Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > International > 2011 - 2015 International
Old 06-27-2015, 12:44 PM   #21
Plasma800's Avatar
houston , Texas
Originally Posted by BoldAdventure View Post
Single stage
Not with a single stage charger. Just getting blasted no stop.
And so then at a campground, hooked up, the STORE button should be used?
I have no problem changing the charger, the cost is pretty minimal, just like I'm considering swapping the 15's for 16's
'15 27fb Signature
'12 Chevy 2500HD Gasser
Plasma800 is offline   Reply With Quote
Old 06-27-2015, 03:07 PM   #22
Damien
tot2learn's Avatar
2012 27' FB International
2023 30' Flying Cloud
Lafayette , Colorado
I have the same trailer as Plasma, but with 2 a/c units and 50amp service. Would the PD4655 be the correct replacement for me as well?
tot2learn is offline   Reply With Quote
Old 06-27-2015, 04:27 PM   #23
Naples , Florida
Nope. You need the PD 9260 deck mount.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
lewster
Old 06-27-2015, 05:04 PM   #24
Ponyfvr's Avatar
2015 25' International
Scottsdale , Arizona
We have a 2015 AS International Signature addition, I am not sure which converter I have. I had a 2104 AS FC and replaced the converter but I am not sure if AS changed to converter in 2015.
Do I need to upgrade my 2015?
Thanks for the help. lewster I always enjoy your comments and how you share your knowledge with the forum.
2017 Ford F-250 Diesel
WBCCI # 5462 4CU
Ponyfvr is offline   Reply With Quote
Old 06-27-2015, 05:17 PM   #25
Plasma800's Avatar
houston , Texas
Lew Farber
541-490-6357
Deal.
I'd let you install some solar if you wanted to......................... I'll meet you wherever.
'15 27fb Signature
Old 06-27-2015, 06:26 PM   #26
Naples , Florida
Any time!
Lew Farber
541-490-6357
lewster
Old 06-27-2015, 09:22 PM   #27
Damien
tot2learn's Avatar
Thanks Lew
Old 06-28-2015, 05:51 AM   #28
Damien
tot2learn's Avatar
I was doing a bit more research on the recommendation of the PD9260 deck mount that Lewster mentioned. It sounds like the PowerMax PM4B-60 BoldAdventure mentioned would be a comparable choice. Does anyone have a recommendation of one over the other? Ease of install, noise, performance?
I liked the original idea of the 4600 Series being a direct replacement, it's too bad that's not an option for my 50amp service. I'd like to keep the install as straightforward as possible.
Old 06-28-2015, 09:02 AM   #29
Naples , Florida
The biggest difference between the PD 9260 and the Powermax is country of origin. The Boondocker (which is really a pretty misleading name, as you usually don't have access to 120VAC shore power required to operate a converter when you are truly 'boondocking' ) is made in China and Progressive Dynamics builds their units in Michigan.
All things being equal, I prefer the PD-9260 as it is made in the USA!
lewster
Old 06-29-2015, 11:18 AM   #30
Damien
tot2learn's Avatar
I checked which converter I have this morning, it's the Parallax Model 555. I'm perplexed now as to why I can't upgrade to the PD4655. Both are 55amp.
Again, I like the idea of doing a replacement upgrade vs. a deck mount with its additional customizations (fuse panel holder and mounting)
Old 06-30-2015, 10:30 AM   #31
Damien
tot2learn's Avatar
I just heard back from Progressive, Lewster you were right that the PD4655 won't work for me. It sounds like a deck mount is my only option.
Old 10-19-2015, 05:06 PM   #32
2016 25' International
Wanamingo , Minnesota
Are you sure the new (2015 & 2016) trailers have 3 stage chargers? My 2008 only had the single stage MagnaTec (sp?). When I replaced it my batteries started lasting much longer.....haven't had any problems since.
Scout1 is offline   Reply With Quote
Intl Sig 30RB Lounge - Where is the Dual Coax? SafariBez Electronics & Connectivity 1 04-30-2014 03:36 PM
Converter/Charger vs. Inverter/Charger moosetags Batteries, Univolts, Converters & Inverters 5 11-22-2013 10:21 PM
Converter/charger humming in stereo blickcd Electrical - Systems, Generators, Batteries & Solar 6 01-05-2005 07:50 PM
Converter/battery charger ARGONUT Batteries, Univolts, Converters & Inverters 0 11-23-2003 04:28 PM
Adding charger where no charger has gone before Jabba Electrical - Systems, Generators, Batteries & Solar 4 03-08-2003 09:39 AM
