Old 10-25-2010, 05:08 PM   #1
Mifair's Avatar
2011 27 FB International
Keswick , Ontario
Winterizing Valve on 27FB
Hi there, Anyone owning a 27FB or any later model RV tell me if they are equipped with the wintering valve that is inline befoe the water pump. These valves are switchable from taking water from the fresh water tank OR from a clear flexible tube for the purposes of pumping in plumbers antifeeze. I know these models are equipped with the hot water tank by-pass.
Appreciate your response in advance.
MIFAIR
future owner of 2011 27FB International
Mifair is offline   Reply With Quote
Old 10-25-2010, 05:15 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Hi Mifair. I don't know that I've ever heard of the factory installing these. It's easy enough to do it yourself. I've heard of dealers installing them when requested.
5 meter Langford Nahanni
Old 10-25-2010, 08:02 PM   #3
Mifair's Avatar
Keswick , Ontario
without this valve kit, how is plumbers antifreeze fed into the pipes?
Old 11-10-2010, 05:42 PM   #4
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Potable antifreeze
Without the kit, the only way I know to do this it is to 1st be sure the fresh water tank is drained then close the petcock and add 2-3 gallons (or more if needed) of potable RV antifreeze. if the trailer is leaning slightly towards the pickup tube, you should be able to use the pump to get it. The kits cost about $20-25. A local dealer carries 3 different brands and there's little difference between them, one has a plastic valve, the others are brass.
Silver Goose is offline   Reply With Quote
Old 11-11-2010, 07:24 PM   #5
2010 27' FB Classic
N/A , Texas
I just received my kit from Camping World (CW) today. The price was $10.99 US dollars. It is called a Pump Converter Winterizer Kit. CW Part# is 6279. It comes with the brass valve., clear tubing and fittings and seal tape. It's a Camco brand kit.
2011 international
« - | Top | Fresh water drain »
Stubborn valve on Safari 27FB dpulling Waste Systems, Tanks & Totes 5 04-05-2010 11:41 PM
towing 27fb vs 25 fb ? jhnquest 2006 - 2010 International 23 03-11-2009 08:33 AM
Winterizing Valve tomb Winterizing, Storage, Carports & Covers 3 07-08-2008 07:04 PM
Electrical outlet on 27FB gowyn 2007 Safari 4 12-16-2007 01:39 PM
Today gate valve, later check valve. GlenCoombe Classic Motorhomes 1 09-20-2005 11:02 AM
