Old 05-30-2015, 04:52 AM   #1037
chaseav's Avatar
2015 25' FB International
Originally Posted by moosetags View Post
When Lucy was just at the Service Center in Jackson Center they put rubber washers under her water pump. It is now a lot quieter than it was.
Brian
Just happened across this comment. I used my water pump for the first time yesterday. Yeeeeow that thing is loud! I have no doubt that it is located under our coat closet in the 25fb... how is it accessed though? Something has to happen there. I sounds like it's sitting on bare metal and just as loud as can be.
chaseav is offline   Reply With Quote
Old 05-30-2015, 04:59 AM   #1038
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
That panel will open like a cabinet door.
2012 Dodge Durango Hemi/AWD
Old 05-30-2015, 09:09 AM   #1039
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Open the wardrobe door. Take a small screw driver and stick it behind the panel below that has the furnace vent in it. Pop open the door. It is hinged on the left. You'll see the water pump about a foot in.
Brian
SuEllyn & Brian McCabe
Old 05-30-2015, 09:28 AM   #1040
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
My pump is also a little load. But yet when I put my hand on it (while running) it does not seem to be as big an issue as the hose lines. When I hold the hose lines the sound gets dramatically better. I'm assuming my hoes must be touching a cabinet or something but cannot really see in there well enough to confirm. Has anyone got any idea on how to isolate the hoses a little better?
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 05-30-2015, 10:42 AM   #1041
Wayne&Sam's Avatar
Images: 21
I've put foam pipe insulation on the hoses where they contact something. I did it at the same time I did other things so I don't know how it helped. But it couldn't hurt.
Old 05-30-2015, 11:18 AM   #1042
Arcticfox's Avatar
Central , Canada
Thanks I'll give it a try....
Old 05-30-2015, 12:42 PM   #1043
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
Doug
Go to your local hardware store and buy a 20" faucet hose it will have 2 female ends ,install it between the pump and pex tubing. This will allow for rapid expansion of the water when pump is turned on
Gary
Castaway is offline   Reply With Quote
Old 05-30-2015, 09:10 PM   #1044
moosetags's Avatar
Gary
I'm going to have to try that trick.
Brian
Old 06-03-2015, 12:01 PM   #1045
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
The door under the wardrobe can be difficult to open though I've never tried Brian's screwdriver trick. I'd be afraid of damaging the Formica glued to the door. I pull on the bottom of the door with as many finger tips as I can and it eventually opens. There's a heat vent in the door and that assembly makes it hard to open the door all that far, but there's enough room for access to the pump. You can install a small tank in the plumbing line to reduce noise, but the idea of a longer flexible pipe probably does the same thing.
Not all Airstreams have the pump in this location, but a lot do. Ours was installed backwards so the filter was at the back and inaccessible, but they turned it around at the Airstream service center at no charge. I installed a kit in the line to more easily pump antifreeze into the system when winterizing.
Gene
Gene
Old 06-04-2015, 07:09 AM   #1046
moosetags's Avatar
I have always opened this compartment with a screw driver or pocket knife blade. If you open the wardrobe door and pry the lower compartment door from the top right corner, it opens without any damage to the door. I have considered putting a knob on this access door on Old Lucy, but never got around to it.
Brian
Old 06-04-2015, 08:58 AM   #1047
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Name:	ImageUploadedByAirstream Forums1433429800.134207.jpg
ID:	239961Click image for larger version
Name:	ImageUploadedByAirstream Forums1433429822.031816.jpg
Mine opens quite easily by grabbing it at the bottom.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 06-04-2015, 09:02 AM   #1048
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I put pipe insulation around some of my plumbing around the water pump. Several pipes were in contact with each other and with drain pipes which vibrated against. It seemed to knock down some of the vibration noise.
Kelvin
Old 06-04-2015, 09:05 AM   #1049
moosetags's Avatar
Thanks for the pictures, Jay. That makes it crystal clear.
Brian
Old 06-04-2015, 06:33 PM   #1050
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Hi Doug,
The water pump in my Sig is usually whisper quiet. However, the one in my Safari caused the pipes to rattle somewhere and I could not fix it so I minimized the length of time it made a racket by installing a 1 gal residential accumulator tank from Home Depot. I stuffed it up under the sink and it really resolved the stress from the noise since the pump ran so infrequently. Never at night but occasionally during the day. 1 gallon is a fair bit of water in an Airstream. I suppose it ran when I was in the shower but with all the banging around I couldn't hear it. By the way, I just went through your neck of the woods but stayed at the Walmart in North Battleford which was a days drive for me from Winnipeg. Jim
Jim Flower is offline   Reply With Quote
2015 Flying Cloud woof 2009-2015 Flying Cloud 13 04-05-2015 12:53 PM
Selling our 2012 Flying Cloud 30' Sofa for 2015 Bunkhouse Hibby 2009-2015 Flying Cloud 12 03-15-2015 08:08 PM
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 07:43 AM
2015 Flying Cloud front lounge changes Endodoc 2009-2015 Flying Cloud 4 10-10-2014 06:11 AM
2010 Airstream Flying Cloud BRAND NEW!!!!! S2010 Airstream Flying Cloud BRAND NEW!! eBay Watch Airstreams on eBay 0 11-03-2010 03:50 PM
