Old 02-08-2016, 08:51 AM   #1345
Long Island , New York
Where there is a will, there is a way!
So, does the entire silver face of the vent rotate as you adjust it? And is the center axle (which can you can see in the photo) the only thing holding the plastic base with tabs to the silver adjustable vents and trim flange?
Why not (if my assumptions are correct):
-- drill out the axle (is that a riveted connection I see?)
-- attach the two parts (silver and plastic) to each other with nut and bolt
-- detach two pieces
-- screw plastic sub-flange to the ceiling
-- attach silver face to plastic base with nut and bolt
[nut may have to be adhered to back of plastic somehow?]
-- or could you get one of those rivets which have internal machine threads, and rivet it to the plastic base, to receive the bolt from below?
Yeah! I am liking the way this is headed. Are we pointed in a workable direction do you think?
Peter
PS -- Or how about this Fred Flintstone approach -- wrap 1-3 layers of aluminum foil over/around each plastic tab sticking up, and jam the whole thing up into the opening?
Yabba Dabba Doo !!! ???
Old 02-08-2016, 09:04 AM   #1346
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
This lack of attention to the curvature design of the ceiling versus a flat fixture being attached is not new.
Our 2014 Classic had the Fluorescent light fixtures installed cross frame. The are screwed tight to the ceiling even though they were designed for under a flat bottom a cabinet. This put a slight bend to the fixture the put pressure on the center of the plastic lens at each end. All of ours cracked.
I got the dealer to provide me with new ones. They wanted to install them and I said they were incapable of doing the job properly. I took them home and sanded a slight radius in each lenses edge on both ends so the lens matched the space available. The center of the lens was now a little shorted than the bottom length of the lens next to the ceiling.
Putting a 5" hole through a skin joint is just poor planning with this attachment design.
The only true fix is a new attachment plate cast with the ceiling radius and a slightly longer round shoulder to move the rotating louvers slightly farther away from the ceiling so it could remain flat.
Putting a doubler circle plate inside the opening would allow for screws to hold the fixture in place.
Old 02-08-2016, 09:42 AM   #1347
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Gorilla glue or 2-sided tape, the red backed variety used to attach the trim on GM pickups....seriously. I use both of these items often in my trailer.
Jay
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, '11 Touareg TDI
Santana tandem bike
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 02-08-2016, 10:19 AM   #1348
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Jay
This is worth a try, but as someone said earlier, poor design to begin with. They need to be confronted about this one. How do you get to a sr. mgr. at AS and make them aware of this type issue? I was seriously looking at upgrading to a 2016 or 2017, 27' FC later this year because of the ducting primarily, but now I will wait for a fix...
Old 02-08-2016, 02:01 PM   #1349
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Peter
Thank you, Peter. I think that this could be a permanent fix for this issue.
Brian
SuEllyn & Brian McCabe
Old 02-08-2016, 02:14 PM   #1350
moosetags's Avatar
I have had email contact with the Service Center and Customer Technical Support at Jackson Center, and have made them aware of this issue. Neither could offer any solution. I have had a much better response from the membership here on AirForums than the factory has provided.
I surely am not the only one who has contacted them about this issue. They seem to have the ostrich attitude of just sticking their head in the sand and hoping that it will go away.
Brian
Old 02-08-2016, 04:19 PM   #1351
gypsydad's Avatar
Brian
Yea, sounds like the same early response they had to the "oil canning" issue with the newer models when you shift weight in the kitchen area..."oh, your the first person who has mentioned this!" Yea, right....was the Forum where the quick solution was found....
Wonder if Patrick at Colonial knows who to call there at the factory to get some more attention? Seems the king of the dealers should get some ones ear? But, that just may be me trying to be logical...
Old 02-08-2016, 05:23 PM   #1352
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Brian, having a 2016 with the adjustable vents & no problems, I'm wondering if the early 2015 models were not as precise with the hole cuts for the air vents causing your change out not to fit correctly.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 02-08-2016, 06:15 PM   #1353
Seattle , USA
Take the vent out, put a little dab of clear RTV on each tab, put vent back in roof. Never worry about them falling again.
This works.
RareStream is offline   Reply With Quote
Old 02-08-2016, 07:25 PM   #1354
moosetags's Avatar
This works.
I like this idea as it will not require any modifications to the vent. If I did this, how difficult would it be to remove the vent unit, if necessary?
Brian
Old 02-08-2016, 08:07 PM   #1355
Seattle , USA
Moderately easy. The clear RTV is very robust yet easy removed by rolling it. But, it hardly lets go on its own. It was a common trick back in the day to use a dab to keep your hubcaps on yet they were easily removeable.
Just put a dab on two or three tabs...the vents will stay on their own but you can pop them out easily by spinning them first to break the RTV seal.
Old 02-08-2016, 09:15 PM   #1356
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
Now that sounds like an excellent first choice!
DoublTrouble is offline   Reply With Quote
Old 02-09-2016, 09:43 AM   #1357
Atlantic Beach , Florida
Very Timely! Have an appointment on Monday to install new revolving vents in our 2015 FC FB twin. I will have a tube of RTV with me.
We will also have all the trim on clearance lights, tail lights and scare lights warranty replaced since plastic chrome has turned dark brown.
When in Hilton Head over Thanksgiving holiday we were camped next to two Airstream.
A young couple came by and were excited to see us and said they had an Airstream on the other side of the campground.
Just happened to be the General manger of Airstream Jackson Center making their way to the RV Trade show in Louisville.
He may be a great contact for some of these issues. He was taken aback by the light trim.
I'll bet there is a market for Stainless trim for our Airstream!
Fred
fpbender is offline   Reply With Quote
Old 02-09-2016, 10:31 AM   #1358
moosetags's Avatar
This morning I hit Wal-Mart early and picked up a tube of Clear RTV Silicone. I will first try it on the vents that have fallen most often. These are mainly inthe living room and bath. The vents in the bedroom have never fallen.
Where do you think that I will do the most good with the silicone? It has been suggested that I put it on the little plastic tabs. I am concerned that since these rub against the sharp aluminum edge of the hole when being inserted that the silicone will peel right off.
Brian
2015 Flying Cloud woof 2009-2015 Flying Cloud 13 04-05-2015 01:53 PM
Selling our 2012 Flying Cloud 30' Sofa for 2015 Bunkhouse Hibby 2009-2015 Flying Cloud 12 03-15-2015 09:08 PM
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 08:43 AM
2015 Flying Cloud front lounge changes Endodoc 2009-2015 Flying Cloud 4 10-10-2014 07:11 AM
2010 Airstream Flying Cloud BRAND NEW!!!!! S2010 Airstream Flying Cloud BRAND NEW!! eBay Watch Airstreams on eBay 0 11-03-2010 04:50 PM
