Old 04-23-2016, 06:04 PM   #785
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
So I just got back from buying some undercoating for the wheels wells
Name:	ImageUploadedByAirstream Forums1461452395.174176.jpg
The question I had Otra15, will you be covering the entire wheel well specifically the galvanized part? I want to attempt to do this tomorrow. One other note, I don't see how I can do this without removing the tire. Do you still think you can do it without removing the tires Otra15?
subfan1 is offline   Reply With Quote
Old 04-23-2016, 07:19 PM   #786
Long Island , New York
Yes, subfan1, I agree that the wheels should come off to do the job right, and have the chassis elevated to spray the entire wheel well from underneath. As I think I said in an earlier post, however, I don't have time for this right now. I did get the trailer wheels up on 6x6's today, and will do the best I can to cover the exposed plywood sub-floor in the next day or two, weather permitting.
Old 04-23-2016, 07:53 PM   #787
TahoeStream'n
subfan1's Avatar
Yes you did say without removing the wheel; before I spray I'm going to lift the trailer by the "jack here point" and see if I can spray the well completely.
Old 04-23-2016, 07:54 PM   #788
TahoeStream'n
subfan1's Avatar
I'm hoping I won't have to remove the wheel.
Old 04-23-2016, 08:12 PM   #789
If you do this, and end up removing one tire at a time, please consider adding some safety blocking just under the bare wheel hub and/or axle (non load bearing) in case the jack fails.
Old 04-23-2016, 09:49 PM   #790
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
Peter and Jose, since you two are in the lead on the wheel well/sheet metal project, I'm hoping to see some progress pics and maybe comments re tire removal or lack thereof. There wasn't much room for a camera, so it will be interesting how the spray can fits.
Like Peter said, please work safe.
CruizinDux is offline   Reply With Quote
Old 04-23-2016, 10:01 PM   #791
CruizinDux's Avatar
Originally Posted by OTRA15 View Post
On the pump noise -- ...Not a diaphragm pump, but a variable speed screw-feed pump (if I have the terminology right). A lower GPM flow rate would be OK too.
.... but will have to make sure the pump room space under the blankets does not get too hot with the pump running in the summer.
Thanks, Peter. Good discussion and analysis. If I hit the sound wall, VS is the way to go. Can't be that pricey and should be an easy swap.
Old 04-23-2016, 10:13 PM   #792
CruizinDux's Avatar
Bob, our Dometic fridge has the sliding "thermistor" (?) shown below, which can be slid up and down on the right fin. There is a blue triangular arrow/play symbol on the right side of the case (and looks like a hint of blue mark near the top of the slide?). This is the way it came from the factory, and the various threads here which mention this seem to agree +/- that it should be on the right fin. I did try sliding it up and down last fall, but don't recall any firm conclusions.
One thread about slide adjusting up for colder etc. :
http://www.airforums.com/forums/f425...nt-147010.html
We have accurate Taylor thermometers in the fridge and freezer at all times, as I have found that looking at them often is advisable, both at home and in the trailer.
I just turned the fridge on and will check back tomorrow. I put two large blocks of blue ice in there also, as it helps lower the temp more quickly. Also, I have read that one should never put warm items in the fridge. We pre-cool all beverages etc. in the tow vehicle's ice chest first. If needed in hot weather, I may even add a bag of ice to the fridge, as you seem to have done.
Once the fridge is at temperature and stable, it can take 24 hours for the system to stabilize again after moving the thermistor apparently. In a sense our AS Dometic fridges are more like a "keep cool" appliance than a "get it cold" unit IMO -- an acceptable compromise when backed up by a good ice chest. The next purchase for boondocking might be a Pelican or Yeti cooler for dry ice storage of frozen items.
Curious to hear how you make out on the trip, and whether you can get a handle on this temp. adjustment system.
Peter
Attachment 261201
Peter....thanks for the tread and the pic/comments. I'll read it, call Sutton on Monday and look at the refer and note the position I left it in from the maiden. It seemed to work once allowed to stabilize....just takes longer to not only cool but react to the adjustment than I had expected. I'll also look for the mark....I sure don't remember seeing it. I'll light'r up first thing Monday when I bring Blue home to load up.
Interesting other than the model number, there was hardly any mention our unit in the op manual.
I planned on the pre-cooling content which I didn't do the last time as we didn't buy groceries until we were 3 days down the road and hadn't turned it on yet.
Old 04-23-2016, 10:17 PM   #793
CruizinDux's Avatar
Originally Posted by waldosgone View Post
Bob - I've driven the ALCAN/Cassiar highway twice and my wife has done it five times and couple words of advice.
Milepost is an invaluable tool on this trip but like any tool it's not 100% accurate...... "
If anyone has an questions I'd be happy to answer them or share our experiences along the way in a separate thread.
Jim your comments as very much appreciated.
We're hoping to make the trip but expect it may be later than planned to allow for more planning.
Safe Journey
Old 04-23-2016, 10:32 PM   #794
CruizinDux's Avatar
In light of the Sony stereo model variance...I have a Dometic 2351...the lowest model # in the series covered by the manual
bob
Old 04-23-2016, 10:48 PM   #795
TahoeStream'n
subfan1's Avatar
Yes of course, safety first. I'm going to make an attempt tomorrow. Today I jacked the trailer and noticed a seam at the top of the wheel well that I'm going to get as well. I'll take some pictures and post. It was getting late in the day and didn't want to hurry but wanted to know what I was up against. Good luck tomorrow Otra15
Old 04-24-2016, 09:07 AM   #796
MaineStreamer's Avatar
2007 20' Safari
Saco , Maine
Here are Youtube videos about Dometic refrigerator thermostat adjustment:
Marty Womer
Saco, Maine
MaineStreamer is offline   Reply With Quote
Old 04-24-2016, 11:07 AM   #797
CruizinDux's Avatar
If it were me, in addition to the axle and other wheel blocking, I would also hook up the the TV, just to make sure there is no fwd/rev movement once on blocks.
Old 04-24-2016, 01:47 PM   #798
TahoeStream'n
subfan1's Avatar
Well it didn't go so great. I would not recommend the undercoating for this job. I think the gaps are just too big on our trailer. The spray was too hard to control in terms if knowing how much of the undercoating from the spray is coming out. I only did one side and will now wait until Otra15 completes his trailer with bed liner spray. Here are a couple of pictures:
Name:	ImageUploadedByAirstream Forums1461523597.107079.jpg
Name:	ImageUploadedByAirstream Forums1461523623.751124.jpg
Prices on 34 Footers ElCamino Man Trailer Values 21 01-23-2014 04:56 PM
1970s vintage type 30+ footers silversails Airstream History 6 07-22-2010 06:58 AM
31 and 34 footers a thing of the past. yakman Off Topic Forum 23 08-02-2009 11:05 PM
frame layout for 18-footers greenrig Repairing/Replacing Floor &/or Frame 2 08-19-2008 12:06 AM
What about the 74' 28 footers? stinkytwinky All Argosy Trailers 10 08-22-2005 07:30 PM
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
