Old 03-31-2016, 05:44 PM   #1457
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
New Lucy is now sporting LED lighting around each of her street side windows.
Brian
ID:	259729   Click image for larger version
SuEllyn & Brian McCabe
Old 03-31-2016, 06:18 PM   #1458
blufishin's Avatar
Wilmington , North Carolina
Brian, Doug....I appreciate your input. We are 1 year into ownership of our first AS and have learned LOTS from the Forums.
Jere
Jere Freeman
2015 FC 25FB w/ Hensley
2017 GMC Denali HD 6.6L DuraMax
blufishin is offline   Reply With Quote
Old 03-31-2016, 06:21 PM   #1459
Long Island , New York
Also, a number of comments in various threads have indicated that the selection of available 15" Michelin tires is shrinking, due to the industry moving to 16" wheels in general. If you can find the 15" tire you want, with the correct load and speed ratings, go for it . . .
Originally Posted by blufishin View Post
We are considering upgrading to Michelin LTX. I have read many posts about going with 16" tires/wheels. Why not just put 15" Michelins on existing 15" wheels?
Originally Posted by moosetags View Post
The 15" Michelin LT's are in use by many here on the Forums. I have chosen to use the 16" Michelins because it is a 10 ply (load range E) tire with a significantly higher load rating.
Brian
Originally Posted by Arcticfox View Post
We made the same decision. It just made more sense to go with the higher ply and load rating.
Cheers
Doug
Old 04-01-2016, 03:38 AM   #1460
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
@blufishin
For those who want to learn and have a great time, plan on Alumalina next time....we are only a few hours down the road at Palmetto Cove RV Park near Cleveland, SC.
Join us next time....unless you are here already....
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 04-01-2016, 06:23 AM   #1461
blufishin's Avatar
Yes, we were there last fall. Had a great time, especially enjoyed the possum bog!
Jere Freeman
Old 04-01-2016, 08:46 AM   #1462
gpt
2014 25' FB Flying Cloud
sequim , Washington
moving to E rated tires is a waste of money. our trailers are simply not heavy enough to warrant tires of that rating.
gpt is offline   Reply With Quote
Old 04-01-2016, 09:27 AM   #1463
moosetags's Avatar
I don't like wasting money either, but my tire experience is such that the only money that I wasted was by not going to 16" Michelins E's sooner, rather than later.
Both of our 25FB's have weighed-in at +/- 7,400# ready to camp. The OEM Goodyear Marathon load range D tires on the 2005 Safari did not fare well. We had three catastrophic failures (blowouts) within the first 12,000 miles. We then moved up to load range E Maxxis ST tires. Over the following 25,000 miles, we did not experience any further blowouts, but these tires experienced tread separation which mandated their replacement. We again went with a set of the Maxxis E's. This time we got only about 10,000 miles before experiencing tread separation. At this point, we decided to throw in the towel, and went to 16" wheels and load range E Michelin LT's. We continued another 60,000 miles with the 2005 Safari without any tire issues whatsoever. As a matter of fact, the Michelins did not show any significant tread wear when we sold the trailer.
When we purchased our 2015 Flying Cloud 25FB in October of 2014, we immediately replaced the OEM wheels and tires. We again went with the 16" wheels and Michelin LT's. We have now covered over 20,000 miles with new Lucy without the slightest tire issue.
Brian
Old 04-01-2016, 09:40 AM   #1464
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We installed 15" Michelin LTX (P) 235/75R15 XL tires on the stock wheels of our 2013 25FB International Serenity and carried the 44 psi tire pressure recommended by Andy at CanAm. Loaded for camping the axles were supporting 5,800 pounds or 1,450 pounds per tire. The derated capacity of these tires is 1,983 pounds, so there was more than enough load margin and a softer ride for the trailer.
Note that this tire has it's maximum load capacity at 41 psi with a maximum side wall pressure of 50 psi. The 44 psi recommended by Andy adds some side wall stiffness and he told me this setting has worked on thousands of trailers.
Old 04-02-2016, 04:28 AM   #1465
Msmoto's Avatar
2007 25' Safari
Images: 135
Maybe the best idea from all the tire wheel/discussions is that one must know the weight each wheel is carrying, and what the manufacturer recommends as the proper pressure to carry the weight measured.
I run slightly above the recommended on my 16" with Firestone Transforce 225/75-16...which is 46 psi with the 1800 lb per wheel. But, as some wheels may be carrying a bit more weight, plus I like a stiffer side to side stability, I run 54 psi.
The result is a much easier ride for the trailer vs. 65 psi with stock tires, albeit possibly some increased rolling resistance with lower pressures. Another reason I run 9 psi higher than the calculated pressure based on weight of the trailer.
AIR #31871 K4MTL
Old 04-02-2016, 09:32 AM   #1466
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Each to their own, but I'm with you. After 6 years of trouble free miles with the originl GYMs I've now put one snowbird winter on new 15" LTX's. If Andy says 44 lbs pressure I guess I'll go with that.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 04-02-2016, 09:43 AM   #1467
moosetags's Avatar
Getting back to New Lucy's air conditioning vents. It has now been about a month since I reattached 8 of 12 of the vents with two sided tape. So far, so good. None have fallen even though we have been back and forth using air conditioning and heat pump. Lucy has not been on a trip yet, but we are hoping that we have this problem solved.
On a brighter note, we have had over 11 inches of torrential rains in the last week here in the Florida Panhandle. New Lucy has not had any leaks.
Brian
Old 04-05-2016, 03:52 PM   #1468
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Nice and colorful lights Brian. Are they plugged into either 120 or 12 v., or battery powered? How did you get them to stick to the windows? I'm not sure I'd do that, but maybe….
We got fewer miles but five years on our Michelin LTX 16" LR E tires, but they aged out rather than wore out. The tread was very good, probably because a trailer doesn't have any drive wheels (i.e., powered by an engine). Since the sidewalls were starting to crack, Michelin honored the warranty on them even though they were slightly beyond the date (on the tire, not when we bought them-a few months difference). I think I got about $40/tire discount for that. I believe the E range tires have a deeper tread than other tires of the same line and so you get more wear out of them. I check tread depth frequently so I can rotate tires to even out wear, but there's really very little difference between tires. Using tread gauge lets you know whether you have too much or too little air pressure. We have settled on 72 psi.
Brian, I'll try to get the Grand Mesa moose, all 400 of them, to show up this year so you can see them. Still a lot of snow up on the Mesa, though ours is gone (10,000' vs. 6,900').
Gene
Gene
Old 04-05-2016, 04:11 PM   #1469
moosetags's Avatar
The lights inside Lucy's side windows are powered by 110. The light strip come with rape backing that is stuck to the window frame inside of the glass.
The light strip along the belt line on Lucy's the curb side is powered by 12 volt.
Brian
Old 04-06-2016, 11:00 AM   #1470
Would it be too rude to say that the colored lights look tacky as he.. to these eyes?
2015 Flying Cloud woof 2009-2015 Flying Cloud 13 04-05-2015 12:53 PM
Selling our 2012 Flying Cloud 30' Sofa for 2015 Bunkhouse Hibby 2009-2015 Flying Cloud 12 03-15-2015 08:08 PM
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 07:43 AM
2015 Flying Cloud front lounge changes Endodoc 2009-2015 Flying Cloud 4 10-10-2014 06:11 AM
2010 Airstream Flying Cloud BRAND NEW!!!!! S2010 Airstream Flying Cloud BRAND NEW!! eBay Watch Airstreams on eBay 0 11-03-2010 03:50 PM
