Old 02-15-2016, 09:26 PM   #1387
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Originally Posted by RareStream View Post
Man...you guys could turn making toast into a 3 week discussion...
Clear RTV and be done with it.
Exactly. That's what makes these Forums a valuable asset.
Brian
SuEllyn & Brian McCabe
Old 02-16-2016, 05:55 AM   #1388
Long Island , New York
And will the vent covers be removable? Thanks for joining the discussion! Ditto to Brian . . .
Old 02-16-2016, 07:50 AM   #1389
moosetags's Avatar
I was up early this morning and out in Lucy. I decided to try putting some tin foil on the air conditioning vents. First I wrapped some on the edge of the hole. When I installed the vent, it pushed most of the tin foil up into the vent. I then tried putting pieces of tin foil on the plastic tabs held on by two sided tape. Doing it this way seemed to make the vents even looser than without it. It was almost as if the tin foil was acting as a lubricant.
Brian
Old 02-16-2016, 08:27 AM   #1390
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Brian
Brian
Could have told you the foil idea would not work; RTV...it aint going to ruin your rig, and it does roll off with finger ...now, for toast, you put the bread near the heat just till it turns brown...
Old 02-16-2016, 08:32 AM   #1391
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
What?? Are you nuts?? That's the worst way to make toast!! The ONLY acceptable way is in a Cuisinart toaster, powered by an inverter, using lithium batteries, charged by solar panels. Now THAT makes toast.
2012 Dodge Durango Hemi/AWD
Old 02-16-2016, 08:46 AM   #1392
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Only if you have a ProPride. 😃
SteveSueMac is online now   Reply With Quote
Old 02-16-2016, 09:11 AM   #1393
Thanks for trying Brian, the aluminum foil probably bunched up and pushed the tabs away from the rough opening, thus decreasing their abiiity to catch on the edge of the aluminum ceiling skin.
Old 02-16-2016, 09:17 AM   #1394
gypsydad's Avatar
Lithium batteries...that sounds like a great idea when my AGM's give out... how much juice does the Cuisinart use? The hairdryer worked fine and only used 800...my 1500 W inverter that came with my FC does the job for us...we use the 80W GoPower portable solar, but are thinking a few things after this last desert trip...ran into a "full timer" in Borrego Springs with 25 FC also...he has most everything needed to stay on the road...quite interesting to see the things we had not thought of, only going out for a week or so at a time...immediately had to go on line to Amazon and pick up a few things...almost made me want to quite my job and leave early!
Old 02-16-2016, 10:25 AM   #1395
Hmmmm.... pretty much anything makes me want to do that.
And man it's been a long time since I checked in on this thread. I believe I'm 2 Lucys behind.
Old 02-16-2016, 11:19 AM   #1396
Master of Universe
Gene's Avatar
Grand Junction , Colorado
Brian, it sounds like there might be non-adjustable vents available (post 1380) and maybe that is the only solution.
Or, apply something tough like a thin coat of epoxy to the tabs to make them slightly thicker. Let it dry, try it out.
How long since you've contacted Airstream about a fix? I think it still is warranteed since it seems you bought it less than 2 years ago. Seems like they are responsible and even if it is out of warranty, they have been known to help out people when a problem is common.
Or, I might get tired of the whole thing and screw them in place if there's enough room to put a hole through both the register and ceiling. How important is it to turn them?
As far as how hot they get, I doubt the heat coming out is very hot, but you can check with a tester. Even if it is 110-120˚ or so, most glues should hold at that temp. If the temp is hotter, you may be able to make toast in the hole; it would probably be faster than those things for camping you can put on a stove.
Gene
Gene
Old 02-16-2016, 12:06 PM   #1397
gypsydad's Avatar
Gene[/QUOTE]
I like your thinking, Gene!
Old 02-16-2016, 06:54 PM   #1398
moosetags's Avatar
Gene
Hi Gene,
The epoxy suggestion would work, but might make them permanent. OK, but not desirable.
It was January when I contacted Airstream. They had no real answer then, and the never got back wit me on a new find. New Lucy's warranty is good until October, 2016. She will be going back to Jackson Center this spring. The vents will be one of the issues that they will be addressing if I cannot come up with my own solution in the meantime.
Screwing them in place would negate their adjustability. I am not as concerned with the direction of the air flow as I am with being able to cut off flow to selected vents.
I haven't checked the heat level of the vents with my infrared scope, but I have noticed that the metal part of the vent is too hot to touch when the heat pump has been running.
Brian
Old 02-16-2016, 07:06 PM   #1399
moosetags's Avatar
Hi Marcus,
Apparently you have slipped behind on the saga of the Lucys. Old Lucy was the 2005 Safari 25FB. Little was the 2012 Flying Cloud 23FB, and New Lucy is the 2015 Flying Cloud 25FB.
Brian
Old 02-17-2016, 09:56 AM   #1400
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Brian
The threshold of pain for most people is about 140F according to a report I read many years ago for work.
The whole interior might get to near or above this temp if your Airstream is locked up with windows and vents closed on a very hot and sunny day without shade. Car interiors can get to over 150F air temp and over 200F surface temp (if in direct sun light) in those conditions.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
2015 Flying Cloud woof 2009-2015 Flying Cloud 13 04-05-2015 12:53 PM
Selling our 2012 Flying Cloud 30' Sofa for 2015 Bunkhouse Hibby 2009-2015 Flying Cloud 12 03-15-2015 08:08 PM
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 07:43 AM
2015 Flying Cloud front lounge changes Endodoc 2009-2015 Flying Cloud 4 10-10-2014 06:11 AM
2010 Airstream Flying Cloud BRAND NEW!!!!! S2010 Airstream Flying Cloud BRAND NEW!! eBay Watch Airstreams on eBay 0 11-03-2010 03:50 PM
