Hookup should be sat dish to the sat input on the outside of the trailer. Inside there will be a coax cable labeled SAT, usually buried behind/unde the BluRay player. You can lift the player from its Velcro mount and slide it out to get to the cable. Also unplug the HDMI cable from the BluRay. Hook the SAT cable to the input on you receiver and plug in the HDMI cable. Make sure that if you have a TV antenna amp switch that it is turned off and no light is on.
To get the signal to show you use the the TV remote and change the input to BluRay/HDMI the same as if you use the BluRay player.
Sounds a bit confusing I'm sure.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
