09-29-2016, 06:42 AM
2015 25' FB Flying Cloud
Nebo
, North Carolina
All exterior lights, brakes,tail lights, position lights.
In advertisements I have seen photos of an Airstream with out a TV and all outside lighting is on.
How is this done? There are times whin I need all the light I can get..
Lkjdude
09-29-2016, 06:47 AM
1973 31' Excella 500
Vicksburg
, Mississippi
You can do this thru umbilical cord plug. Get a plug and connect the charging circut to running light circut. Insert plug and running lights come on.
You can put a switch or switches if you also want to use brake or reverse lights.
A great way to test your lights without having to hook up tv!
09-30-2016, 10:33 PM
2018 30' International
2016 28' International
2010 25' FB Flying Cloud
St Augustine
I just learned this last week at Urban Air where it's common to leave your parking lights on overnight to light up the street. I purchased a 3in piece of wire and used it as a jumper for two of the slots in the brake wire plug.
Hold the brake wire upside down so the "spine" is at the 12 o'clock position, then jump the 11 and 1 o'clock positions (officially I think they are called the #1 and #7 slots) with a short wire.
Some folks had an actually plug designed just for this purpose.
I'll snap a picture this weekend.
09-30-2016, 10:45 PM
2019 27' Globetrotter
Salem
, Oregon
You can just use a flat 10 amp in line fuse. It will plug into the 11 and 1 o'clock position. This is the easiest. You could also figure where these wires go and wire in a switch.
Dave
10-01-2016, 12:13 AM
1995 25' Excella
xxxxx
, xxxxxx
Yep, I use a blade fuse between 11 and 1. If you want to get fancy, you can use a car emergency flasher to make them blink.
10-01-2016, 03:35 AM
1967 17' Caravel
Oak Creek
They all so sell a little gizmo on Ebay that plugs on the end of umbilical. About 10 bucks.
10-01-2016, 07:24 AM
1973 23' Safari
1970 27' Overlander
Boerne
I wanted to install a switch on the inside of the trailer to operate the clearnace lights. My trailer was gutted, so this was easy to do. Using the advice from others on this forum, I just tied a wire from the distribution box to the clearance light wire using a blocking diode and also installed a on-off-on switch to control the clearance lights - on for the TV, on from the switch inside (powered by the house battery), or all off. Works great and I like the control from the inside of the trailer.
Greg
10-01-2016, 03:07 PM
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera
CRH & Noresults cover the simplest, a 10 amp blade fuse inserted into your umbilical at the 11 & 1 position slots. Mind your batteries though!
10-02-2016, 08:33 AM
Silver Star
1970 23' Safari
Victoria
, British Columbia
I use the fuse as well...works great
10-03-2016, 06:42 AM
2013 30' Classic
Greenwood
, Mississippi
I also use a fuse.
I leave the fuse on the kitchen counter just inside the entry door so it's easy to find when I want to turn lights on.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
10-04-2016, 08:04 AM
St Augustine
Here are some pic's of what I did (in my post above). I do like the idea of using a fuse so will try that next time.
Remember the spine needs to be at the top to align the 11 and 1 o'clock positions.
10-04-2016, 09:54 AM
2013 30' Classic
Greenwood
, Mississippi
Attachment 272857Attachment 272858
I have done this, too.
Now I use a fuse.
I see that ProPride (or Hensley).
TAC #MS-10
Airforums #70955
10-04-2016, 10:05 AM
Vintage Kin
Fort Worth
This was one of those little things always wired by the factory on a Silver Streak. In the latest unit I can turn on all eighteen clearance lights plus tail from switches at either bedside or in the lounge beside the audio system.
Sure makes it easy for someone to find you.
