Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Flying Cloud > 2009-2015 Flying Cloud
Old 01-09-2016, 12:18 PM   #1321
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Along the same line, get two two twin mattresses and put them together. Then use a 2 or 3 inch memory foam king suze topper. Voila! King size bed.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 01-17-2016, 03:54 PM   #1322
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Whether you like or dislike the east/west queen bed is a matter of whether you can easily crawl over your partner. I can't because of numerous bad joints and injuries, Barb can, but as we age crawling gets more of a challenge. But I do like being crawled over when Barb does it. If I were going to buy another one, the 27" with the north/south bed would be a solution. I was supposed to win the $1.5 B Powerball, but something went wrong with the machine and I didn't. I was going to buy a new truck, a 27' and a few politicians.
Since we are used to a king bed at home, a double bed would feel much too small. The queen is ok. If you want a larger bed, foam is the way to go to get it in the door and around the corners. We've carried a king mattress that was not foam up and down some narrow, twisting stairs—it isn't easy and you have to force it and bend it, but we did it. Not sure we could get it in an Airstream, but they used to have a model with a king bed—maybe a 30' or up. Maybe it was foam, maybe it had springs. The very uncomfortable bed that came with the trailer would not be easy to remove—much too firm and probably hard to bend. We solved it with a foam top which by now is getting old and may need replacement.
Gene
Gene
Old 01-17-2016, 05:08 PM   #1323
moosetags's Avatar
You sure have been quiet, Gene. Has the Internet been off in Colorado? Just to let you know, we didn't win the Power Ball either.
Brian
Old 01-19-2016, 11:30 AM   #1324
Master of Universe
Gene's Avatar
Brian
Brian, the holidays seemed to dominate, then there's catching up on reading, getting a cold after New Year's, travel to in-laws for Christmas and being lazy and sleeping late. I've thought of posting, but managed to forget to. If we had won Powerball, I'd have servants doing the posting. I've also been researching power tools, a far more pleasant time than actually doing the work. Do not fret, even backward western Colorado still has internet, slow and expensive, but internet all the same.
Gene
Gene
Old 02-07-2016, 09:14 AM   #1325
moosetags's Avatar
New Lucy continues to suffer from the problem of of randomly dropping her adjustable air conditioning vents from the ceiling. This has been a chronic issue since the new vents were installed in Jackson Center last April.
We have since been adding pieces of tape to the vent tabs. This has help somewhat, but has not solved the problem.
I emailed Chris Burch at the Service Center in Jackson Center. He responded that he did not know of a fix for this issue. He suggested that I contact Airstream Customer Support for a possible solution.
I did this and got a response from Dan Snider, Senior Technical Support Representative, at the Airstream Factory. The only fix that he was able to suggest was to try bending out the little plastic tabs on the vents. I advised him that the first thing I did was bending the tabs out, and that it didn't seem to help at all. I advised him of this, and he did not have any further suggestions.
I am now looking for any and all suggestions as to how to correct this problem.
Brian
Old 02-07-2016, 09:25 AM   #1326
DoublTrouble's Avatar
2017 25' International
Carlsbad , California
Brian,
I am not sure how tightly yours fit. Mine are so tight that I look at them and wonder if they're in all the way sometimes. Have you tried some duct tape around the edge of the hole, small pieces that won't extend beyond the flange of the vent cover, to "shim" the diameter of the hole a bit. Just thinking out loud here...
DoublTrouble is offline   Reply With Quote
Old 02-07-2016, 09:30 AM   #1327
moosetags's Avatar
Originally Posted by DoublTrouble View Post
Brian,
That's an excellent suggestion. I will try that next. Thank you.
Brian
Old 02-07-2016, 09:33 AM   #1328
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Brian, is there evidence of anything else getting tossed around back there. Could there be a problem with excessive tire pressure or running gear balance, are the Centramatics working well or is there a major tire imbalance. Is there some flexibility in the hitch connection.
That being well, I wonder if there some way to spring-loaded clips could be added to the vents similar to the ceiling light fastening system.
Doug and Cheryl
Old 02-07-2016, 09:48 AM   #1329
moosetags's Avatar
Hi Doug,
There doesn't seem to be any evidence of unusual jostling while underway. Everything in New Lucy seems to ride as well as ever in any of the three Lucys. There does not seem to be any major imbalance.
We have had vents fall and wake us in the middle of the night while camped. These times were obviously not caused by any bumping while heading down the road.
I am not seeing any way to add spring-loaded clips to the vents. The OEM screen vents did have metal spring clip that held the vents in. They were so strong that it was quite difficult to remove these vents from the ceiling.
Brian
Old 02-07-2016, 10:00 AM   #1330
Sag Harbor , New York
The construction project manager in me feels that there must be a solution, but I haven't read this entire thread yet. Have you described the geometry of the ducts in an earlier post? Surface mounted, size of opening for supply duct, and so forth . . .
I am on the road now, but will read the pertinent posts here later.
Thank you for any guidance which might help,
Peter
Old 02-07-2016, 10:18 AM   #1331
moosetags's Avatar
Peter
Thanks for your interest, Peter. As this thread has over a thousand posts and addresses all aspects of the 25FB, I am posting a couple of pictures of one of the errant vents and the hole in New Lucy's ceiling that it goes into.
Brian
ID:	256949   Click image for larger version
Old 02-07-2016, 11:56 AM   #1332
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Southeast , Michigan
Images: 41
Falling vents is a common problem with the new 2016 ducted air directional vent design, even for us that got a 2016 with them as original equipment. We have had all of ours replaced under warranty and that did not really help. And yes, they tend to fall out when not moving, so road vibration is not the main issue. Thermal expansion and contraction of the metal inner skin vs. the plastic vent body may be the more significant factor, because the tab grip area is very small and aluminum likely expands or contracts more than the plastic used on the tabs.
I see the directional vent design as being flawed. The locking tabs on the vents have several very small steps along a ramp profile on the tabs that provides very minimal surface area on each tab to lock in place. The steps are so small that thermal contraction of the inner skin may be enough cause the vents to fall out. I assume these small steps were provided to allow the vents to be easily removed, but then once removed, the ramp steps are likely damaged and will not hold as well the next time they are inserted. If you were to cut off the ramped steps and thus make the surface area of the latch larger (e.g. one big flat area), they might lock into place better, but might become impossible to remove without totally mangling the vent.
Another issue is that the vents are are designed flat but are being mounted into a ceiling contour that is not flat. This means the vent may need to be warped to get all tabs long the perimeter to grab. or some tabs may not grab at all. Also, I believe that in at least some locations on our trailer, at least part of the vent opening is cut into overlapped interior skin sections which may make it impossible for some tabs to grab at all where there are two layers, because the steps cannot accommodate metal that thick.
I would also love to see the design drawings showing the tab dimensions compared to the hole opening dimensions. If the design dimensions of these two parts were not correct, you might have a loose fit by design. Then I would love to see a study of the actual vent tab and hole dimensions in production compared to the design dimensions. If the holes are coming out larger than design, or the tabs are coming out smaller than design, this could also lead to a loose fit, but that would be a quality control issue. Proper engineering and quality control at a major automaker would be on top of all these details. I wonder if Airstream is as thorough?
Finally, when you look at the directional vents as compared to the open screen vents, they restrict the airflow greatly. I would guess that the total opening area of each vent was reduced by greater than 75% in the fully open position as compared to the open screen design used in 2015. This probably makes the Airstream conditioner fan work much harder trying to push the air out and it likely significantly reduces the overall cooling ability of the Air Conditioner. Because of this, we have considered replacing some of the original directional vents that come on our 2016 with the open screen design used on the 2015's, but we have not done this yet. We wouldn't want to replace them all, because there is value to being able to direct air flow for at least some of them. Anybody have a few open screen vents they don't want?
In the end, I think adding tape to the vent tabs of circular opening in the roof is merely a band-aid that may buy a little time before the next time they fall out. I think there the best solution would the a total redesign of the directional vents that would have a better tab design, or maybe metal tabs, or might even require them to be screwed in place. Of course Airstream probably wouldn't want to consider screwing the vents in place because it would slow down production vs. the current "snap in place" design.
Maybe there is an aftermarket opportunity for someone here to design a better mouse trap (i.e. a better directional vent that solves both the retention and airflow issues), but I don't have that desire myself. I will keep paying attention, though, in case someone else develops a robust solution.
Joe
WBCCI/VAC #702 & #6768
66Overlander is offline   Reply With Quote
Old 02-07-2016, 12:02 PM   #1333
moosetags's Avatar
I just measured the vent holes in Lucy's ceiling. They are exactly 5" in diameter.
Brian
Old 02-07-2016, 12:09 PM   #1334
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
2015 Flying Cloud 25FB
How about a dab of silicone on the plastic? I not talking gobs. It looks like there's a half inch landing to put it on. I know we're anti silicone but it would be hidden by the directional cover and would hold good enough.
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
Bigventure is offline   Reply With Quote
Old 02-07-2016, 12:14 PM   #1335
1962 22' Safari
2016 30' Classic
Images: 41
Brian
Hi Brian,
I don't mean to be nit-picky, but as a retired engineer details matter. Did you measure all the holes (i.e. they might not all be the same) in multiple directions (i.e. they might be oval and not round)? And did you measure with calipers (i.e. not just an eye ball measurement with a simple tape measure)?
The locking tab surfaces on the vents are so small that a 1/32" variation on hole size might have a significant impact on retention. I don't have any vents to look at right now, but from memory I'd estimate the depth of the steps on the locking tabs to be 1/32" or less, which could make very small hole diameter differences very important.
But of course, I don't know what the correct hole size was even meant to be. A exact 5.00" sounds likely, but without the part drawing we cannot be sure. And getting a measurement on the vent tabs is even harder.
Joe
Old 02-07-2016, 12:36 PM   #1336
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Not a solution to keep the vent cover in place, but if there's a way to connect it to some fishing line somewhere in the ceiling - at least if it pops out it won't hit the floor and wake you up. I know it's not what you're looking for but I'd start there since a redesign seems like the longer term answer. Good luck!!
Old 02-07-2016, 12:51 PM   #1337
Thanks for the photos Brian.
I agree with Joe and others that the tabs that go up into the duct supply hole have ridiculously small plastic steps on them, and that thermal movement (and vibration IMO) are the cause of the problem. And ditto on the precision of the "round" hole in the inner aluminum skin being a factor.
This is basically a bad design.
When the design engineers try to hide attaching systems like this, they usually make things worse! Have you ever tried to remove the small LED ceiling light fixtures with those weird little spring-loaded clips holding them in? I dare you to get it right the first time, without bending/creasing the inner ceiling skin!
I would bite the bullet and use stainless steel truss head allen sheet metal screws through the surface flange of each vent -- at least 4 per vent because you won't be able to tighten them much with stripping the ceiling aluminum skin. A dap of silicon as you seat each one wouldn't hurt (hidden behind the surface flange).
Is this inelegant? Yes, but it is an improvement IMO. Other than a total redesign -- with some "framing" behind the edge of the aluminum skin's "rough opening"-- and with a well-thought-out hinge/catch/release system for removing the vent for cleaning etc. -- the inelegance of the surface screws, if done neatly, could actually look pretty cool.
And it lets you move on and leave this issue behind.
Try one in the least visible location maybe for looks, and see what you think? Again, be careful tightening the screws to avoid stripping the ceiling aluminum skin.
Good luck,
Peter
PS -- I spec'd SS truss head screws with an allen head because they don't stick up much. Jamestown Distributors out of RI used to carry them, but there are probably many other suppliers on the Net. A box of 100 should not run you over $25 incl. shipping IMO, although I last bought them in the 1990's! An alternative would be regular SS Phillips head sheet metal screws which are sold all over.
PS2 -- In the meantime, you could add 3-4 Z-clips at each location from thin scrap aluminum -- about 1/2" wide and about 3" long. Hard to describe maybe:
-- (for each one of the 3-4 clips per opening) stick about 1" of the 3" length behind the ceiling hole lying flat against the back of the ceiling skin
-- bend the remaining 2" of length 180 degrees so it lies flat on the bottom of the ceiling (the inside of the trailer)
-- put vent up, and bend Z-clips back over the surface flange of the vent.
Also inelegant, but they won't fall down for now.
Old 02-07-2016, 01:12 PM   #1338
moosetags's Avatar
Thanks for all the interest and suggestions. I did measure three of the holes and each was right at 5" in diameter.
I did consider screwing the the vents to the ceiling and be done with it, but there is a problems with doing this. If I did this, the vents would no longer be adjustable as to direction and opening and and closing off.
I have also considered adding some kind of mild adhesive to the flange. I haven't tried this yet.
I agree that Airstream could have done a much better job of designing and executing this feature.
Brian
Old 02-07-2016, 01:19 PM   #1339
Tn Traveler's Avatar
2006 25' Safari
Signal Mountain , Tennessee
This vent cover falling problem sounds as if it could be wide spread. Airstream is a quality trailer. It seems to me they should put a team of product engineers working diligently to solve this problem. Then issue a recall to bring the trailers in for the fix. It's hard to imagine that there is so little factory help with this. Is there something missing here?
Don
'06 Safari 25 LS
'18 GMC 2500HD Duramax/Allison
TN,”Greenest State in the Land of the Free”.Davy Crocket
" America is not a place;it's a road." Mark Twain
Tn Traveler is offline   Reply With Quote
Old 02-07-2016, 01:42 PM   #1340
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Ours is a 2016, and we haven't had this problem with the vent covers falling out, at least not yet. This is the first I have heard of it actually. I can see how bending the plastic tabs wouldn't work, but I wonder if you could glue a strong piece of small metal wire, like part of the right sized paper clip, at least half way up on the tab so that it would permanently hold the tab out a little bit?
If this ever happens to mine, I may try something like that on two or four opposing tabs to see if it would work.
Or maybe wrap some wire all the way around the vent through the tabs in such a way that it would hold them out a little bit?
Just some initial thoughts.
SeaLevel is offline   Reply With Quote
2015 Flying Cloud woof 2009-2015 Flying Cloud 13 04-05-2015 12:53 PM
Selling our 2012 Flying Cloud 30' Sofa for 2015 Bunkhouse Hibby 2009-2015 Flying Cloud 12 03-15-2015 08:08 PM
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 07:43 AM
2015 Flying Cloud front lounge changes Endodoc 2009-2015 Flying Cloud 4 10-10-2014 06:11 AM
2010 Airstream Flying Cloud BRAND NEW!!!!! S2010 Airstream Flying Cloud BRAND NEW!! eBay Watch Airstreams on eBay 0 11-03-2010 03:50 PM
