Old 10-18-2015, 03:14 AM   #1
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
Tracking down the 28W hot water bypass
Ok, this is getting a tad frustrating...
My 2011 International manual states that the 28W hot water bypass is behind a panel in the lower section of the hallway wardrobe; yet when when I remove that panel, I see 8-12 different pipe runs, but not a single pipe with any identifiable valve.
Yet the manual also shows a single switch on the rear of the hot water tank mechanism for the 30 -- this switch I can see in the cubby hole beneath the front L-Lounge.
Can anyone with a 2011-2015 International series 28W provide guidance/feedback as to where they've located their bypasses (photos would help!) I _really_ don't want to spend another $90 having a third party winterize when I ought be doing it myself.
Cheers thanks,
Ian
2011 Airstream International Serenity 28'
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 10-18-2015, 06:58 AM   #2
paiceman's Avatar
Upper St Clair, PA , PA-Summer/FL-Winter
We have a 30' and ours is under the dinette seat nearest the television. Thru a small hole in the plywood you should see a yellow valve, if so that is the one, turn it closed and you are done with HW bypass.
SAFE TRAVELS
Bud
Starting to Look (AGAIN) Number 5 Hopefully
USAF Training Instructor (TI) - 68-72
Old 10-18-2015, 07:48 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Ours is a single yellow-handled valve as well located on a water line just before and going into the water heater. Accessed through a small cabinet door inside the Airstream.
Doug and Cheryl
Goin' down, down, down... Aironius Axles 12 08-23-2014 09:09 AM
HELP! Water leak In 2005 Safari 28W Coming from behind shower? Shirley C Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 12-30-2012 07:51 PM
Tracking down previous owners of a trailer 68-Ovrlndr Title, VIN & Registration 2 10-19-2009 11:24 AM
Tracking down brake failure kwoolston Brakes & Brake Controllers 7 10-02-2009 09:58 PM
Tracking down a leak.....window?? Captmorg Windows & Screens 8 10-22-2004 12:13 PM
