Old 08-17-2014, 04:42 PM   #15
Van1's Avatar
2014 27' Flying Cloud
New Bern , North Carolina
No, it will not crush them. I have used them. Don't worry about that.
Van1 is offline   Reply With Quote
Old 08-17-2014, 05:38 PM   #16
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
I wouldn't mind seeing placement pics as well if anyone gets a chance
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
cory_can is offline   Reply With Quote
Old 08-18-2014, 06:24 AM   #17
Van1's Avatar
As soon as I install them I'll post pics.
Old 09-04-2014, 05:32 PM   #18
Van1's Avatar
Here are the photos of the lights I just installed. These particular lights come with a remote that can turn them off or on, can dim or brighten them.Click image for larger version
Name:	ImageUploadedByAirstream Forums1409869817.845486.jpg
ID:	220823Click image for larger version
Name:	ImageUploadedByAirstream Forums1409869843.953529.jpg
ID:	220824Click image for larger version
Name:	ImageUploadedByAirstream Forums1409869885.362598.jpg
ID:	220825Click image for larger version
Name:	ImageUploadedByAirstream Forums1409869911.420982.jpg
Old 09-04-2014, 05:59 PM   #19
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
^ looks great...the transformer just disconnects when you're travelling? Are they attached with 3M tape just below the awning on the trailer body?
Old 09-04-2014, 06:13 PM   #20
Van1's Avatar
No, I disconnect when traveling. I placed the end of the lights that hooks into the transformer at the end where the door is located. That way I can stand on the door step and plug in, or unplug, easily.
Old 09-04-2014, 06:18 PM   #21
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
Sorry, should have been more clear....after reading I can see how it would misunderstood.
It should have read...
Is the light rope attached with 3M tape just below the awning on the trailer body?
Old 09-04-2014, 06:21 PM   #22
Van1's Avatar
Ahh....no, the lights are placed on the underside of the metal awning cover with 3m tape. Not on the trailer.
Old 09-04-2014, 06:21 PM   #23
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Looking at putting the LED lights on the inside of the recessed aluminum awning cover to keep them safe from the weather and make for easy, safe storage. Like what you have done. Thanks for posting the photos.
tsunami is offline   Reply With Quote
Old 09-04-2014, 08:49 PM   #24
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Temporary attached with good old duct tape.
MICHAEL
Old 09-04-2014, 09:26 PM   #25
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Here are the photos of the lights I just installed. These particular lights come with a remote that can turn them off or on, can dim or brighten them.Attachment 220823Attachment 220824Attachment 220825Attachment 220826
This install looks very good! Just for clarity would it be possible to post an up close (macro) image of how and where you actually install the light strip
Is this the lights your using?
LED Light Kits
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 09-05-2014, 04:07 AM   #26
Van1's Avatar
Yes, that's the lights I'm using. I will attempt to take a really up close pic and post it.
Old 09-05-2014, 11:08 AM   #27
Van1's Avatar
LED Light Kits
Doug
Doug,
Here are the close us. As you can see, there are 4 channels on the aluminum awning cover. I installed mine in the channel closest to the side of the trailer. Although where I placed them is o.k. I think installing them in the channel furthest from the side of the trailer would be even better. I plan on moving mine to that location when I get an opportunityClick image for larger version
Name:	ImageUploadedByAirstream Forums1409933325.627637.jpg
Old 09-05-2014, 11:21 AM   #28
Arcticfox's Avatar
Central , Canada
Doug,
Here are the close us. As you can see, there are 4 channels on the aluminum awning cover. I installed mine in the channel closest to the side of the trailer. Although where I placed them is o.k. I think installing them in the channel furthest from the side of the trailer would be even better. I plan on moving mine to that location when I get an opportunityAttachment 220876.
This is excellent - Now I can see how you installed it. Do you think be moving the install to the furthest away channel that you risk having the lights hurt in anyway when closing/opening the awning? Not that I know one way or the other - just thought I would ask.
As a final comment, its to bad one could not create some type of plug system that would allow you to hardwire the lights into the trailer in someway. It would just clean things up a little....
Cheers
Doug
Flying Cloud :: 1958 Airstream Flying Cloud Cloud58 Airstream Registry Discussions 0 08-19-2011 09:32 AM
2010 Airstream Flying Cloud LIKE NEW!!!!! S2010 Airstream Flying Cloud LIKE NEW!!!! eBay Watch Airstreams on eBay 0 11-11-2010 04:40 PM
2010 Airstream Flying Cloud LIKE NEW!!!!! S2010 Airstream Flying Cloud LIKE NEW!!!! eBay Watch Airstreams on eBay 0 11-04-2010 04:40 PM
2010 Airstream Flying Cloud BRAND NEW!!!!! S2010 Airstream Flying Cloud BRAND NEW!! eBay Watch Airstreams on eBay 0 11-03-2010 04:50 PM
