Old 07-01-2019, 05:35 PM   #1
2014 23' FB Flying Cloud
Yamhill , Oregon
23FB Shower Drain Leak
Just am noticing water leaking outside only when using the shower. No water inside on the floor showing. Checked the access to the shower valve, all is dry. I suspect the shower drain is leaking. Thoughts or suggestions?
Rob Edgerton is offline   Reply With Quote
Old 07-01-2019, 06:01 PM   #2
2013 20' Flying Cloud
Westerly , Rhode Island
We bought our trailer used, but it must have had a shower leak at some point. An access hole was cut in the belly pan right under the drain and the flange probably just needed to be tightened.
smithcreek is offline   Reply With Quote
Old 07-01-2019, 06:29 PM   #3
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
Might be the same as on the 22, since the layouts of the bathroom is similar. Check the caulking at the bottom especially at the left side.
http://www.airforums.com/forums/f295...ak-142453.html
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 07-01-2019, 07:10 PM   #4
2002 19' Bambi
Lafayette , California
I recently helped fix (in a friend's Airstream with a corner shower) a similar leak a couple of months ago.
The shower drain is connected to the P-trap plumbing with a "swivel adapter" (https://www.menards.com/main/plumbin...4449188850.htm, https://www.rveparts.com/rv-sewer-ab...adapter-1-1-2/)
The swivel adapter uses a rubber ring gasket to provide a watertight seal. The threaded collar of the adapter compresses the rubber and can easily crack due to continuous tension and from supporting the weight of the P-trap and its contained water. After cracking, the joint then leaks out the bottom of the trailer. Rough roads can "help" crack the collar. The swivel adapter is common for RVs, but not in most plumbing supply stores.
We fixed the problem by cutting a hole in the belly pan to access the plumbing. After repair and leak testing, an aluminum patch and pop rivets covered the access hole.
Tim
Tim A. is offline   Reply With Quote
Old 07-02-2019, 09:16 AM   #5
2010 25' FB Flying Cloud
Snoqualmie , Washington
Just had the exact same problem and fixed at our local dealer. They said it just needed a new clamp. Hope yours is as minor
Anders79 is offline   Reply With Quote
Old 07-11-2019, 01:46 PM   #6
2012 22' FB Sport
Altamonte Springs , Florida
22FB shower leak
Oddly enough I just fixed ours yesterday. There was an inspection plate where it looked like some was there before. Ours is a Bambi 22FB. It was a nasty job and had to remove the inside shower drain piece just to get to the nut. Nut was split and leaking. Once I replaced the nut and reinstalled everything seems fine. I suspect everything does not line up exactly and may be stressing the connection. However once I got the lay of the land was a half hour job tops. Good luck!
mvalore is offline   Reply With Quote
Old 07-13-2019, 05:31 PM   #7
Yamhill , Oregon
Mine wasn’t a half hour, more like an hour plus a two hour trip to the nearest Home Depot for parts.
Below are pictures of what was there and what I replaced it with. Now if I need to work on it again it can all be done from below without having to take the floor drain out to get things apart. Poor original design in my opinion, and it didn’t leave any room to flex or for slight misalignment.
[ATTACH]346421[ATTACH]346422
ID:	346421   Click image for larger version
Shower drain leak TayaraTravel Sprinter and B-van Forum 13 10-03-2018 04:08 AM
Shower drain leak - 2006 International CCD tanniwells Sinks, Showers & Toilets 4 04-18-2016 10:14 AM
Water leak under shower 2013 23fb BobGall Plumbing - Systems & Fixtures 0 09-08-2015 08:49 AM
'06 Safari FB Water leak from Shower Drain RichHog Sinks, Showers & Toilets 0 09-01-2014 03:35 PM
Shower Door Leak 09 23FB Flying Cloud pebbrb05 Sinks, Showers & Toilets 1 06-13-2010 08:14 PM
