Old 02-11-2016, 09:35 AM   #1373
Long Island , New York
Thanks gypsydad, just to be clear --
I never doubted the ability of silicon to hold the vent in place, given that in a 5" diameter there are EIGHT points of adhesion.
Still doubting the predictable and easy remove-ability of the vent without damaging the ceiling aluminum inner skin . . .
Only a full-scale model from moosetags will provide an answer at this point IMO.
PS -- I have relied on moosetags' photos and descriptions, and have never seen such an AC vent in person. Oh, and plenty of construction experience . . . and logic . . .
Old 02-11-2016, 09:43 AM   #1374
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Double-Sided Tape
Small pieces of double-sided tape around the outer ring (mounted horizontally, outboard of the vertical tabs) will cure the dropping cover. There are two types of bonding compounds available from 3M; temporary or permanent.
I suggest you try the temporary compound first which holds well, yet can be removed easily without damaging anything. If the covers continue to drop in hotter climates then the permanent compound will cure the issue as it is rated to 212 degrees: just use 4-6 small squares strategically placed. I use both in my shop regularly for a variety of applications with great success.
Temporary:
http://www.amazon.com/3M-Scotch-Doub.../dp/B00I4D3ZTI
Permanent:
http://www.amazon.com/Scotch-Double-.../dp/B00004Z47L
Sirs Gawain & Galahad
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 02-11-2016, 11:23 AM   #1375
Shreveport , Louisiana
Experiment. Use a dab of silicone on maybe 2 or 3 tabs and assess the difficulty of removal. Go from there.
Endodoc is offline   Reply With Quote
Old 02-12-2016, 09:24 AM   #1376
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Thanks; I also have worked on many different aircraft doing sheet metal (aluminum), ventilation systems, etc., back in the day....however, wife looked at this yesterday, and suggested getting sticky velcrow tape strips, and install under vent flange and around opening and trim. Says problem solved...I'm not going to argue with my wife!
Old 02-12-2016, 09:33 AM   #1377
Will the vent still be adjustable and removable? My impression is that the very outside of the silver cover needs to rotate. If so the Velcro would have to permit this.
Moosetags?
Old 02-15-2016, 08:01 AM   #1378
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Moosetags?
I have thought about using some small Velcro tabs with the loop on the ceiling, right next to the opening, and the hook on the little grey ring that contacts the ceiling. This would still allow adjustment of the other two pieces.
My only concern with doing this is that the vent becomes quite warm when the heat pump is running. This could compromise the glue on the back of the Velcro pieces.
Brian
SuEllyn & Brian McCabe
Old 02-15-2016, 08:21 AM   #1379
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Late to this discussion and just throwing out a wild suggestion...but how about trying a spring to help hold the vents up? Similar to how inner sleeves of recessed can lights are held in place. With enough tension to assist the holding of the tabs but with enough spring to pull the vent down to attach/detach the spring. Just a thought....
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is online now   Reply With Quote
Old 02-15-2016, 08:35 AM   #1380
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
I have same issue as Moosetags on our 2015 30' FC. All vents were converted to adjustable and I did the replacement myself. When I took the non-adjustable out I saw the BIG difference in design between the two vents. The non-adjustable are metal tabbed and very hard to remove, the new adjustable are plastic and I could easily install and remove. SO, I put ductape on the circle of the inside skin for each hole, then applied gorilla glue to the tabs on each of the vents. If any fall out I may try loctite red as my next experiment. Really don't plan on taking them out in the future so don't care about removal.
I just looked on Amazon for RVT Sealant and found one that is designed for high heat areas, ie around fireplaces. So, may, if the vents fall again, try this approach.
High Heat Velcro Link:
http://www.rochfordsupply.com/shop/U...%29/index.html
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 02-15-2016, 08:41 AM   #1381
Ditto Brian to your concern about heat compromising the Velco adhesive, especially where the Velco adheres to the plastic vent base, if I have understood this assembly correctly.
Recent suggestion for spring may be difficult IMO. Where would the spring attach at the top end? Inside the round (flexible?) duct? Sounds as if this solution might create new problems of its own IMO. [deforming the duct wall, sagging, etc.]
PS Brian would you please try my Fred Flintstone solution with aluminum foil on (only) three tabs, and see if it helps keep the vent cover up? Each journey begins with one small step?
Peter
Old 02-15-2016, 09:24 AM   #1382
2016 27' Flying Cloud
Pittsford , New York
We have a 2016 26U - after the first few trips, vents started falling out. Agree seems to be a widespread problem
TG2500 is offline   Reply With Quote
Old 02-15-2016, 10:32 AM   #1383
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
The old spring clips sound interesting. Is there a reason why you didn't switch out the clips from fixed to adjustable?
subfan1 is offline   Reply With Quote
Old 02-15-2016, 01:08 PM   #1384
moosetags's Avatar
The metal clips on the OEM vents are spot welded to the the metal trim ring. I don't see any way to attach them to the adjustable vent plastic base ring.
Brian
Old 02-15-2016, 02:27 PM   #1385
Seattle , USA
Man...you guys could turn making toast into a 3 week discussion...
Clear RTV and be done with it.
RareStream is offline   Reply With Quote
Old 02-15-2016, 02:31 PM   #1386
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Well, it depends you make the toast on a regular toaster or one of those gizmos you put on the stove burner.
But yes, RTV cures a lot of problems. I used it on light covers that popped off all the time. Fixed it.
2012 Dodge Durango Hemi/AWD
2015 Flying Cloud woof 2009-2015 Flying Cloud 13 04-05-2015 12:53 PM
Selling our 2012 Flying Cloud 30' Sofa for 2015 Bunkhouse Hibby 2009-2015 Flying Cloud 12 03-15-2015 08:08 PM
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 07:43 AM
2015 Flying Cloud front lounge changes Endodoc 2009-2015 Flying Cloud 4 10-10-2014 06:11 AM
2010 Airstream Flying Cloud BRAND NEW!!!!! S2010 Airstream Flying Cloud BRAND NEW!! eBay Watch Airstreams on eBay 0 11-03-2010 03:50 PM
