Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Flying Cloud > 2009-2015 Flying Cloud
Old 10-02-2017, 10:56 AM   #21
J-Dog's Avatar
2014 27' Flying Cloud
Rancho Cordova , California
Originally Posted by greghoro View Post
Caption on second photo indicates you drilled a hole in the roof to feed the cable inside. Just above an interior LED ceiling light.
What did you do to seal the roof area where it went through?
How did you feed the wire inside the trailer? Between the inner and outer skins?
Greg
Greg,
I have attached photos, hope that answers your questions.
The only picture I don't have of the install is how I routed the interior coax cable. I drilled a small hole straight down out of the cabinet, (way outboard against the interior wall), and used tie mounts and tie wraps to follow around the window frame to the dinning room table. The curtains cover everything so it isn't as bad as it sounds.
ID:	296069   Click image for larger version
ID:	296071   Click image for larger version
ID:	296073   Click image for larger version
J-Dog is offline   Reply With Quote
Old 10-02-2017, 01:02 PM   #22
Traveler
TravlinMan's Avatar
2017 25' International
Staunton , Virginia
Where did ya find the adapter to use a regular RF cable with the weboost? I need one so I can use my satellite input with the antenna. Thank you.
TravlinMan is offline   Reply With Quote
Old 10-02-2017, 02:18 PM   #23
J-Dog's Avatar
TravlinMan,
All the parts required for the installation were included in the kit (Drive 4G-X RV).
The external coax cable (what I would call the regular type), did not require an adapter at either end, the antenna or the booster.
The internal coax was significantly smaller than the external one and it did have an adapter in the kit to attach it to the inside antenna which was an even smaller coaxial cable.
Sorry I couldn't answer your question.
Old 10-02-2017, 02:35 PM   #24
Traveler
TravlinMan's Avatar
Staunton , Virginia
Originally Posted by J-Dog View Post
TravlinMan,
No problem, J-Dog, I appreciate the info. My unit is a drive 4gx (not RV) cause I bought it for the truck and the connection is a smaller rf connector called RG58U as opposed to the normal ones that I think are RG6......
Old 09-04-2019, 05:10 AM   #25
dwhitake's Avatar
1972 23' Safari
1978 31' Sovereign
Akron , Indiana
Completed our non standard WeBoost exterior antenna install yesterday. Not sure how well it will hold up when on the road; the TV antenna is not very robust so I will be keeping on eye out for any failures.
Why I did what I did was to be able to mount the antenna high enough so there would be no signal obstructions from our trailer. I had contemplated fabricating something completely different, then I thought that utilizing the existing TV antenna might work. Time will tell if the wind and towing will destroy the antenna assembly. I'll update this thread if things go bad so that nobody else will get the idea to perform this installation.
So far I like it, the cell phone booster is working fine.
Hi J Dog - I'm thinking of copying your setup for the Weboost antenna mount on the winguard mast. It's been a couple years since this post, any update on how your mount is holding up?
thanks
dwhitake is offline   Reply With Quote
Old 09-09-2019, 09:11 PM   #26
Journeyman
2016 25' International
Amherst , Massachusetts
I think this is what you are looking for:
https://www.amazon.com/gp/product/B071VF47XT/
Some (hopefully useful) Airstream videos here:
https://www.youtube.com/c/journeymanvideos
thiel is offline   Reply With Quote
Old 09-11-2019, 03:43 PM   #27
J-Dog's Avatar
thanks
I have had to replace the zip ties and zip mounts as the sun had degraded them. The long term fix might be using clamps and rivets or screws. I am planning on just replacing the zip ties as required.
The system overall works well.
Old 09-12-2019, 02:36 AM   #28
dwhitake's Avatar
1972 23' Safari
1978 31' Sovereign
Akron , Indiana
Thanks for the response. Glad to hear it's doing well
weBoost Drive Cell Phone Booster dasams Airstream Classifieds 0 09-01-2017 03:50 PM
How I installed my weBoost Drive 4G-X OTR on International 27FB tot2learn Electronics & Connectivity 18 07-10-2017 02:53 PM
WeBoost Drive 4GX RV KJRitchie Computers, Internet & Satellite 0 04-25-2017 08:24 AM
Update: WeBoost Drive 4G-X BoldAdventure Computers, Internet & Satellite 8 10-22-2015 02:30 PM
