11-20-2015, 01:24 PM
#21
Sag Harbor
, New York
Although here it may have indeed been a HOT "water heater" if left empty with the electric element on?
Or am I getting into hot water . . . ?
11-20-2015, 02:13 PM
#22
2015 25' FB International
Ha! Now that you mention it... not sure why I call it that. At a minimum I should be calling it a cold water heater.
11-20-2015, 03:04 PM
#23
Naples
PERFECT!!!
lewster
11-21-2015, 10:26 AM
#24
Master of Universe
2008 25' Safari FB SE
Grand Junction
I can deal with "hot water heater", a phrase from the Department of Redundancy Department, but "VIN number" drives me crazy.
But is there always fire where there's smoke?
Gene
Gene
11-21-2015, 12:21 PM
#25
2007 25' International CCD FB
Salisbury
, Maryland
consider this
You may have a problem with the shore/park power supply. Maybe a problem with the pedestal supply has cooked your heat pump. I bought a surge protector that has a diagnostic read out that always plugs into the campground pedestal first to make sure the power supply is up to standard, no mis-wired connections, open ground, etc. once I get the correct readings I plug my AS into the surge protector. I lock the protector to the pedestal with a chain since it cost $300 but it gives me great peace of mind. Also if there is a brief power failure while the heatpump or AC is on it will not allow power to the units for about 8 minutes, so that the compressor can reset.
11-21-2015, 01:56 PM
#26
Naples
HJ ,
You should read the thread before posting. The problem was stated to be in the water heater and had nothing to do with either the heat p pump or shore power supply.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
lewster
12-02-2015, 03:08 AM
#27
Ft Worth
The Airstream Dealer couldn't find anything wrong or replicate the issue that caused the smoker detectors to activate.
Best guess - once I detached the city water supply but left the hot water heater on (electricity) that caused the smell and odor.
Thanks for all the replies! Hopefully this will be my only Rookie mistake!!!
12-02-2015, 05:39 AM
#28
Sag Harbor
, New York
Good news, thanks for the follow-up!
12-02-2015, 04:28 PM
#29
Master of Universe
Grand Junction
I doubt the water heater would cause a problem if there was water in it. It is pretty hard to completely drain it.
Gene
Gene
12-02-2015, 05:45 PM
#30
begorragirl
2017 25' Flying Cloud
Denville
, New Jersey
My rookie mistake was hooking up the hose to the black tank clean out instead of the fresh water hookup. My my was that a learning curve!
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
12-25-2015, 03:05 PM
#31
2010 30' SO Classic
Mohawk
, Michigan
Heat Pump is part of the AC and does not require water, so will assume you mean electric hot water heater. Disconnecting water supply from the trailer should have no effect on the hot water heater, unless you are USING hot water, with it turned ON, after you remove the water supply. This would probably burn out its heating element.
04-03-2016, 09:06 PM
#32
Ft Worth
Update - Turns out it was the A/C and the Dealer replaced it with a new unit!!!
04-04-2016, 12:47 PM
#33
2022 Atlas
Homosassa
Great outcome. Happy travels.
04-04-2016, 01:11 PM
#34
Granbury
I bet your furness came on when the heat pump quit...if it had never been run it will do exactly what you described.
04-04-2016, 05:54 PM
#35
Sag Harbor
, New York
Thanks for the update!
Interesting to read the entire thread again and marvel over how the symptoms and diagnosis wandered a bit . . .
