Old 10-30-2015, 10:42 AM   #225
Toronto , Ontario
Thanks so much KTBug75. I have added all of your recommendations to my list!
Bearskin is offline   Reply With Quote
Old 07-01-2016, 10:41 PM   #226
2016 27' Flying Cloud
Pittsford , New York
Does bath sink dump into grey or black tank?
Question says it all. I know some units have bath sink that drains into black tank instead of grey. Is this true on the 30' FC Bunk or not? Thanks!
TG2500 is offline   Reply With Quote
Old 07-03-2016, 01:02 PM   #227
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
The macerator style toilet is a direct shot to the black tank. That is all that goes to the black tank. Shower and sinks go to grey tank.
2015 30' FC Bunk, Dual A/C, Full Awning, RV550, Sleep Number, ProPride, Nokian Rotiiva AT 15" Tires
2015 Chevrolet 2500HD 4WD Duramax/Allison LTZ Crew Cab Short Bed, Huper Optik, Bull Dog Spray In, Roll-N-Lock, Full Amsoil, Denali SoundBomb, Yakima
2012FB is offline   Reply With Quote
Old 07-07-2016, 05:58 PM   #228
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
First time I'm giving my front ac unit a good run. Don't see any condensate dripping. Can someone point me to where the line should be? Concerned it's clogged. Thanks.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 07-07-2016, 06:01 PM   #229
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Strike that. road side front tire. dripping well now.
Old 07-12-2016, 10:50 PM   #230
2014 30' FB FC Bunk
City , Maryland
2013+ Bunkhouse Owners Thread!
Can someone point me in the direction of the low point drains for their 2014 bunkhouse? It's the only thing I'm unsure of.
Thanks - awesome thread by the way!
Alumalarkey is offline   Reply With Quote
Old 08-09-2016, 11:38 AM   #231
2014 30' FB FC Bunk
1964 28' Ambassador
Panama City Beach , Florida
I have recently listed my 2014 Bunkhouse. I am the original owner and purchased it new. Excellent condition... Check it out at--
http://www.airstreamclassifieds.com/...-30-florida-3/
Thx! George
geowickey is offline   Reply With Quote
Old 08-20-2016, 08:41 AM   #232
2016 30' Flying Cloud
Savannah , Texas
We have the 2016 30fb and similar issues with drawers opening during travel, made for some frustrating nights pulling into find broken drawers, all pretty easy to fix, and likely due to maxing out capacity. However we have added some discrete hooks and bungees during travel to finally stop the issue. Although I wish airstream would use the button style locking latches, that would be awesome.
Streaminfree is offline   Reply With Quote
Old 08-20-2016, 08:48 AM   #233
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Got rid of all the plastic catches in both the 2014 Classic and the 2015 23D International Serenity. These completely solved the drawer and cabinet door opening issue and they cost less than the replacement plastic stuff from Airstream. Make sure to order the appropriate brass screws at the same time as the smaller screw sizes are not readily available at the local big box stores or the smaller hardware stores.
http://www.leevalley.com/US/Hardware...=3,41399,41405
We used the "C" and "D sizes depending on location.
Old 08-20-2016, 09:44 AM   #234
Savannah , Texas
Thanks for this post, we just put some discreet hooks and used bungees, but I like this much better!
Old 08-21-2016, 06:16 PM   #235
bullet661's Avatar
2014 30' FB FC Bunk
Fresno , California
The hot and cold low point drains are just in front of the fresh water drain which is between the wheels on the port side.
It takes a big man to cry....it takes an even bigger man to laugh at that man.
bullet661 is offline   Reply With Quote
Old 08-27-2016, 07:12 PM   #236
2014 30' FB FC Bunk
City , Maryland
I have no exterior low point drain valves on my 2014 bunkhouse. Any other suggestions ?
Manual says under the rear dinette cushion there should be a hole cutout. I don't have this either. Doesn't make sense since all of the water lines with exception of the hot water heater are on the other side.
I also don't know where my water pump is located and how to access it. I believe it's under the pantry or below or behind the bathroom sink somewhere.
Any suggestions are welcome and appreciated!
Old 08-28-2016, 06:38 AM   #237
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
The low point drains can be hard to find. they are tucked up behind the tires on the curb side.
Nit sure about the manual and a cutout, but I don't have one. there is a hole for the water bypass under the rear bed.
Water pump behind the furnace vent under the drawers adjacent to the oven. give the whole panel a firm tug and it will pop out.
Good luck!
Btw, I assume you go by the same name on instagram? we've spoken there.
Old 08-29-2016, 06:22 PM   #238
2014 30' FB FC Bunk
City , Maryland
Thanks for the reply yes that's us from Instagram LOL!
Found the pump.
However the only drain valve I have between the curbside tires is for the freshwater tank. I did find a valve just to the left if my hot water heater in the rear roadside compartment. I opened it after cracking the faucets and it acted like a low point drain.
I haven't had a chance to poke my head under the rear bed to understand what's going in back there.
It's been great following you over on Instagram ! Thanks for the help.
