Old 08-22-2016, 06:21 PM   #1205
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
Originally Posted by OTRA15 View Post
Tanks Bob!
I gas you are talking about the propane tanks? Why are you moving them? This is a new one on me. Will check ours for security. Tanks again.
Looking forward to your drawer latch feedback. Likin' the bungee cord solution here . . .
Peter
tanks...you're killing me. You do need to get on the road...soon!
as for the tanks moving...well I’m not positive but expect I will. Maybe too much work for an inch…but we’ll see.
It's just that I have such an ill-fitting tank enclosure. Some misfit was caused by a jack post that was not plumb…slight lean to the rear. This pushes the top of the tank cover back but the bottom can’t move as it’s fixed. The dealer added 2 washers (to match the thickness of the one required for the jack ground) when they swapped out the head recently so at least the post is now plumb… that helped a bit.
The other clue was the notch at the bottom rear of cover…the enclosure sits forward so the notch in the rear panel of the cover is still well forward of the battery box. I presume the notch is there so the batt box can slip under the notch and the panel lands just forward of the piano hinge. When the lid is up and the lid latch against the panel, the panel should be at least vertical, maybe a slight lean fwd to accommodate getting the batts out when needed. When I redo the box for the 6v’s I presume I’ll raise the lid as opposed to dropping the bottom. I think I’ll lose the hinge and maybe go with the mechanisms in the rear bumper compartment…fit into slot and push over to hold down.
I’ve never seen an AS with a leaning tank closure like our and it drives me nuts…plus it’s always a struggle getting the cover on and off as the front of the enclosure is hard against (and even past) the rear edge (plane) of the jack head…so the front panel bows in to accommodate the jack head.
as for the bungee that is my default. I'm just not there yet. I've also only had problems with the P & P drawer and the slider opening I presume as they generally carry a heavier payload. I solved the slide with a gate latch I had...kinda Rube but form follows function.
When I was at the hardware vendor, they said they sell a ton of these...to quote them " by the boxes to hospitals and Dr's offices" for their med's cabinets in patient rooms. If it works for them...I'll give it a try. Plus now that I understand the how (how the constant reverse polarity closes the latch and the strong magnet opens it) , I feel better that I'll be able to open it and not get stranded.
I hope to do this tomorrow. We finally got a break in the weather (105 one day!!!) so I'll probably drag Blue home do the work, give the batts a drink, remove them for a trickle until we leave in a month.
Name:	IMG_8651 (Small).JPG
ID:	269773   Click image for larger version
Name:	IMG_8652 (Small).JPG
CruizinDux is offline   Reply With Quote
Old 08-23-2016, 08:16 AM   #1206
Long Island , New York
Appreciate the further clarification, Bob. I gas our propane tanks could stand to go back a bit, as the jack also pushes into our tank cover, but yours sounds worse. Our jack vertical tube seems pretty plumb FWIW.
So this is the tanks we get, for all our hard work . . . ?
Sorry. Yeah, too much free time I guess . . . gotta get OTRA again soon . . . going to try for Hither Hills SP mid-week again after Labor Day. Then maybe Asheville NC in October or November? TBD. CalDream16/17 may morph into 17/18 . . .
Ya done Rube proud with that latch, for sure, but it is hidden, simple and it works -- with minimal installation labor. I like it. One bungee cord down low would also work for you -- for both this pantry door, and for the drawer under the stove. And the two strap eyes could be low and less visible than our three on each end.
That magnetic latch sounds good, but you know how little gadgets like that sometimes malfunction in ways we don't anticipate . . .
Have a good Labor Day weekend. Looking forward to cooler weather (which we have a great dose of right now) and getting on the road again!
Cheers,
Peter
OTRA15 is online now   Reply With Quote
Old 08-23-2016, 12:19 PM   #1207
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
Guess what?? I finally got around to measuring the rear galley window during my camping trip last week. I am including a couple of photos. Advanced apologies for any sideways photos....they sometimes come out weird here on the forums.
In my model, the window can be opened and latches open with the opener arms. The right edge of the window frame goes, just barely, behind the edge of the bathroom wall. From the bathroom wall edge to the center of the right handle is 1/2 inch. From the slit that the right arm occupies, it is 25 3/8 inches over to the center of the slit that the left arm occupies.
Hopefully this information helps.....please let me know if you have any other questions.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 08-23-2016, 12:28 PM   #1208
OK...let's try again. For some reason, pics aren't uploading easily this morning.
ID:	269841   Click image for larger version
Old 08-23-2016, 01:25 PM   #1209
Thanks Steve, it appears that your interior trim piece incl. screen would work on our sink window, but that the right edge would have to be trimmed off, to lose most if not all of the slot for the right operator handle. Add in a new left operator handle and mechanism, which should bolt to our window's existing through-bolts, and this may be a solution for us IMO.
I am guessing that they moved the bath wall over to the right (looking at the galley sinks) a bit to accomplish this.
One of the face screws which hold on our trim piece would conflict with the new left operator it appears, but this is manageable.
Thanks again,
Peter
Old 08-23-2016, 04:09 PM   #1210
You bet Peter.....on my unit it appears that the entire window frame is there and that they "slid" it ever so slightly behind the bathroom wall. It's hard to tell but it looks like it's the same size all the way around. Let me know if you need any other measurements.
Old 08-23-2016, 05:21 PM   #1211
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
Yes thanks for the measurements, I have a measurement request. Can you measure the distance between the edge of the sink to the bathroom wall? Thanks I'm still going to pursue looking into installing the curb side only lever when I get back in September. I'll post here with the results. I'm wondering if the shower enclosure is smaller in the new units?
subfan1 is offline   Reply With Quote
Old 08-23-2016, 05:57 PM   #1212
That has been my assumption all along, a smaller shower in the new units. Or has the sink and/or window been shifted to the left? No matter IMO, as Steve's L/R dimension earlier confirms the new interior screen/trim should work in our 2014. With cool weather on the way here in the NE, any window work will probably go to the back burner.
Steve it looks like you have about 2" of counter from the rim of the sink to the bath wall cove trim? What is the unit with bars sitting on your sink? A dish drain or drying rack of some kind? Thanks.
Old 08-23-2016, 06:28 PM   #1213
Originally Posted by subfan1 View Post
Yosemite National Park lower pines campground. I'm a volunteer this month.
Attachment 269074
Cool photo! How's it going in Yosemite?
Old 08-23-2016, 09:32 PM   #1214
TahoeStream'n
subfan1's Avatar
Earlier in the month it was very hot and throughout the year there has been an increase in visitors by 22%
Volunteers and park staff have been very busy this month and for me, I'm ready to come home. This year has been very difficult due to the increase in visitors. I'll be heading home on Monday.
Old 08-24-2016, 05:45 AM   #1215
Sounds, er, emm, well . . . gruesome!
Kinda takes the bloom off the rose of volunteering IMO.
Safe home.
Peter
Old 08-24-2016, 06:24 AM   #1216
'15 Flying Loud 20' Bambi
renderit's Avatar
2014 16' Sport
small city outside a big one , south of some, north of some
I did this to my cover and it works great. Posted it a while back, but this thing is way too long to search. This lifts it and gives more clearance. It also quiets it and keeps you from having to move it. I put felt pads in back of the jack head that it rests against. The rubber (actually rubber feet from Amazon) are stepped in the front to go over the jack pad. Cuts easily with a back saw. Stuck on with 30# tape.
renderit is offline   Reply With Quote
Old 08-24-2016, 09:33 AM   #1217
OK...so, I went out and measured from the bathroom wall to the sink edge this mornong. It's 2 3/8"
I decided to take a really close look at the edge of the window next to the bathroom wall. It actually looks like the edge stops right at the edge of the bathroom wall instead of going behind it. The edge of the window is slightly hidden by the aluminum decorative strip that covers it.
Also, the rack that you saw over the sink is a foldable dish dryer that I bought on Amazon. It is very durable and will hold the weight of a hot pot with food in it which gives even more workable space in our wonderful kitchens that we are blessed with in this model I use it as a vegetable drying rack after rinsing, dish drainer, and hot pot rack. When I travel it folds up and is stowed under the sink.
Old 08-24-2016, 09:49 AM   #1218
Ditto here -- 2 3/8" thanks.
Prices on 34 Footers ElCamino Man Trailer Values 21 01-23-2014 04:56 PM
1970s vintage type 30+ footers silversails Airstream History 6 07-22-2010 06:58 AM
31 and 34 footers a thing of the past. yakman Off Topic Forum 23 08-02-2009 11:05 PM
frame layout for 18-footers greenrig Repairing/Replacing Floor &/or Frame 2 08-19-2008 12:06 AM
What about the 74' 28 footers? stinkytwinky All Argosy Trailers 10 08-22-2005 07:30 PM
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
