Old 05-18-2016, 05:59 AM   #15
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Originally Posted by KiraR View Post
I'm 1250 miles away from Jackson Center, not 650. Additionally, I am traveling the country with my kids, stopping in places in the West, currently in Colorado, with the intent to travel and spend time together exploring. I didn't plan on spending any time traveling to Ohio to fix the trailer. That was not factored into my plan.
You can always stop in JC on your way home. Start making a detailed list of all suspected defects. Give JC a call long before you get there to make an appointment to have all your complints addressed.
MICHAEL
Old 05-18-2016, 06:21 AM   #16
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I have been to the Airstream Service Center in Jackson Center on several occasions. I have found that sending them an email specifically listing all of of issues to be addressed helps to streamline the process.
Brian
SuEllyn & Brian McCabe
Old 05-18-2016, 07:56 AM   #17
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Airstream's quality has decreased in my personal experience and a fundamental reason is the speed up of the production line with no QC checks.
2013 25FB International Serenity made in July 2012 at 26 units per week. No warranty issues or the dealer corrected them during the PDI.
2014 31' Classic started the day before Christmas break 2013 and finished in mid January 2014 at 41 units per week. I was there every day. It was utter chaos with people climbing over one another. I watched the kitchen cabinet come in and be set down on the crossed ducting (I had a photo of this) which later precluded air flow to the rear bedroom discovered on the overnite. The dealer PDI did not notice the lack of air flow. Many issues pointed out both personally and followed up with an email to the factory QC supervisor were not addressed. I caught the wrong flooring and bathroom backsplash as the dealer had failed to follow through and verify that the approved change order had made it to the shop floor work order - I had a copy on my laptop so it was sloppily corrected and we had to replace that replaced flooring the first year on my nickel. There were broken wall trim, gouges in the wood cabinets, broken hinges, broken drawer catches, the list just goes on.
The 2015 23D International Serenity made the last week of September 2014 at 51 units per week was missing the "AIRSTREAM" name on the back of the trailer, the broken blind in the front vista view window had " pleats and the replacement came with 1" pleats so both had to be replaced., wadded up ball of unremoved plastic protective film still on the wall with the mattress shoved against it and the dealer put the bedspread on the mattress, bathroom door stops installed on the wrong side, sheet metal for the curb side wheel opening did not match the street side opening requiring metal work to install my tire upgrade, dead USP power points and the ongoing saga of breaking plastic catches.
The 23D sat on the dealer lot for over 9 months and as far as I could see, no physical PDI was actually done or these obvious issues would have been corrected. They waited until I was there and pointed out the issues I found and immediately proceeded to open a warranty claim for things they should have fixed during the PDI. The dinette leg wore a hole in the really cheap flooring in under 2,000 miles and we found one wheel bearing scored from lack of grease and the the other three needed to be properly packed.
I got a questionnaire from Airstream about the 23D and I pointed out several pages of issues in the reply. I never heard back from them.
The upgrades and repairs to both the Classic and the 23D have been very extensive and expensive. My upgrading the 2014 Classic to the 16" SenDel wheels and 16" Michelins for safety was addressed in the 2015 Classic by being standard equipment, just like on the Eddie Bauer and now the Pendleton models.
For both trailers:
We replaced all plastic catches with brass ones, replaced all 120Vac outlets with Hubbell commercial grade 20 amp GFI units, replaced the skylights with Maxim units, replaced all Fantastic fans with MaxxFan 7000 units, upgraded the 23D from 14" GYM tires and wheels to 15" SenDel wheels and Michelin tires, converted the Classic to disc brakes and the 23D to auto-adjusting drum brakes (replacing the wheel bearings and seals with USA made Timken parts). We have upgraded the water heaters, the stoves, the refrigerators and the electric power systems by adding solar systems with lithium batteries. We installed blocking under the cabinets so "stuff" can not fall down through gaps around the plumbing or poor cabinet fitting into the voids under the cabinets never to be seen again.
The plywood floor is still an Achilles heel for these units. While I watched, the chap applying the black edge sealer was certainly disinterested and did a exceptionally poor job of getting the stuff on the edges of the floor he was working on.
So once all the work was done, they are the way we want them and they should last our lifetime with the usual maintenance one would expect to do for a home on wheels.
This fix up process is a lot like remodeling a home. One can forget the trials and tribulations after starting to enjoy the fruits of the effort.
Old 05-18-2016, 08:23 AM   #18
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
Increased production may contribute the lack of QC, but it certainly is not a new phenomena
The original Town Hall......closed & gone.
In 2009 JC started the "Town Hall" thread to garner input from owners.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 05-18-2016, 10:00 AM   #19
Gainesville , Florida
And yet they sell everyone built?
Old 05-18-2016, 10:06 AM   #20
FCStreamer's Avatar
2014 30' Flying Cloud
And they have a backorder?
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 05-18-2016, 10:08 AM   #21
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
http://youtu.be/IIEVqFB4WUo
Superat stultitia.
Old 05-18-2016, 10:28 AM   #22
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
It does seem they indeed sell every one built and more.
For the OP, the problem list seems long and severe enough to merit a visit to JC vs. yet another round trip to the dealer in Denver, who seems to be having some pretty fundamental problems getting basic repairs done right.
Our experience with Rocinante's initial quality was far from perfect, and it honestly took us two years to get the kinks out. Some issues were so bad we had to get significant things replaced (e.g. our forward storage door and our tank monitoring system). However, none of our failures were serious enough to prevent us camping - except for the time she spent at the dealer getting repaired. We never made the trip to JC - it's just too far from Western WA to be feasible without a retirement plan in place.
I suppose we could have put Rocinante on a flat bed and had her delivered to JC for repairs, but that didn't occur to us because the problems and dealer service departments simply weren't bad enough to push us there.
Luckily, the quality of service we got from our dealer steadily improved over those two years. We can't claim credit for that - have to give props to the management team and their decision to build a service department they could be proud of (e.g. a service department that would drive more sales instead of driving customers away from them in particular and from Airstream in general). They still aren't perfect (they keep our trailer too long), but have become so much better than they were.
Best wishes, and don't give up! When it's finally right, it'll be great.
Rocinante is our 2014 International Signature 27FB
Old 05-18-2016, 11:51 AM   #23
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
On my third Airstream . My 2012 is pretty great except for the water pump which is once again sucking air {NO biggie IF (a) I were 20 and nimble or (b) they put it somewhere other than under a closet in the hall where one needs orangatang arms to reach it and fix it.} and the tongue jack - a "special one" the prior owner put in flaked out 5 times before I ordered a replacement. AND a flat tire, and a damaged umbilical cord that got chewed up in a tight cornering situation by the Hensley hitch.
SORRY you are having so many problems. That was a "monday" build probably. Persist, it will get better.
Paula
Old 05-18-2016, 12:36 PM   #24
So the four problems you mentioned only the water pump was the fault of AS. Pretty luck. Referring to post 23.
Old 05-18-2016, 01:12 PM   #25
Each time you take it in for service at a different dealer it is the first time, five dealers? Why didn't you go back to the dealer who did the work instead of to a different one. Have you read your owners manual? Perhaps you are doing something wrong unintentionally. Being persistent at one dealer is much better than jumping around to others as I see you gave been in contact with the factory. Did you take it to a non AS repair shop? If so what did they do?
Old 05-18-2016, 04:12 PM   #26
Rivet Slave
Rocinante's Avatar
Anyone else have serial problems with their AS?
Sorry to have missed your post above. Yeah, I wouldn't want to make the 1,250 mile trip either. If you're headed to Spokane, WA, the dealer there does good work and they are very pleasant. Our own dealer is "Airstream Adventures NW," one of the larger Airstream dealerships, with multiple locations across the PNW (and in Boise, ID). We are most familiar with the location in Covington, WA.
Perhaps other members will chime in with dealers in the West who they believe to be particularly helpful. That way if you'll be passing near one of them, maybe you can get the worst problems resolved along the way. Switz often mentions his favorite authorized service location that isn't a dealer, so it may also be worth searching on his username for a post where he mentions them. I believe they are in Texas.
Meanwhile, it never hurts to chat with the folks at Airstream customer service to let them know just how unhappy you are, and why. We've done that in the past and had reasonable results, though to be fair our larger dealer has been quite effective at going to bat for us when we (and they) wanted something expensive fixed and paid for by Airstream under warranty. If you have a good relationship with your original dealer, maybe they can step into the conversation to help lobby for your satisfaction. Unfortunately, this process often takes time, but it still may be worth a try.
Old 05-18-2016, 05:22 PM   #27
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
I personally would be wary of buying any "New" RV ... I've heard so many horror stories of poor workmanship on other trailers as well as airstreams .... I think thats the lucky thing about taking and oldie and turning it into a "newby" at least you know what been done ... I realize not everyone can do this... but I would be some PO'd if I spent that amount of money and was constantly having quality issues!
rucos is online now   Reply With Quote
Old 05-18-2016, 05:23 PM   #28
enived2's Avatar
1967 20' Globetrotter
Englewood , Colorado
Images: 12
I am sorry for your problems. The one thing I can say, and I think others will agree is that all components in travel trailers are crap. Regardless of whether it is Airstream or a $12000 off brand trailer, they all use the same crap components for toilets, fittings, hot water heaters, ect. ect. Even when Airstream could source better components like tires, Airstream uses crap marathons instead of Michillins. At some point I hope you get your trailer fixed with components that work. Is that asking too much? I don't think so!
Www.projectmidge.wordpress.com
enived2 is offline   Reply With Quote
2016 Inverter problems - anyone else? Two Peas Electrical - Systems, Generators, Batteries & Solar 19 12-04-2017 06:38 PM
Anyone Have LED Taillight Problems on their Classic KJRitchie 2006 - 2010 Classic (all lengths) 10 11-09-2014 12:12 PM
Has Anyone Else Had a Bear Climb In Their Airstream? cclarkego Off Topic Forum 117 01-17-2011 08:30 PM
Who's done their Airstream with their custom style interior? ANY PICS LAWFISH Upholstery, Blinds, Walls & Interior Finishes 1 02-08-2009 05:36 PM
anyone else have a 69 Sovereign? Randy Lee Member Introductions 1 08-18-2007 09:18 PM
