Old 01-31-2015, 04:11 PM   #491
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Brian, man Pentek has a lot of filters. Does your filter attach to some John Guest fittings, so it is easy in and out and are they easily found? Jim
Jim Flower is offline   Reply With Quote
Old 01-31-2015, 04:55 PM   #492
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I'll go out to Lucy and dig out the winterizing replacement pipe and take a picture of the fittings. All I have to do is find it.
Brian
SuEllyn & Brian McCabe
Old 01-31-2015, 04:58 PM   #493
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi moosetags, thanks for the photo of New Lucy all hooked up in her "slip" for the night. The sewer connection in that campground is exactly why we need a sewer solution. It appears it would be a challenge to drain the holding tanks with a gravity "slinky". My old 86 holding tank drain connection is often lower than the darn campground connection. And add the height of the 90 elbow that connects to the campground connection and the slinky is 6" off the ground.
And filtering campground water before entering the trailer makes perfect sense. The filter under the sink makes less sense. I removed the filter in the 86 as it was more difficult to perform the winterization and it was messy to change the element.
I'm surprised New Lucy's shore power connection is not on the street side. It looks like the power cord is running under the rear of the trailer.
New Lucy sure looks nice in your photo.
David
dbj216 is online now   Reply With Quote
Old 01-31-2015, 07:05 PM   #494
moosetags's Avatar
New Lucy has one of those new fancy 30 amp hook-ups at the front of the trailer.
Brian
Old 01-31-2015, 07:15 PM   #495
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
The problem I've had with CG water is sediment plugging up all the faucet aerators. So I use a sediment filter whenever I hook to city water and when I fill the tank. The kitchen sink filter also does taste and odor- but only on the cold water, not the hot. But that's OK, as the hot is only for washing, not cooking and drinking. When we're being very water aware and without city water, I'll fill a Brita filter pitcher for drinking and cooking, saving the on board water for everything else.
2012 Dodge Durango Hemi/AWD
Old 01-31-2015, 08:14 PM   #496
chaseav's Avatar
2015 25' FB International
What is that sewer connection adaptor in the picture? And are you parked at Disney's Fort Wilderness?
chaseav is offline   Reply With Quote
Old 01-31-2015, 08:32 PM   #497
moosetags's Avatar
That is Fort Wilderness and the sewer connection is standard Sewer Solution fare.
Brian
Old 01-31-2015, 10:28 PM   #498
chaseav's Avatar
I'm heading there next month. Are you in one of the Premium spots? Trying to go as cheaply as possible. (Sorry for being quite so off-topic)
Old 01-31-2015, 10:47 PM   #499
chaseav's Avatar
PS- I'm new to this and have never even dumped my black tank yet. However, having watched the Sewer Solution video now I went ahead and ordered it.
Old 02-01-2015, 05:42 AM   #500
Atlantic Beach , Florida
Brian,
Thanks for the info on the sewer solution.
I have watched the video and ordering today.
Do you have any difficulty back washing new Lucy's tank.
The video indicated some configurations may not backwash effectively.
Being a newbie, I was wondering, do most dump sites has fresh water available to use this system when departing the campground.
Fred
fpbender is offline   Reply With Quote
Old 02-01-2015, 06:14 AM   #501
chaseav's Avatar
Ooooooh. Good question. ^
Old 02-01-2015, 08:12 AM   #502
moosetags's Avatar
Originally Posted by fpbender View Post
Brian,
Fred
Newer Airstreams have a built-in sewer black tank rinse system. With this system there is no need to use the Sewer Solution's backwash function.
Brian
Old 02-01-2015, 03:09 PM   #503
Brian, Another question. Like when you were at Wilderness and hooked up do you keep black tank valve open all the time then just run water to rinse out the hose on departure or keep it closed and dump before departure?
Fred
Old 02-01-2015, 03:45 PM   #504
moosetags's Avatar
Fred
!!!!CAUTION CAUTION CAUTION!!!!
Never, ever, ever leave the black tank valve open other than when actually dumping the black tank. Leaving the valve open when set up at a campground will eventually result in what is called the "black hills syndrome". This is when solid waste is allowed to accumulate and dry out in the tank. It is very difficult, if not impossible, to remove. If not caught in time, this situation can cause a situation where the black tank may need to be replaced with a new one. This would be a very expensive proposition.
Brian
2015 Flying Cloud woof 2009-2015 Flying Cloud 13 04-05-2015 01:53 PM
Selling our 2012 Flying Cloud 30' Sofa for 2015 Bunkhouse Hibby 2009-2015 Flying Cloud 12 03-15-2015 09:08 PM
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 08:43 AM
2015 Flying Cloud front lounge changes Endodoc 2009-2015 Flying Cloud 4 10-10-2014 07:11 AM
2010 Airstream Flying Cloud BRAND NEW!!!!! S2010 Airstream Flying Cloud BRAND NEW!! eBay Watch Airstreams on eBay 0 11-03-2010 04:50 PM
