Old 06-19-2014, 06:01 AM   #15
2015 30' FB FC Bunk
West Point , New York
Thank you again for all of the suggestions. The Airstream community is one of the things that made our decision to purchase easier. I have two questions:
The towing help/practice ideas is much appreciated. I look at the numbers for towing capacity, but want to throw it out to the community.
I currently own a 2013 Ram 1500 Crew Cab, Rambox, and 3.92 Gear Ratio. The Towing Guide states I should be able to tow a total of 9,950 lbs. The 30FB w/ Bunk has a total loaded weight of 8,800 lbs. Would there be any reason for me to bump of to a 2500?
There is a Airstream only park south of Atlantic City called Jersey Shore Haven Airstream Park. Would it be worth the extra 20 min drive to atlantic city to be around other airstream owners? Any reviews for the park?
Thanks for the help
Bmonty25 is offline   Reply With Quote
Old 06-19-2014, 09:56 AM   #16
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
BMonty25, well now you've opened up a whole new can of worms! the perennial 1/2 ton vs. 3/4 ton debate! I'm sure the diesel vs. gas debate will work its way into subsequent comments before too long as well.
There is no doubt that your 1/2 ton is more than sufficient to pull your trailer. Some people successfully pull their contemporary 30 foot long trailers with much less beefy vehicles including SUV's, full size passenger cars and even minivans!
#1 - Just make sure that your weight distributing/sway control hitch is properly set up (your dealer should have done this for you and you can search other threads for tips on fine tuning this if you want.)
#2 - make sure that you do not overload the tow vehicle. Check the payload capacity of your 1/2 ton and figure out how much you are carrying (passengers, fuel, gear, cap or tonneau cover AND hitch weight of your trailer) and just don't exceed that figure. Make sure your tow vehicle tire pressures are set for the load you are actually carrying. You can weigh your loaded truck and trailer at a CAT scale at nearly any truck stop if you are unsure of the total weight of everything that you are carrying. You'll find many threads on this forum that cover the weighing process. You may find that the payload capacity is the limiting factor to your using the 1/2 ton.
The 3/4 ton truck gives you two basic upgrade opportunities from the 1/2 ton: 1) a higher payload figure, and 2) the opportunity to get a diesel engine (although Chrysler has recently announced the availability of a diesel in it's 1/2 ton.) There are other advantages with the 3/4 ton such as beefier brakes, larger passenger area, possibly longer bed, etc... but they tend to come with the disadvantages of higher up front cost, lower fuel mileage when not towing, harder to park and maneuver in tight spots, stiffer suspension, etc...
My suggestion is to verify the weight/payload issue and then head out with your current 1/2 pickup. If after several trips (especially mountainous ones) you are not happy with the 1/2 ton, then you can think about another tow vehicle.
Bob Martel
WBCCI# 5766
Old 06-19-2014, 11:33 AM   #17
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Payload is not very controversial - attempt to estimate your payload - think of an "error bar" or a range of estimate of payload given your hitch - weight of gas - weigh of passengers - gear - tongue weight - etc....
Do not exceed payload
This for many for a 30 footer means 3/4 may be needed
Some will get by with a half ton
Do the math - good luck
Towing capacity is controversial it seems
PharmGeek is offline   Reply With Quote
Old 06-19-2014, 12:50 PM   #18
2015 30' FB FC Bunk
PharmGeek, do you mind if I ask what you are using to tow your airstream?
Old 06-19-2014, 03:30 PM   #19
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
2010 Ram 2500 diesel
I like to carry a lot of crap so I blew over payload figures in my estimations and my real life use has proven to be the case
We have two mountain bikes- kids crap - extra propane tank for our fire pit and portable grill - kid tow behind trailer - and some other stuff is fairly minimum and we plan on generator later too
But if half ton numbers can work for you - the ride I suspect will be smoother and nicer
Old 06-19-2014, 03:33 PM   #20
2015 30' FB FC Bunk
Thank you for the reply. I am new to this towing stuff. I am trying to figure payload impact on towing ability. The impact of tongue weight, etc.
I think I am closer than I initially thought to maxing it out. I also live in areas with tons of hills.
I know that I won't max the trailer weight, but also know I pal. To load up the truck.
How does your family like the bunks?
Old 06-19-2014, 06:58 PM   #21
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Weight distribution hitches can move some payload off he truck and back to trailer axels - that can I think help you in crunching figures
Old 06-22-2014, 11:13 AM   #22
2015 30' FB FC Bunk
Found a 2013 Ram 2500 with only 2,000 miles. Picked it up this weekend, and pick the AS up on Wednesday. Can't wait!
Old 06-22-2014, 11:47 AM   #23
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I ain't the smartest man in the world, but it looks like to me you ready to go campin'!
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
2013 Flying Cloud 30FB Bunk - new owners! BarryNolte 2009-2015 Flying Cloud 18 09-20-2013 11:28 AM
Airstream 30FB Flying Cloud Travel Trailer RV Aluminum New eBay Watch Airstreams on eBay 0 07-04-2013 07:40 PM
New 2013 airstream 30fb flying cloud bunk house travel trailer sleeps 9 eBay Watch Airstreams on eBay 0 05-17-2013 07:00 PM
2013 airstream 30fb flying cloud bunk travel trailer brand new! eBay Watch Airstreams on eBay 0 04-19-2013 07:20 PM
2013 Airstream Flying Cloud 30FB Bunk BarryNolte Airstream Registry Discussions 0 03-18-2013 11:24 PM
