Old 01-03-2016, 10:50 AM   #1289
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I have found the folks at Centramatic to be helpful. Explain to them what you have, and they will recommend the best balancer.
We had Centramatics on our 2005 Safari 25FB. We left them on Old Lucy as we were trading for a 23FB. We would have kept them to reuse if we had any idea that we would eventually go back to a 25FB..
Brian
SuEllyn & Brian McCabe
Old 01-03-2016, 11:15 AM   #1290
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Originally Posted by moosetags View Post
That's correct, Doug. They just slip over the lug nuts, and you mount the wheel.
We got them directly from Centramatic in Texas. Give them a call. They are very helpful and will set you up with the correct model balancer.
Brian
Originally Posted by switz View Post
Since the three sizes of Centramatics are the same price of $199 per set, I would suggest that if installing the 16" wheel upgrade one should order the ones designed with a larger diameter for those wheels.
Centramatic Part Numbers for Airstream use:
14" 5 bolt pattern #200-221 standard part
15" 6 bolt pattern #200-221 Special
16" 6 bolt pattern #300-356 all A plates
Brian
Thanks for the info here folks. I will call them on Monday and see what we can get happening.
Cheers
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 01-03-2016, 11:57 AM   #1291
moosetags's Avatar
We have now replaced New Lucy's living room Samsung 28" television. We have installed a 28" Vizio Smart TV. We wanted to be able to access Amazon Prime Video and Netflix directly without any hocus pocus.
We have now tested the connection using SuEllyn's Verizon cell phone wifi hotspot. It works flawlessly without any buffering or interruption. We think that this will work for us on the road.
Brian
Old 01-03-2016, 03:10 PM   #1292
Arcticfox's Avatar
Central , Canada
That's interesting Brian. It never occurred to me that changing out the TV would eliminate the need to something like an Apple TV, to access things like Netflix. Sows how much I know about these so called smart TV's..... lol
Old 01-03-2016, 03:37 PM   #1293
moosetags's Avatar
New Lucy came off the line in May of 2015. Her OEM television is probably from 2013. The smaller size smart TV's are only of the last year or so. These TV's have their own Wifi and can directly connect to the Internet and access about 20 different channels and functions directly from the Internet.
Brian
Old 01-03-2016, 03:54 PM   #1294
Arcticfox's Avatar
Central , Canada
Brian
Cool Brian, I will have to look into this. We generate our own WIFI network (Apple airport express) while on the road. We have a network printer we use often to print bills and online payments to maintain hard copies of everything.
Other than that we have a ATT MIFI that we use to access the internet with on our phones and iPad's. I was going to add an Apple TV to allow us to access Netflix on the Tv, but it might make more sense to just get a smart TV and be done with it.
Thanks again
Doug
Old 01-03-2016, 03:56 PM   #1295
Flht2k's Avatar
sacramento , California
All Samsung smart tv's have own WiFi
Flht2k is offline   Reply With Quote
Old 01-04-2016, 07:29 AM   #1296
moosetags's Avatar
I would have preferred to stay with a Samsung for Lucy. I went with the Vizio because I could find a Samsung Smart TV in the 28" size that I needed.
Going to a Vizio also has another benefit. When Lucy had the two Samsung televisions, we would often experience the problem of the wrong TV picking up the remote control signal. Many times, the bedroom TV would turn on while trying to turn on only the living room television.
Brian
Old 01-04-2016, 07:33 AM   #1297
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
When the the TV is connected to the internet, your privacy is over. We installed a large Sony that would accept "verbal" commands so it is "listening" all the time. The infrared eye to receive signals is watching all the time. Our TV is not directly connected to the internet.
Ah, yes, George Orwell predicted this pretty well in his book he wrote about Burma named "1984"........ Big brother is listening and watching those morning exercises.
Old 01-04-2016, 10:32 AM   #1298
AStreamNerds's Avatar
Manassas , Virginia
Thanks again
Doug
Adding an AppleTV also give you the advantage of using Airplay from other Apple devices such as iPhone and iPad for displaying content (pictures, videos, or even mirror the image) easily from them to your TV's. For more information you can go to video below. If you fast forward towards end you can see it working. If you regularly use an iPad or iPhone this is a cheap and great addition to your AS.
AStreamNerds is offline   Reply With Quote
Old 01-05-2016, 06:59 AM   #1299
moosetags's Avatar
We looked at add-on devices like the Apple TV and others. We like the Smart TV concept because it's all internal without any extra boxes, cords, and remotes.
Brian
Old 01-05-2016, 07:34 AM   #1300
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Hopefully with the newer TVs they have put better processors in them as they were painfully slow even with speedy internet. I prefer connecting a device for these features and have chosen the Apple TV. If something better comes all you need to do is upgrade the device and not the TV.
I guess all of you that want to watch Netflix on the road must have unlimited data plans. I can't see campground and public WIFI working well for streaming Netflix.
Kelvin
Old 01-05-2016, 07:42 AM   #1301
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Kelvin
Moosetags, Kevin's "guess" was actually my question. We have WiFi we use for bills etc running of a Samsung Tablet, but it is on the same data plan as both our phones, so it's limited. I am guessing if one runs the Smart TV off the Verizon WiFi we have our monthly data would be used up pretty quickly? Which is why we carry a portable Direct Sat antenna and Direct Box
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 01-05-2016, 02:59 PM   #1302
moosetags's Avatar
We do have unlimited data on our Verizon plan.
Brian
2015 Flying Cloud woof 2009-2015 Flying Cloud 13 04-05-2015 12:53 PM
Selling our 2012 Flying Cloud 30' Sofa for 2015 Bunkhouse Hibby 2009-2015 Flying Cloud 12 03-15-2015 08:08 PM
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 07:43 AM
2015 Flying Cloud front lounge changes Endodoc 2009-2015 Flying Cloud 4 10-10-2014 06:11 AM
2010 Airstream Flying Cloud BRAND NEW!!!!! S2010 Airstream Flying Cloud BRAND NEW!! eBay Watch Airstreams on eBay 0 11-03-2010 03:50 PM
