Old 10-25-2018, 05:20 AM   #1
Livonia , MI
Trim Panel Removal
I'm trying to remove the trim panel above the fridge on my 2013 30' International. I want to access the space above the fridge to route some wiring. All the other trim panels seem to have snap closures or screws. This panel will flex outward from the bottom when I pry it, but doesn't seem to come off. Any ideas on how to remove it?
mpabele is offline   Reply With Quote
Old 10-25-2018, 05:31 AM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
It will not come off without removing the fridge. It is one of those pieces that is attached with pocket screws from the inside.
Old 10-26-2018, 02:47 PM   #3
Livonia , MI
GMFL Thanks for the reply. I was afraid that was the case. Do you know what type of head the screws have? I can flex the panel out enough to access the screws and possible remove it without damage, but I cannot make out the type of screw. Thought I'd ask before I had to go out and buy 5 different screwdriver types, as I need a long shaft to access.
Old 10-26-2018, 02:52 PM   #4
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
They should be Phillips.
Old 10-26-2018, 04:06 PM   #5
Livonia , MI
Thank you. Will let you know how it turns out.
interior door trim removal kokomoscalls Doors & Locks 5 02-22-2014 02:52 PM
Tambour trim and trim Big C General Repair Forum 6 08-14-2012 08:01 PM
interior trim around door removal? Bill M. General Interior Topics 2 01-24-2011 08:25 AM
Belt Line Trim Removal Advice urban71 Ribs, Skins & Rivets 3 10-27-2010 04:21 PM
front end vinyl trim, misc trim mlmarch Clearcoat, Exterior Paint & Trim 4 07-07-2003 10:29 AM
