03-01-2014, 07:10 PM
2012 27' Flying Cloud
Lake Oswego
, Oregon
Apple TV
We have a 27FC and are considering installing an Apple TV. I asked the dealership about such an install and they'd never even heard of Apple TV. Has anyone ever installed one before? Is it hard to do? I'd love to be able to access the content on both the front and rear televisions. Is this possible?
03-01-2014, 07:18 PM
1972 25' Tradewind
North Vancouver
, British Columbia
I have two in my house and they're easy peasy. Just follow the prompts and you're done. They're small and portable, so you can take it with you to the trailer. All you need is power and an HDMI cable.
North Vancouver, BC
03-01-2014, 07:24 PM
2024 23' Flying Cloud
San Antonio
Roku is similar. On sale at Target.
03-01-2014, 07:25 PM
Lake Oswego
, Oregon
How much is the Roku box? Can u get ESPN on the Roku?
03-01-2014, 07:28 PM
San Antonio
If I remember correctly, the Roku 2 was $69 or so. I cannot remember about ESPN, but if you go to the Roku website, they have the complete channel list. We really like ours paired with a Netflix subscription.
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
I use an Apple TV. Use an
HDMI cable to connect it to your TV. Plug it into a 110v circuit. Then follow the instructions to connect the Apple TV to a WIFI signal that has an internet connection. If you connect your Apple device (Mac laptop, iPhone etc) to the same WIFI network you can view photos and videos that are resident on your device using "Air Play". I don't know how you would hook up two TVs. Perhaps someone else here knows, or you could ask a tech at the Apple store.
03-01-2014, 07:33 PM
Lake Oswego
, Oregon
Given the interior set up of our airstream, we have 110 AC right above the blue-ray player. I'm guessing there's an hdmi cable hooked up to the blue ray player. I'd love to figure out a way to not re-patch each time we're going to watch a blue ray disk.
03-01-2014, 07:35 PM
1972 25' Tradewind
North Vancouver
, British Columbia
Does your TV have more than one HDMI port? If so, no problem.
North Vancouver, BC
03-01-2014, 07:38 PM
Lake Oswego
, Oregon
I believe it does. Next question is where to install it. In the cabinet near the blue ray player or underneath the flat screen. Any ideas?
03-01-2014, 07:43 PM
2016 25' Flying Cloud
Sunnyvale
Key phrase above is "WiFi connection.." Neither Apple TV nor Roku will work well inside an Airstream unless you have a strong and high-speed WiFi connection to the internet... And there are two challenges reaching that state if digital happiness..
First - The Airstream makes a pretty good shield to block incoming wireless signals (double walls of highly conductive aluminum..) so you will need an internal wireless router or be very close to an external source. Some of the 4G MyFi's working from LTE Cell towers might make it.. The second issue is that many campgrounds are limiting bandwidth to discourage "streamers" (as in streaming video content, rather than Air-streaming..). It is expensive and technically challenging to set up and maintain enough high-speed bandwidth to allow a park full of RV's to stream simultaneously, so most don't... They will purposely limit download speeds or capacity to make HD video downloads fail... (Not evil, just trying to address need for e-mails without building a major electronics infrastructure..).
Oh, and we do watch ESPN on Roku box, but initial log-in requires validation and link to cable or satellite subscriber account.. No free ESPN, given most cable companies have to pay them ~$7/month per subscriber... We haven't bothered trying to take Roku along in Airstream...
Condoluminum
03-01-2014, 07:46 PM
2012 25' Flying Cloud
Battle Lake
We use an Apple TV. There are two HDMI ports on the back of our standard equipment Samsung TV, one for the BluRay player and we plug the Apple TV into the other. Had to buy an HDMI cable for it. I think the Apple TV has to be placed in line of sight for its remote control to work.
Doug and Cheryl
Lake Oswego
, Oregon
If I had a movie already downloaded on my iPad, could I then view it thru the Apple TV via blue-tooth or does Airplay only function over wifi?
03-01-2014, 07:47 PM
Lake Oswego
, Oregon
Where did you mount your Apple TV?
03-01-2014, 08:07 PM
Battle Lake
When we converted to recliners we had this cabinet under the TV built, and set it there. But a holder or little shelf could be mounted under the TV.
Doug and Cheryl
03-01-2014, 09:11 PM
1972 25' Tradewind
North Vancouver
, British Columbia
You can get a mount for it from the Apple Store. Just attach it to the wall where the remote can get to it. Or just set it on a counter top - it doesn't necessarily need to be mounted anywhere.
North Vancouver, BC
03-01-2014, 09:15 PM
Lake Oswego
, Oregon
Thanks for the info. One other question, do you always need wifi to play content from a nearby iPad or will it play via Bluetooth?
03-01-2014, 09:30 PM
2014 28' Flying Cloud
2021 16' Basecamp
Millsboro
, Delaware
We are planning to install Apple TV in our as
We have one at home and love it.
I don't believe you need Wifi to use your iPhone/ipad just use airplay if you have later model iPhone/ipad
We watch movies so that will be the majority of our use
03-01-2014, 10:04 PM
1965 17' Caravel
1983 27' Excella
This may depend on how old your Apple TV is, mine only works through WIFI or direct HDMI connection. Mine is fifteen months old and has no blue-tooth capability. Perhaps the newer units have blue-tooth.
The Airport Express, sold by Apple, creates a WIFI network which will connect your iPhone/iPad to your Apple TV
03-01-2014, 11:11 PM
TinCan
2016 30' Classic
Apache Junction
You could also create your own network inside your AS but that is another story. Connecting the AppleTV to your TV would be simple. Download whatever via your computer and iTunes then watch or listen on your TV via the AppleTV.
TinCan
03-01-2014, 11:36 PM
1965 17' Caravel
1983 27' Excella
We use a Netgear MBR624GU WIFI router to network our PCs, printer, Iphones and Apple TV. It runs on 120v or 12v. It uses an Air Card for internet access. We no longer use an Air Card as we have a Verizon MIFI when we want to use the internet on the road. Our devices can also be networked using the MIFI, however, data moving from device to device uses our monthly data allowance, therefore, the Netgear router is best for us unless we need internet access such as for YouTube or other internet features of Apple TV.
