Old 01-20-2015, 10:38 PM   #1
2015 27' Flying Cloud
maple grove , Minnesota
2nd A/C? Or fantastic fan on 27 with ducting?
Getting ready to order a 2015 27fb. If I get the 2nd a/c, they remove the bedroom fantastic fan and I'm stuck with a heavy 50 amp cord. Also it adds about 100 lbs, a lot of which will be on the hitch. On the other hand, if it gets really hot, it would be nice to have the extra cooling.
Has anyone bought a 2015 with single air and if so, how do you like it?
thebreezeman is offline   Reply With Quote
Old 01-21-2015, 06:18 AM   #2
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
We ordered the two A/Cs on our 30' after having another 30' without and a 25' without. The 30' comes with two fantastic fans and the two A/Cs, two skylights and we have factory installed solar as well. No room up there for anything else.
We tow with an F350 6.7 Diesel Crew Cab so weight is not a concern for me at all. We opted for the 30' over the 27' and 28' as the way I figured it if I can get a 27' into a spot I can get a 30' in. With our previous 30' never really had an issue, just watched which gas station we went into and how. Campgrounds never seemed to be a problem.
Good luck and enjoy
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 01-21-2015, 07:45 AM   #3
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
We have a 28' Argosy with 1 A/C. We have been out west in early fall and all over the midwest in the dead of summer. The only time we felt we could have used a second A/C was during that very hot spell a few years back. I'm sure you remember that hot spell. It was one not easily forgotten. We were at Willow River State park just east of you (on the good side of the tracks, WI) LOL. Otherwise one A/C has been fine.
We have not been out west or down south in the dead of summer so I can not speak for that.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 01-21-2015, 07:59 AM   #4
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Not directly to your point, but I've always felt that if we were in an area that needed both AC units running we'd move!
Having said that, we do have two AC units (non-ducted) on our 2014 trailer and do find it nice to turn on the AC unit that is not in the space where we happen to be occupying (e.g., we turn on the BR unit during the day and the LR one at night.) That helps to minimize the noise in the occupied area. Of course, with a 2015 model you will have ducted air so this may be less of a concern.
Also, I have identified some spare roof area in the bedroom where we could install a second Fantastic Fan next to the BR AC unit if we ever choose to do so. Thus, I would not assume that two AC's precludes two Fantastic Fans.
Bob Martel
WBCCI# 5766
Old 01-21-2015, 08:31 AM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Be careful of "Inch-itis", a constant urge to trade for a little bigger Airstream with the latest gadget. It's a wallet-depleting disease that flourishes during the winter months, quickly cured with spring-summer-fall camping in your presently new Airstream.
Doug and Cheryl
Old 01-21-2015, 11:03 AM   #6
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Much would depend on how you use it. High humidity summer use, not just high temperatures, should be the guide in selection for twin A/C if one is resisting that purchase.
When one does not have vehicle shade and/or adequate dehumidification is when the trailer becomes very uncomfortable. Wet bulb temperature is the issue.
Re-sale is negatively affected, and it is more expensive to add this feature post-factory. Potential buyers of your trailer may not be in your climatic region.
There are those with very definite ideas, and for yourself who is without such I would recommend you research the subjects of twin A/C units, retrofitting, and 50A service.
This is a trailer design which both cools and heats faster than others.
Good luck
Old 01-21-2015, 11:43 AM   #7
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
It would depend where you spend most of your time,being from montana we never use the ac as we are in the high mountains where is cool.In calif. In early spring or in up michigan in the fall, we used the heat pump.I would have changed mine to 1 ac and 2 fantastic fans for our use ,if too hot we move.....
tjdonahoe is online now   Reply With Quote
Old 01-21-2015, 12:57 PM   #8
2016 30' International
Boerne , Texas
We looked at a 27FB with the ducted AC and liked the fact that it was much, much quieter than our current 2012 27FB. It was touted as being more efficient such that 1 AC with ducts would be close to the same cooling capacity as a two unit non-ducted unit. If we really wanted to shell out that kind of money for an upgrade, I would want to test that assertion a lot more. Not sure how to do it unless it was 100 degrees out and had the unit side-by-side, however.
akjam is offline   Reply With Quote
Old 01-21-2015, 03:50 PM   #9
Dallas Center , Iowa
A complete awning package is a real benefit in combating the attack of the sun in hot summer. 2-ac units would be great in summer desert or ultra high humidity and high temp settings. Of course a small floor fan inside is amazing for moving around the cool air as a back-up to the single ac unit. It is one of those things where you may appreciate the 2nd air 2-5 days a year but the rest of the time you are just dragging it around. My guess is that you will get more long term benefit from the 2nd Fantastic Fan than you will the 2nd ac.
Earthcreeper is offline   Reply With Quote
Old 01-21-2015, 05:39 PM   #10
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
If you get 2 a/c units and don't want 50A service there is a device that takes 30A service and only allows 1 a/c to run at a time automatically. Might want to ask AS about that.
Our '69 Tradwind didn't have a/c and only 1 pathetic powered vent over the bedroom area.
So we added 2 Maxxair remote controlled vents and a 15,000 BTU a/c with a 8500 BTU heat strip and got rid of the old fashioned TV antenna and replaced it with a digital antenna.
I also add a second 30A service for the side by side washer & dryer.
ID:	230873   Click image for larger version
ID:	230875   Click image for larger version
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 01-21-2015, 07:57 PM   #11
2018 33' Classic
Newport , Pennsylvania
Buy
The 2 airs better resale
It is better to have it and not have it and need
In the grand scheme of thing the expense compared to not having the second air is minuscule
My 2 cents
EarlM is offline   Reply With Quote
Old 01-21-2015, 08:10 PM   #12
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We have a 2014 31' Classic with two air conditioners and eight solar panels on the roof. If we want to, the center exhaust fan between the shower and toilet could be converted to a Fantastic fan.
When we rewired the trailer for the solar system, we installed a new primary power panel that lets us shed AC power load (front air conditioner, water heater and refrigerator) and pass through only 30 amps of 240Vac or 120Vac to the Magnum MS2800 inverter/converter and back to the original power panel in the bedroom stressed roof locker.
Thus we can operate with either 30 amp or 50 amp power in either 240Vac or 120Vac situations
Old 01-21-2015, 08:25 PM   #13
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
lost the FF, installed second AC... upgraded to 50AMP... Momma happy.
We run the fan in the center bath if cool enough.. but it doesn't happen very often. We put a MaxAir over the center bath fan... just open the cover and run the heater.. we get enough airflow to keep inside from 'fogging up' with too much moisture..
Happy ending!
Peace and Blessings..
Channing
WBCCI# 30676
Old 01-21-2015, 11:04 PM   #14
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
It also depends on your camping style. If you camp primarily in parks with full hookups, the twin AC may be for you. If you're like me and primarily dry camp or boondock, the twin AC won't do you much good, and the fresh air from the Fantastic fan is a wonderful thing.
In my 28' with the slideout, the 15,000 btu AC unit will cool the interior down to about 80 degrees with the trailer in full sun when it's 105 degrees out with low relative humidity.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Refrigerator ducting Forrest Refrigerators 15 11-08-2013 09:15 PM
Maxx Fan Vs. Fantastic Fan Lumatic Roof Vents, Skylights & Fans 19 09-07-2011 07:10 AM
Furnace ducting question? Mrcrowley Winter Living 6 08-26-2011 07:51 PM
Late 70's light/fan Fantastic Fan installation question tschat Roof Vents, Skylights & Fans 2 07-18-2009 01:30 PM
Front ducting work Mobile1 Classic Motorhomes 1 11-16-2005 01:27 PM
