Old 09-05-2016, 06:12 PM   #239
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I have 2014 - I'll post in a moment location of all of em
PharmGeek is offline   Reply With Quote
Old 09-05-2016, 06:15 PM   #240
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
1) right next to water pump - this one was hard to find as it can be obscured by other crap in that small area under those drawers - that heat duct panel pops out - that will help - as the drain cut off is under that hose. This is the low point drain for water servicing the macerator toilet.
2) hot water tank is in exterior storage compartment - just next to it is a low point drain.
3) between the tires drivers side are two valves that are low point drains.
I think that is it.
Old 09-05-2016, 06:19 PM   #241
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Also there is the fresh water tank itself of course
Old 03-20-2017, 07:41 AM   #242
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Couple of questions:
1. Does anyone know where the tanks are located in a 2014 30' bunk? I am moving my table from the standard location to the "front bedroom" area. In fact I'm moving the entire dinette there. The table for the screws look to be long enough to penetrate through the subfloor. Don't want to hit anything below. I doubt there is a tank there, but figured I'd ask.
2. Where have people installed solar? I haven't gotten up on the roof to measure (it's full of snow right now), but I'm thinking either 2x100 or 3x100. Could also do 2x160 if they'll fit. Looking to see where the best spot might be. I'm going to utilize the prewire so can't go much above 300w. My inclination is to put one panel on one side and the second on the other to "split the difference" and always have one panel toward the sun (from either side), but I'm interested to hear counter-arguments. Perhaps lining up the panels on the street side and then trying to orient the trailer that way is better?
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 03-21-2017, 07:29 AM   #243
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Getting the narrower 100 watt AM Solar panels allowed us to get nine on the roof of our 2014 31' Classic. We had four on each side outboard of the A/C units and one in the middle forward.
Old 03-21-2017, 09:15 AM   #244
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Could you have fit the larger 100w panels outboard of the A/C?
I'm looking to put between 2 and 4 panels.
Old 03-23-2017, 09:18 AM   #245
switz's Avatar
2014 31' Classic
Images: 8
The constraint is the width. The AM Solar GS-100 panels we used still allowed one's hands between the solar panel and the A/C shroud for maintenance.
We removed the original crank-up television antenna on both trailers and gained a spot for the front panel on the 23D. We installed the Winegard Rayzar antenna which allows for TV in strong signal areas. For us, most TV is now rubbish, so books and DVD movies are our preferred entertainment.
Name:	23D Five AM Solar GS-100 panels.jpg
ID:	281935   Click image for larger version
Name:	Classic to front.JPG
Name:	Classic to rear.jpg
Old 03-23-2017, 09:58 AM   #246
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
That does look tight.
Old 03-30-2017, 11:51 AM   #247
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
Scott, I just put 500W, five of the am solar on my new 2017 23D. I couldn't lay it out like Switz did above, I was planning to, but the roof was different in terms of spacing, and vents and such. I plan to post on another thread tonight my install process, and will post a picture here if you want. I essentially put three in a row in the curbside, and two up front on the street side. I was able to get two of them up against the AC unit on the side, with room for maintenance.
Troutboy
Troutboy is offline   Reply With Quote
Old 03-30-2017, 11:52 AM   #248
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I'm just here to say heeeeey all!!
Old 05-11-2017, 10:29 AM   #249
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Because in theory, I *MAY* be upgrading to a new bunkhouse, is there any folks on here that have a 2015 and above model following this thread? I really want to glean from any and all owners of the ducted models to find out if they have had any real headaches as a result of having the AC units within this configuration.
Thanks!
No decision will be made till mid june at least...but if anyone knows me, I can certainly think out loud heavily until a decision is made.
Old 05-11-2017, 11:17 PM   #250
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
Thanks!
I am happy to chat about my 2015. PM with time and number or I can reply with mine.
2015 30' FC Bunk, Dual A/C, Full Awning, RV550, Sleep Number, ProPride, Nokian Rotiiva AT 15" Tires
2015 Chevrolet 2500HD 4WD Duramax/Allison LTZ Crew Cab Short Bed, Huper Optik, Bull Dog Spray In, Roll-N-Lock, Full Amsoil, Denali SoundBomb, Yakima
2012FB is offline   Reply With Quote
Old 05-12-2017, 08:48 AM   #251
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Pm sent - big thanks!
Old 06-18-2017, 08:57 AM   #252
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
The mods continue. Decided to replace the lounge with a full length countertop.
