Old 06-09-2015, 09:17 AM   #1065
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Originally Posted by Gene View Post
If the memory foam is just foam without a cloth cover, then you can cut the foam to any length you want so long as it is shorter. That way you don't have to special order something from an RV store. To make it longer, put in bathtub with enough water to partially cover it and make sure it gets some sun 12 hours per day; in a few weeks it should begin growing (whether it grows foam or something else, I don't know). An electric knife cuts foam easily I am told, but I just use a sharp knife long enough to cut all the way through.
Gene
We had to trim several inches along the entire length of Lucy's memory foam mattress toppers. We also had to cut a curve to follow the form of Lucy's corner. We were able to make these cuts with an old electric carving knife. This method cut the foam beautifully. It was easy to cut along both straight and curved lines. Lucy's toppers are the two sided type with a blue gel liner on one side, so they don't have any cover to deal with.
Brian
SuEllyn & Brian McCabe
Old 06-27-2015, 01:07 PM   #1066
moosetags's Avatar
Well, we just had new Lucy on the road for 16 days, and she was towed a little over 1,000 miles up into Alabama, Tennessee, and North Carolina.
We had a couple of 97 degree days, and her ducted air conditioner did very. All other systems performed well. We have noticed that unless you lock her awning support bar with two clicks on the door end, the door hits the awning material slightly.
We did find that if the air is running and you are using the microwave and coffee maker, it is best to use the LP gas water heater. We blew the campground circuit breaker a couple of times. It wasn't a big deal, but if you have to get dressed to go outside, it is kind of a pain.
We are now at 103 nights spent in New Lucy, and she is meeting all of our expectations.
Brian
Old 06-27-2015, 01:38 PM   #1067
2015 25' Flying Cloud
Apollo Beach , Florida
25' FC 2015 ducted air. I notice more air coming out of the bedroom, back, ducts than the front. I read somewhere there are directional vents for the ducts. Where can they be purchased? Thanks
Guyel is offline   Reply With Quote
Old 06-27-2015, 02:28 PM   #1068
moosetags's Avatar
We got Lucy's at Jackson Center, but you should be able to get them from any Airstream Dealer.
Brian
Old 06-28-2015, 06:45 AM   #1069
Atlantic Beach , Florida
Longest Trip To Date
We had a wonderful 2400 mile trip in our 25 FC FB.
Traveled from Florida to PA,VA and TN. Met with old friends(My 50th Class reunion) LOL and stayed at some fine locations. Before we purchased our Airstream I had a dream to camp at a very special area that I had fly fished numerous time That dream came True! Amazing.
fpbender is offline   Reply With Quote
Old 06-28-2015, 08:15 AM   #1070
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
You might look into the Truma AquaGo comfort instant on water heater. It only uses 12Vdc for the control circuit and runs on propane. Takes 50 pounds of stored hot water weight from the trailer and the second person still gets hot water.
Old 06-28-2015, 08:37 AM   #1071
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Brian
Brian- I also heard if you run the washer/dryer along with the vacuum while your "air, coffee, microwave and massage chair" are running, same thing happens! LoL! Tried to get a deal on new 2015 25' FC F Twin with the Gourmet Lounge kitchen upgrade from AS Adventures yesterday.... they wanted $13K for the upgrade alone and not much discount on the unit, even though the 16's are arriving...guess we will keep ours thru the summer at least...we leave for MT Tuesday...hope the traffic is not too bad. Happy trails....
Old 06-28-2015, 08:37 AM   #1072
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The standard 6 gallons of hot water is more than enough for two people to shower, based on hundreds of showers we have taken in our Airstream. Powered with 120 vac electric or propane or both, also gives an extra 6 gallons of water storage for boon docking.
Doug and Cheryl
Old 06-28-2015, 08:44 AM   #1073
chaseav's Avatar
2015 25' FB International
Stumbled across this thread again and what a dynamic one it is! Does anyone know the amp draw of the factory installed (Dometic) hot water heater when it's on electric mode? I've blown the breaker twice now but I was always using something else too.
chaseav is offline   Reply With Quote
Old 06-28-2015, 09:43 PM   #1074
moosetags's Avatar
New Lucy's Atwood gas/electric water heater has 12 amp draw while running on electric. Old Lucy had a gas only water. Never had any breakers trip.
Brian
Old 06-28-2015, 09:55 PM   #1075
chaseav's Avatar
I meant to put a question mark after (Dometic). Atwood is more like it! If just 12 amp, something else must have been on too. How about microwave and AC draw? It has been raining like mad here too (hope this Airstream floats!) so maybe there is something else afoot.
Old 06-28-2015, 10:26 PM   #1076
moosetags's Avatar
A Dometic 15,000 btu a/c unit draws 13 amps. The microwave varies.
Brian
Old 06-29-2015, 06:33 PM   #1077
2015 FC Twin. Any suggestions on how to keep from sliding off the synthetic leather cushions. Maybe should have gotten the cloth material??
Old 06-29-2015, 10:14 PM   #1078
Flht2k's Avatar
sacramento , California
Velcro
Flht2k is offline   Reply With Quote
2015 Flying Cloud woof 2009-2015 Flying Cloud 13 04-05-2015 01:53 PM
Selling our 2012 Flying Cloud 30' Sofa for 2015 Bunkhouse Hibby 2009-2015 Flying Cloud 12 03-15-2015 09:08 PM
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 08:43 AM
2015 Flying Cloud front lounge changes Endodoc 2009-2015 Flying Cloud 4 10-10-2014 07:11 AM
2010 Airstream Flying Cloud BRAND NEW!!!!! S2010 Airstream Flying Cloud BRAND NEW!! eBay Watch Airstreams on eBay 0 11-03-2010 04:50 PM
