Old 06-26-2015, 09:27 AM   #1
Plasma800's Avatar
houston , Texas
Which charger / converter? 15 Intl Sig
So I have a new international signature.
I've read some about changing the converter/inverter to a nicer unit.
From what I understand, the progressive dynamics units is the unit of choice.
When I go to 4600 Series Upgrade or Replacement Power Converters from Progressive Dynamics I see that they have multiple units to replace different Parallax units.
I am curious to know if anyone knows which parallax unit would be installed in a 27FB with one A/C?
Access to see it in my storage bay is difficult.
Which ProgDyn unit would the appropriate one to order?
'15 27fb Signature
'12 Chevy 2500HD Gasser
Plasma800 is offline   Reply With Quote
Old 06-26-2015, 11:10 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
contact www.bestconverter.com, they are in many threads here and are highly regarded.
Larry
lsbrodsky is offline   Reply With Quote
Old 06-26-2015, 11:22 AM   #3
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
The PD4655 is what I bought from BestConverter to replace my Parallax which failed. It slips in the space under the fuse panels. Easy upgrade. The PD4655 comes with a new 12v fuse panel which connects to the Smart Wizard circuitry. If a 12v fuse pops a little LED lights up against it. The AC fuses stay.
Kelvin
Old 06-26-2015, 11:37 AM   #4
Plasma800's Avatar
houston , Texas
Just trying to learn...
what are the items under my bed? I know there is a relay there, and some other big grey box....
My fuse panels appear to be mid kitchen
'15 27fb Signature
Old 06-26-2015, 12:22 PM   #5
lsbrodsky's Avatar
I have a 25FB Intl so I cannot speak to your 27 with authority but in mine, the converter, breakers, and fuse panel are under the bed. Also there is the transfer switch for switching AC inlet between the two outlets on the side and front of the trailer. The stuff on the kitchen wall is for the water pump, tank sensors, inverter control, and solar monitoring.
Larry
Old 06-26-2015, 12:41 PM   #6
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
On my 25fb behind the converter/charger under the bed is a removable felt covered box is the back part of the converter and the wiring. On the other side of the bed is another felt covered box which has the Store/Use relay, bus bars and a grey plastic box which terminates the wires from the hitch electrical cord and the external lights of the AS. I had to access the one behind the converter so I could unscrew a strain relief clamp to allow a little more length on the battery wires.
Kelvin
Old 06-26-2015, 01:30 PM   #7
Plasma800's Avatar
houston , Texas
No I mean at the floor, just where the kitchen cabinets begin from the bathroom, I have a panel. I open the panel in there are breakers, and fuses.
I think this might be the same panel the 25 has on the edge of the bed.
Then under my bed, in the front storage area, is a relay, something else, and a big grey unly box that I suspect is the converter.
'15 27fb Signature
Old 06-26-2015, 01:32 PM   #8
Plasma800's Avatar
houston , Texas
Look at the floor right where the kitchen meets the bathroom.
'15 27fb Signature
Old 06-26-2015, 01:47 PM   #9
lsbrodsky's Avatar
That box looks like your converter, fuses, and breakers. The post above probably explains what you are seeing up front, maybe an inverter if you have one.
Larry
Old 06-26-2015, 05:40 PM   #10
Plasma800's Avatar
houston , Texas
I do have inverter..
'15 27fb Signature
Old 06-26-2015, 06:53 PM   #11
2015 30' Classic
Pleasanton , California
Just curious but why do you want to replace the converter? If you have a factory solar package or you're contemplating a solar installation in the future then you'll have a 3-stage battery charger and you don't need to spend additional dollars for something which gives no benefit.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 06-26-2015, 09:51 PM   #12
lewster's Avatar
Naples, FL , Hood River, OR
Not unless you are in an extended period of inclement weather ( it DOES happen) and are connected to either shore power or generator. 3 stage charging from 120VAC would be essential in those circumstances. And NO, the 13.6VDC continual output from a Parallax converter is definitely NOT the way to properly charge batteries..........ANY batteries...........especially if you want to derive maximum life from them.
Old 06-26-2015, 10:32 PM   #13
2010 27' FB International
La Crescent , Minnesota
I put in a PD4645. It takes care of our needs very well and it allows a 1000 watt Yamaha to charge the batteries without overloading.
Jay
mjayjensen is offline   Reply With Quote
Old 06-26-2015, 10:34 PM   #14
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Wow, Lew didn't post that you should purchase a $1000+ Magnum???
My setup is the same, and as mentioned above,
I chose the Powermax Boondocker PM4B-60 (4 stage) from BestConverter - Converters, Inverters, Electrical Supplies, Electronics - People choose the ProgDyn units because they are straight swaps and afraid of wiring. Don't get me wrong, they're excellent units.
But it was literally 3 WIRES to install this. And some screws to hold it to the floor. Not complicated. But hey, folks are willing to pay more for plug and play. That's cool.
Plasma, see this thread for additional help: http://www.airforums.com/forums/f449...am-126429.html
We have the same panels, although in these photos some of the covers are removed.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 06-26-2015, 11:24 PM   #15
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We have the original factory converter/charger and factory solar. To protect our original Highline AGM batteries, whenever hooked to external power we isolate the batteries from the converter/charger by placing the Battery Disconnect Switch in STORE position.
The solar system charges the batteries with or without external power. If a long period of cloudy weather, we use external power for brief periods to charge the batteries through the converter/charger. That doesn't happen often.
We look forward to a Magnum inverter and Lithium Ion batteries when/if the price improves.
Doug and Cheryl
Old 06-27-2015, 06:15 AM   #16
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Heed the words of the Prophet, the P-LAX belongs in the underworld, along with the four Interstate Batteries it sent there
Old 06-27-2015, 07:22 AM   #17
lewster's Avatar
BA,
Surprised? You shouldn't be.................... While Magnums are the best all around charger, with a good solar charge controller like a Blue Sky that becomes your primary battery charging source, the converter becomes a back-up. Not everyone needs a Magnum, but then not everyone needs lithium batteries or an Airstream for that matter either........
What folks DON'T NEED is the dated technology of a single stage converter that has a proven history of battery destruction.
What ever floats your boat!
Old 06-27-2015, 10:30 AM   #18
Plasma800's Avatar
houston , Texas
Yeah I agree. I'm just in the information gathering stage right now.
But from what I'm gathering, the on board charge isn't great and should be swapped for a multi stage charger.
'15 27fb Signature
Old 06-27-2015, 11:33 AM   #19
Plasma800's Avatar
houston , Texas
I would likesome clarification on a couple of other things..
1. The charger installed from the factory in 15 is or is not a single stage charger?
2. One should not ever leave their unit plugged into 110 when in storage?
'15 27fb Signature
Old 06-27-2015, 11:41 AM   #20
Nomadic , USA
Single stage
Not with a single stage charger. Just getting blasted no stop.
Intl Sig 30RB Lounge - Where is the Dual Coax? SafariBez Electronics & Connectivity 1 04-30-2014 04:36 PM
Converter/Charger vs. Inverter/Charger moosetags Batteries, Univolts, Converters & Inverters 5 11-22-2013 11:21 PM
Converter/charger humming in stereo blickcd Electrical - Systems, Generators, Batteries & Solar 6 01-05-2005 08:50 PM
Converter/battery charger ARGONUT Batteries, Univolts, Converters & Inverters 0 11-23-2003 05:28 PM
Adding charger where no charger has gone before Jabba Electrical - Systems, Generators, Batteries & Solar 4 03-08-2003 10:39 AM
