Old 03-05-2016, 08:29 AM   #1429
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I have heard back from Dan Snider at Airstream regarding the best method for trimming back the ceiling insulation. This is the email response that I received.
"Brian,
Hello, we have used nose cutters and a hooked knife to trim them back.
Daniel R. Snider
Airstream Senior Technical
Support Representative
(937) 596-6111 Ext. 7408"
I am not real clear on the tools or technique that he is referring to. I would appreciate hearing some other ideas for completing this cutting task.
Brian
SuEllyn & Brian McCabe
Old 03-05-2016, 11:42 AM   #1430
Long Island , New York
I would be surprised if the AS suggestion works uniformly for all the dropping vents/registers. Among other things, the proposed solution does not rectify vent rough openings which are not up to specs (too big or irregular). Also, how dense is the ceiling insulation, that it could keep those tiny plastic tabs from gripping the ceiling's inner skin?
Curious to hear more from you, Brian, about this "fix" especially after a road trip.
FYI I have been too busy to modify the sample register I got to receive a new central shaft.
OTRA15 is online now   Reply With Quote
Old 03-08-2016, 01:22 PM   #1431
moosetags's Avatar
The ceiling insulation board is about 1/8" thick. Today I cut back a bit of the insulation board around the entire hole. I put the vent back in and barely held on. It was quite easy to remove. I don't think that an underway test will be necessary.
Brian
Old 03-08-2016, 01:40 PM   #1432
Yeah that AS suggestion seemed like a real smoke screen. Just kickin' the can further down the road . . .
The plastic tabs that stick up do not have a long enough step on them to grip the aluminum ceiling skin, in part because the tolerances are all so tight. If the ceiling were thicker, and the tabs stuck up more, had more flex, and had a longer step/catch on them -- maybe . . .
Time for a total redesign by AS -- would not be surprised if they eliminate the adjustable register for a while.
Old 03-08-2016, 01:56 PM   #1433
moosetags's Avatar
I have written back to Dan Snider at Airstream reporting the results of their suggested fix.I will report any response, or lack thereof.
Brian
Old 03-08-2016, 03:01 PM   #1434
moosetags's Avatar
Airstream has already written back with the following:
"Brian,
Hello, at this time this is everything we have done. You could add some double face tape to the vent lip when putting it up.
Daniel R. Snider
Brian
Old 03-08-2016, 03:10 PM   #1435
[closest substitute for kickin' can down the road emoji]
Old 03-08-2016, 08:22 PM   #1436
Seattle , USA
lol
RareStream is offline   Reply With Quote
Old 03-09-2016, 07:23 AM   #1437
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We specifically went with one of the last available 2015 23D International Serenity models that had the old style air conditioner. All the 23D models were not built with this ducting system during the 2015 model year. There were enough other QC challenges that I did not desire another one.
It would seem to me that a new disc is needed that is flat on one side and the other side has the necessary curvature to fit flush with the mounting location. The existing hole in the ceiling would have to be made larger so the the ID of the new fitting would be the correct diameter for the existing air registers and have a recess machined so the shoulder of the air register "legs" would have purchase.
I think the factory response to this issue reflects a growing attitude of lack of concern for QC as reflected in the many posts of varied QC issues with the new units. And some of the dealers seem to have the same attitude as well.
The customer takes it in the chops (only polite phrase that came to mind)
switz is online now   Reply With Quote
Old 03-09-2016, 09:02 AM   #1438
Seattle , USA
...kinda like how the end caps don't really fit the roof.
Old 03-09-2016, 03:49 PM   #1439
moosetags's Avatar
I figure that it can't hurt anything, so I have followed Airtream's advice and have put four pieces of two sided tape on the stationary plastic ring. I have also added a small piece of tape to each tab to snug them up a bit. I used 3M Scotch Extreme Mounting Tape.
They seem to be snug and tight. Time will tell. I did this to the eight vents in the living area and bathroom. I left the bedroom vents alone since none of them had ever fallen.
Here are a couple of pictures of one of the vents with the tape applied.
Brian
ID:	258501   Click image for larger version
Old 03-09-2016, 05:23 PM   #1440
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Seems like a good solution, Brian!
Old 03-09-2016, 06:22 PM   #1441
Thanks for the photos Brian. Maybe you should send the files to Airstream and say they can use them in their advertising for Airstream quality control.
"Stick with us, we keep you cool . . . "
Old 03-09-2016, 08:45 PM   #1442
moosetags's Avatar
That would make a great advertisement for Airstream. "Our designs are crummy, but a bunch of aficionados on the Internet will try to correct them."
Brian
2015 Flying Cloud woof 2009-2015 Flying Cloud 13 04-05-2015 12:53 PM
Selling our 2012 Flying Cloud 30' Sofa for 2015 Bunkhouse Hibby 2009-2015 Flying Cloud 12 03-15-2015 08:08 PM
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 07:43 AM
2015 Flying Cloud front lounge changes Endodoc 2009-2015 Flying Cloud 4 10-10-2014 06:11 AM
2010 Airstream Flying Cloud BRAND NEW!!!!! S2010 Airstream Flying Cloud BRAND NEW!! eBay Watch Airstreams on eBay 0 11-03-2010 03:50 PM
