Old 07-05-2014, 06:58 AM   #15
2004 30' Classic
Hillsborough , New Jersey
bike racks on back of airstream
Wolf, it appears you found it, but here is the link for streaminlife:
http://www.airforums.com/forums/f209...per-39529.html
Streaminlife,
It appears that the new bike rack is a better design and has the "blessing" of airstream. But do read post 16 and 17 in the above thread. Unfortunately problems come up after years of use and then new design changes are made to "fix" the problem. I still would hesitate to install one. On smooth roads it would not be a problem but hit a couple of bad roads ie route 10 in Louisiana, railroad tracks etc. I would be concerned of the bike hitting the sides of the back of the airstream or worse falling off if not properly secured.
Wolf
wolf146 is offline   Reply With Quote
Old 07-05-2014, 07:49 AM   #16
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The Fiamma racks are well made and hold the bikes firmly. They don't wiggle. Our first Fiamma rack (similar to this one) was on the back of our VW camper which we carried all over the country without any problems. We have used our Airstream rack for two years, again all over the country, and it works as well, no problems.
Doug and Cheryl
Old 07-05-2014, 10:36 AM   #17
2014 27' Flying Cloud
Seattle , Washington
Hi,
Here is the video link for installation of the Fiamma Carry-Bike bike rack, in case anyone is interested:
I have a couple more questions...
In the video the bike rack seems to block the rear window at the bottom end (of the window). So, for those who have the bike rack: Can you fully open your rear window with the bike rack installed?
The video also mentions the need to relocate the license plate for visibility. Has anyone had to do this? Or, did the dealership relocate it for you?
Thanks again!
Karin
streaminlife is offline   Reply With Quote
Old 07-06-2014, 06:15 AM   #18
2014 30' Flying Cloud
Ponce Inlet , Florida
Hi Karin,
No issues with the window with bikes off. With bikes on we can not fully open the window or put the rear window awning down.
Licence plate may be slightly obstructed but we have been toolin around for over 7K miles and no one has bother us. We have zippo plans to move ours unless we have an issue. If you need to move it there are holes already on the frame of the bike rack to mount the licence plate. You would have to run power if you want to run at night to be totally legal.
Benn
Beach Bum is offline   Reply With Quote
Old 07-06-2014, 07:56 AM   #19
mefly2's Avatar
2015 25' FB Eddie Bauer
We just open the hatch ... LOL
Old 07-06-2014, 09:43 AM   #20
dkottum's Avatar
Then where do you sit or eat lunch . . . LOL
The EB presents an interesting situation. When we had the VW Eurovan Camper we used a Fiamma rack designed to attach to and lift with the rear hatch (without bikes on). It's partly supported by the rear bumper. It's also easily removable. I wonder if that model could be used with the rear hatch EB's.
Doug and Cheryl
Old 07-06-2014, 11:12 PM   #21
Thanks everyone for the answers, really appreciate it! It is good news the window can open (with bikes off).
Old 07-07-2014, 08:20 AM   #22
Holland , Michigan
I was at a dealer in michigan and they install a 2 inch receiver for a bike rack only across the frame in the back. Looks really nice the steel is powder coated and is the same color as the airstream frame.
Readgriff is offline   Reply With Quote
Old 07-07-2014, 09:33 AM   #23
1987 25' Sovereign
Oregon , Ohio
We use a front receiver hitch on our truck for our bike rack. This allows to take our bikes to other places without the trailer.
msmcv51 is offline   Reply With Quote
Old 07-07-2014, 03:57 PM   #24
Advodna's Avatar
2005 25' International CCD
Petaluma , California
Our rear window will open with the Fiamma rack and bikes (1 mens, 1 wmns mtn bike) installed. Took a little tweaking of the trays to the extreme left and right but window opens and rear awning can be fully deployed.
Dave
Advodna is offline   Reply With Quote
Old 07-07-2014, 04:15 PM   #25
interstateflyer's Avatar
2017 25' International
Los Osos , California
My Fiama Rack on 2013 International 19.
The rack weighs 25 lbs, bikes average around 27 lbs each.
No access problems.....I've adjusted to reaching around when bikes loaded. I usually put a piece of pipe insulation foam around the chainring to avoid arm scratching while reaching into the compartment.
The wheel troughs are so close that you need to isolate the bikes from on another to avoid scratching. Fiama make a carrier for VW vans, T2 or T3 that have greater separation between troughs. I'm looking into adapting that to mine.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is online now   Reply With Quote
Old 08-11-2014, 09:34 AM   #26
silverbp's Avatar
2014 25' FB Flying Cloud
LaMarque , Texas
I also I stalled a 2 inch receiver on the rear AS bumper. It looks great. I already had a nice bike rack and could not see getting another one and then try and find a place to store. It's the best of both worlds. Click image for larger version
Name:	ImageUploadedByAirstream Forums1407771269.149735.jpg
Sent from my iPhone using Airstream Forums silver bp
silverbp is offline   Reply With Quote
Old 08-11-2014, 09:36 AM   #27
silverbp's Avatar
LaMarque , Texas
Correction. It's just under bumper bolted to frame.
Old 08-11-2014, 11:04 AM   #28
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The rear window on our trailer is the fire exit, so any impediment would be a safety issue.
About the Airstream bike rack xo1rider 2011 - 2015 International 28 09-29-2017 01:11 PM
Flying Cloud (28) with Bike Rack.... Arcticfox 2009-2015 Flying Cloud 13 05-06-2014 08:30 PM
Airstream Bike Rack - License Plate??? aircampr Airstream Trailer Forums 37 03-15-2013 04:55 PM
