06-27-2015, 12:44 PM
#21
houston
Originally Posted by BoldAdventure
Single stage
Not with a single stage charger. Just getting blasted no stop.
And so then at a campground, hooked up, the STORE button should be used?
I have no problem changing the charger, the cost is pretty minimal, just like I'm considering swapping the 15's for 16's
'15 27fb Signature
'12 Chevy 2500HD Gasser
06-27-2015, 03:07 PM
#22
Damien
2012 27' FB International
2023 30' Flying Cloud
Lafayette
I have the same trailer as Plasma, but with 2 a/c units and 50amp service. Would the PD4655 be the correct replacement for me as well?
06-27-2015, 04:27 PM
#23
Naples
Nope. You need the PD 9260 deck mount.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
lewster
06-27-2015, 05:04 PM
#24
2015 25' International
Scottsdale
We have a 2015 AS International Signature addition, I am not sure which converter I have. I had a 2104 AS FC and replaced the converter but I am not sure if AS changed to converter in 2015.
Do I need to upgrade my 2015?
Thanks for the help. lewster I always enjoy your comments and how you share your knowledge with the forum.
2017 Ford F-250 Diesel
WBCCI # 5462 4CU
06-27-2015, 05:17 PM
#25
houston
Lew Farber
541-490-6357
Deal.
I'd let you install some solar if you wanted to......................... I'll meet you wherever.
'15 27fb Signature
06-27-2015, 06:26 PM
#26
Naples
Any time!
Lew Farber
541-490-6357
lewster
06-27-2015, 09:22 PM
#27
Damien
Lafayette
Thanks Lew
06-28-2015, 05:51 AM
#28
Damien
Lafayette
I was doing a bit more research on the recommendation of the PD9260 deck mount that Lewster mentioned. It sounds like the PowerMax PM4B-60 BoldAdventure mentioned would be a comparable choice. Does anyone have a recommendation of one over the other? Ease of install, noise, performance?
I liked the original idea of the 4600 Series being a direct replacement, it's too bad that's not an option for my 50amp service. I'd like to keep the install as straightforward as possible.
06-28-2015, 09:02 AM
#29
Naples
The biggest difference between the PD 9260 and the Powermax is country of origin. The Boondocker (which is really a pretty misleading name, as you usually don't have access to 120VAC shore power required to operate a converter when you are truly 'boondocking' ) is made in China and Progressive Dynamics builds their units in Michigan.
All things being equal, I prefer the PD-9260 as it is made in the USA!
lewster
06-29-2015, 11:18 AM
#30
Damien
Lafayette
I checked which converter I have this morning, it's the Parallax Model 555. I'm perplexed now as to why I can't upgrade to the PD4655. Both are 55amp.
Again, I like the idea of doing a replacement upgrade vs. a deck mount with its additional customizations (fuse panel holder and mounting)
06-30-2015, 10:30 AM
#31
Damien
Lafayette
I just heard back from Progressive, Lewster you were right that the PD4655 won't work for me. It sounds like a deck mount is my only option.
10-19-2015, 05:06 PM
#32
2016 25' International
Wanamingo
Are you sure the new (2015 & 2016) trailers have 3 stage chargers? My 2008 only had the single stage MagnaTec (sp?). When I replaced it my batteries started lasting much longer.....haven't had any problems since.
