Old 12-29-2015, 04:18 PM   #1261
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Originally Posted by Mrjkq View Post
That's a pretty impressive performance. You didn't mention any tire issues so I presume their were non. We're doing that big trip starting in May 16', Florida up to Buffalo for grandsons HS then on to Las Vegas & Palo Alto, Ca., visiting our children and grandchildren. I hope we share your success with a near flawless trip.
Hi Joe,
We didn't have any tire issues with New Lucy. When she was brand new, we replaced the OEM Marathons with Michelin 16" LT's.
When we had Old Lucy (the 2005 Safari) she gave us fits with her Marathons. We ultimately got her s set of 16" Michelins. After that, we towed her another 60,000 miles without a single tire issue. When we got New Lucy, she immediately got a set of Michelin LT's.
Brian
SuEllyn & Brian McCabe
Old 12-29-2015, 04:28 PM   #1262
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Brian, I've been giving that some thought after the many threads I read about the marathon malfunctions. What are the particulars of your Michelins, size load etc. also what did you do with the 15" rims & tires, especially the rims.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 12-29-2015, 05:50 PM   #1263
moosetags's Avatar
Hi Joe,
Most recently on New Lucy, I purchased five 16" Michelin LT's, premounted on 16" rims which we put on Lucy ourselves. See photos below.
We had only put about 500 miles on New Lucy's OEM Marathons. We sold them to another Forums member for $600. This meant that New Lucy's tire upgrade cost us right at $1,000.
The Michelin LT's that we got are the Michelin LTX M/S2 LT225/75R16E. Max load is 2680# at 80 psi. I run mine at 72 psi.
The wheels we got are the Sendel T03's with zero offset.
We also used a set of Centramatic Balancers as we had used on Old Lucy.
As you can see from the photos, SuEllyn mounted the tires and wheels while I provided moral support and took pictures.
Brian
ID:	254797   Click image for larger version
ID:	254799   Click image for larger version
Old 12-29-2015, 05:59 PM   #1264
Mrjkq's Avatar
Venice , Florida
Thank you....Joe
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
Old 12-29-2015, 06:58 PM   #1265
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Brian your one lucky guy to have such a good looking tire technician! I have never been that lucky.
We upgraded our 28' to the 16" Michelin LT's as well. I had about 2,000KM on the original tires and my tire dealer still took them in on trade. If I remembered right I think he allowed me 700 against the 1600.00 for the new tires and wheels.
Cheers
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 12-29-2015, 08:14 PM   #1266
moosetags's Avatar
Cheers
Doug
Hi Doug,
We were in the same ballpark on our tire upgrade deal. We added new Centramatics as we had had such good luck on Old Lucy's 16" Michelins. When we traded her in, those tires had 60,000 miles on them and show no appreciable tread wear.
Brian
Old 12-30-2015, 08:12 AM   #1267
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
As a point of interest, we had installed the Michelin LTX (P) 235/75R15 XL tires on the factory wheels on our 2013 25FB International Serenity early on from reading the forum. After we traded it in, the dealer in Mesa, Arizona replaced the Michelins with the stock GYM ST225/75R15D tires saying they could not sell it with non-trailer rated tires.
If I was a betting man, those Michelin tires were put on someone else's trailer on their lot....
Old 12-30-2015, 08:43 AM   #1268
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
Can you tell me were and what size are the Centramatic Balancers you got.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 12-30-2015, 08:50 AM   #1269
paiceman's Avatar
Upper St Clair , Pennsylvania
Thanks for the update. Our 2015 30' has performed well, EXCEPT for the gas furnace. Her cycle is start, blow out the chamber (normal) fire the burner and then burner goes off. This cycles 5-7 times. Everything has been replaced except the furnace gas valve and the sail switch. Even the bottle regulator was switched.
Postponing our trip south for several reasons including this furnace, going in Monday the 4th for a quick furnace valve replacement and sail switch. Fortunately, the service guys at our dealer do this under warranty without much testing on their part, just take my word for what is happening.
Yesterday I even checked every gas fitting just to make sure we were not sucking in air, everything was tight. I also always light the three burner stove prior to firing up the furnace. I let it run for a minute, turn the burners off and fire the furnace.
Other than the furnace we are pleased and think she's a keeper.
Happy New Year
Bud
SAFE TRAVELS
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 12-30-2015, 09:05 AM   #1270
switz's Avatar
2014 31' Classic
Images: 8
Centramatic Part Numbers for Airstream use:
14" 5 bolt pattern #200-221 standard part
15" 6 bolt pattern #200-221 Special
16" 6 bolt pattern #300-356 all A plates
Old 12-30-2015, 09:21 AM   #1271
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Can Centramatics be used on Airstreams with disc brakes?
Kelvin
Old 12-30-2015, 11:46 AM   #1272
Long Island , New York
Kelvin
Because they mount on the tire rim, why not?
Not sure if their site has an answer, but the videos are interesting, with the top right one being short and to the point:
Tire Balancers, Tire Balancing, Wheel Balancer and Wheel Balancing from Centramatic
Old 12-30-2015, 11:56 AM   #1273
moosetags's Avatar
Kelvin
I really don't know the answer to your specific question, but I am also running Centramatics on my 2011 Silverado and it has four wheel disc brakes.
Brian
Old 12-30-2015, 12:37 PM   #1274
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
I just put 1200 miles on our new Michelins and feel very secure with them. One note... At the end of each day I put the torque wrench to the lugs and always found a couple out of spec. However, with the stock lug nuts replaced with the stainless solid ones, the job is a lot easier.
We're back in AZ for the winter.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, '11 Touareg TDI
Santana tandem bike
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
2015 Flying Cloud woof 2009-2015 Flying Cloud 13 04-05-2015 01:53 PM
Selling our 2012 Flying Cloud 30' Sofa for 2015 Bunkhouse Hibby 2009-2015 Flying Cloud 12 03-15-2015 09:08 PM
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 08:43 AM
2015 Flying Cloud front lounge changes Endodoc 2009-2015 Flying Cloud 4 10-10-2014 07:11 AM
2010 Airstream Flying Cloud BRAND NEW!!!!! S2010 Airstream Flying Cloud BRAND NEW!! eBay Watch Airstreams on eBay 0 11-03-2010 04:50 PM
