directly into 12 DC. The short did not damage the light string. Now they work great without any further danger of shorting out.
I have recently taken this LED lighting thing to a new level. I have now framed all three large windows on Lucy's street side in LED's. The nighttime effect is really cool.
All four sets of lights were under $100 on Amazon. It sure is a lot of bang for the buck.
Here are a few pictures of the results.
Brian
ID:	259898   Click image for larger version
ID:	259900   Click image for larger version
SuEllyn & Brian McCabe
Old 04-16-2016, 11:18 PM   #52
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
'FollySteve', great write-up. Do you have any followup details/pictures on how your LED install location (on body) looks with awning closed vs open? Are you happy with the quality of light? With the awning closed, isn't the light pointing to the sky rather than down at the ground. How has that worked? I see the advantage of your location since we sometimes don't deploy the awning and the lights would still be available for use.
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
cory_can is offline   Reply With Quote
Old 04-17-2016, 05:16 AM   #53
W , New England
Awning lights for a 27FB Flying Cloud.
Brian - don't know how I missed your last post here. Those look great! How did you connect the internal lights to 12v?
I gave in and had them do the awning strip at the factory - was just under $500 and a complete splurge. They do the drilling so I don't have to 😀They also connect it inside to an on/off switch with dimmer slider.
I would like to find a convenient way to connect my belt line strip to 12v without drilling anything...
Old 04-17-2016, 09:20 PM   #54
moosetags's Avatar
Hi Steve,
We have the inside LED'S around the windows plugged into AC power. It would be easy enough to wire them into DC with a converter.
The outside LED strip is wired directly to the battery. I brought the wire out of the battery box and behind the rock shield. I didn't have to drill any holes.
Brian
Old 04-18-2016, 06:51 PM   #55
Cory_can,
Attached are several pictures with awning opened and closed with varying dimmer settings. I took pix with some daylight because camera exposure is problematic in full darkness.
Dimmer is very nice range with my light set, ranging from almost work light intensity down to practically off.
We really like the placement as it works with awning both open and closed. In both positions the flexible aluminum awning cover panels act as a reflector. With the awning closed the reflection is more harsh but still easy to control with the dimmer. With the awning open the effect is much better with a very even illumination. On lower dimmer settings the light is very soft and balanced.
We are very happy with the setup. We elected to use the remote control as the only switch and control. If we had it to do over we would elect to permanently mount a rheostat inside the overhead cabinet. Once we turn it on and set the brightness we tend to leave it alone and the convenience of a remote is not worth the aggravation of keeping up with it.
Only other thing to add is that we store our Airstream under cover so the installation gets exposed to rain infrequently. While the self stick adhesive on the light string is holding up well for us, I have some concern about how it would hold up with repeated rain exposure. If this is a potential I ssue for you, you might want consider options for a stronger adhesive.
Hope this helps
Steve
Name:	ImageUploadedByAirstream Forums1461026740.408973.jpg
ID:	260978Click image for larger version
Name:	ImageUploadedByAirstream Forums1461026753.976544.jpg
ID:	260979Click image for larger version
Name:	ImageUploadedByAirstream Forums1461026767.912925.jpg
ID:	260980Click image for larger version
Name:	ImageUploadedByAirstream Forums1461026781.132929.jpg
ID:	260981Click image for larger version
Name:	ImageUploadedByAirstream Forums1461026793.781476.jpg
ID:	260982Click image for larger version
Name:	ImageUploadedByAirstream Forums1461026808.553720.jpg
ID:	260983Click image for larger version
Name:	ImageUploadedByAirstream Forums1461026820.836079.jpg
ID:	260984Click image for larger version
Name:	ImageUploadedByAirstream Forums1461026832.287541.jpg
Old 04-18-2016, 06:56 PM   #56
W , New England
Originally Posted by moosetags View Post
Hi Steve,
Brian
Cool. I like the internal ones too! I've been contemplating how to rig up a version with my WBCCI numbers (in red of course) on a piece of plexiglass I can put in place at rallies and such.
Any pics of exactly what you did with the external ones and the battery connection? Thanks!
Flying Cloud :: 1958 Airstream Flying Cloud Cloud58 Airstream Registry Discussions 0 08-19-2011 08:32 AM
2010 Airstream Flying Cloud LIKE NEW!!!!! S2010 Airstream Flying Cloud LIKE NEW!!!! eBay Watch Airstreams on eBay 0 11-11-2010 03:40 PM
2010 Airstream Flying Cloud LIKE NEW!!!!! S2010 Airstream Flying Cloud LIKE NEW!!!! eBay Watch Airstreams on eBay 0 11-04-2010 03:40 PM
2010 Airstream Flying Cloud BRAND NEW!!!!! S2010 Airstream Flying Cloud BRAND NEW!! eBay Watch Airstreams on eBay 0 11-03-2010 03:50 PM
