Old 03-10-2016, 03:22 AM   #1443
2015 25' FB Flying Cloud
Atlantic Beach , Florida
Brian,
We found solution to the falling vents. Drove to the dealer Saturday and returned them.
Sorry to hear the lack of interest in this dilemma from Airstream. Our dealer acted as if this was all new to them.
They had a new Pendleton in the lot 100 Anniversary. Loaded with lots of Classics interior goodies.Hope the tape can handle the heat.
What's you summer adventure plans.
Fred
fpbender is offline   Reply With Quote
Old 03-10-2016, 06:43 AM   #1444
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Note that 3M makes many variations of their double sided red tape in terms of temperature tolerance and, for a lack of a better word, load rating. Many trim pieces on cars and trucks are held on by some variation of that tape.
Lew Faber uses a tape on the roof to attach solar panels, but permanent might not be what is needed if there are air filters behind the registers that need to be changed or cleaned occasionally.
Old 03-10-2016, 07:20 AM   #1445
moosetags's Avatar
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Hi Fred,
We thought about doing the same thing, but we got New Lucy's vents at Jackson Center. We kind of like having the new vents so that we can shut off some of the vents to get more air flow the either the living area or bedroom. We are keeping the OEM screen vents in case we ever want to go back to them.
As far as Lucy Adventures go, we have been trapped here at home since the first of the year doing a renovation on the house.
As soon as we can break free, we are planning to take Lucy over to the the Forgotten Coast for a week or two and explore the area thoroughly.
We are also planning to take a Maine trip later in the spring and a trip way out West this summer and into the fall.
Brian
SuEllyn & Brian McCabe
Old 03-10-2016, 07:28 AM   #1446
moosetags's Avatar
The 3M tape that we used is called Extreme Mounting Tape. It appears to be of the type used to mount automotive trim pieces. I am hopping that it can handle the heat from Lucy's heat pump.
After I installed the vents yesterday, I tried pulling them down. I used reasonable force, and they held tight.
Brian
Old 03-10-2016, 07:48 AM   #1447
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
So do the 2016 models the come with these adjustable vents have this issue too?
Kelvin
Old 03-10-2016, 07:54 AM   #1448
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Kelvin
Yes. Had two fall. All replaced at Jackson Center under warranty. One has since fallen, but not many miles since replacement to know if really better or worse.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 03-10-2016, 08:31 AM   #1449
moosetags's Avatar
The new vent registers are just a poor design that was not well thought out or tested. On the other hand, the OEM screen vent registers that came on the 2015's were fastened with heavy metal spring clips. These were very difficult to remove and had absolutely no danger of falling out.
Brian
Old 03-10-2016, 12:02 PM   #1450
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Been a while, been back to remodeling—A hooked knife may be a carpet knife. A nose cutter might be available at a plastic surgeon's office, but probably is something like a needle nose pliers with a cutter ends like a wire cutter.
Gene
Gene
Gene is online now   Reply With Quote
Old 03-10-2016, 02:39 PM   #1451
moosetags's Avatar
Hi Gene. Glad to hear from you. I really didn't know what kind of cutting tools the guy from Airstream was talking about.
I was able to trim back the insulation in one of the vents with a box cutter. Since there was no improvement in the clips holding, I figured the type of cutting tool was a moot point.
Brian
Old 03-10-2016, 03:03 PM   #1452
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
Brian,
I'm sorry that you are having all of these problems with those vents. As you may recall, I waited until you had them installed at JC before I ordered ours. My dealer installed ours, I went back and ground the aluminum tab back, and reinstalled them. I have yet to have one fall in the rear of our 27FB. I only installed 6 in the lounge /kitchen. I tow with an F250 and use a ProPride hitch.
It really unfortunate that this is happening, I wonder if the vents themselves could be defective or from a bad run.
Best of luck.
DoublTrouble is offline   Reply With Quote
Old 03-10-2016, 07:28 PM   #1453
moosetags's Avatar
Originally Posted by DoublTrouble View Post
Brian,
Best of luck.
We are towing New Lucy with a one ton Silverado and a Hensley. The vents that we have are from Jackson Center in April of 2015. These are probably some of the first of the new ones.
Brian
Old 03-31-2016, 11:40 AM   #1454
blufishin's Avatar
Wilmington , North Carolina
We are considering upgrading to Michelin LTX. I have read many posts about going with 16" tires/wheels. Why not just put 15" Michelins on existing 15" wheels?
blufishin is offline   Reply With Quote
Old 03-31-2016, 12:52 PM   #1455
moosetags's Avatar
The 15" Michelin LT's are in use by many here on the Forums. I have chosen to use the 16" Michelins because it is a 10 ply (load range E) tire with a significantly higher load rating.
Brian
Old 03-31-2016, 01:12 PM   #1456
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Brian
We made the same decision. It just made more sense to go with the higher ply and load rating.
Cheers
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
2015 Flying Cloud woof 2009-2015 Flying Cloud 13 04-05-2015 12:53 PM
Selling our 2012 Flying Cloud 30' Sofa for 2015 Bunkhouse Hibby 2009-2015 Flying Cloud 12 03-15-2015 08:08 PM
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 07:43 AM
2015 Flying Cloud front lounge changes Endodoc 2009-2015 Flying Cloud 4 10-10-2014 06:11 AM
2010 Airstream Flying Cloud BRAND NEW!!!!! S2010 Airstream Flying Cloud BRAND NEW!! eBay Watch Airstreams on eBay 0 11-03-2010 03:50 PM
