Old 06-18-2019, 10:16 AM   #1
2015 30' FB FC Bunk
Zeeland , Michigan
Air conditioner mesh screens
I have a 2015 FC 30 bunk with a single, ducted A/C. My question is about the interior air conditioner intake screens. Iíve cleaned the outside of them. Shining a light inside there appears to be more dust, etc behind the screen. Are these easily removed? I tried to get a finger behind it, but itís real tight. Donít want to bend. Didnít see how to remove in manual. Anyone know how to remove?
Bcousins is offline   Reply With Quote
Old 06-18-2019, 10:40 AM   #2
2004 25' Safari
2019 25' Flying Cloud
South West , USA
On your model they were installed with two spring clips, one on each end. A/S has had some issues with the return air (intake) screens falling out and may have cut yours a little smaller.
Just pull down on one end and slightly push it toward the other end while pulling it down. The spring clips are in the middle of the ends (Lengthwise), if you pull from the corners they can bend.
There should be two 'filters' (one each) behind the return air/intake screens . They can be cleaned by washing them out. Getting the 'filters' to stay put can sometimes be a challenge.
On the newer models A/S stopped using the spring clips and now puts two screws to hold them in/up.
-Ed
RivetED is offline   Reply With Quote
Old 06-18-2019, 11:10 AM   #3
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
I use a small rubber spatula to get into one end then plus down. It works!
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 06-19-2019, 05:53 AM   #4
2015 30' FB FC Bunk
Zeeland , Michigan
Thank you both. Plastic spatula was the trick!
Aluminum Mesh for guards robwok Exterior Restoration Forum 2 11-13-2012 07:54 PM
Mesh screen for a section of the belly pan...normal? Emerson75 Belly Pans & Banana Wraps 2 09-09-2009 06:08 PM
Need Help cleaning our screens and vent screens ctalley316 Full-Timing 3 09-19-2008 11:48 AM
Where to buy Copper Wool Mesh? Zstream Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 09-03-2008 09:59 AM
Grass Protection mesh gowyn Off Topic Forum 7 01-12-2008 06:28 AM
