Old 08-19-2017, 09:18 AM   #1
2019 30' Classic
hamilton , Ohio
Replacement matress
Where is the best place to get a replacement mattress queen?
vdurbin is offline   Reply With Quote
Old 08-19-2017, 11:30 PM   #2
We purchased a sleep number from camping world. We finished 4 week trip and it was so comfortable!
firemed509 is offline   Reply With Quote
Old 08-20-2017, 06:25 AM   #3
2019 30' Classic
hamilton , Ohio
Thank you.
Old 08-20-2017, 07:27 AM   #4
2015 30' FB FC Bunk
Ayer , Massachusetts
Had a custom mattress made from this place using our OEM mattress as a template:
https://themattressmaker.com
We went all out on quality and it is amazing. Heads and tails better then the original mattress.
Ted S. is offline   Reply With Quote
Old 08-20-2017, 09:25 AM   #5
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
I have considered a Sleep Number, but have been concerned about the weight and if you have to have shore power for it to work.
How does this work for you?
thanks,
Steamy1 is offline   Reply With Quote
Old 08-20-2017, 09:49 AM   #6
2007 27' Classic FB
Ridgefield , Washington
Images: 11
We got ours from Rocky Mountain Mattress.
John
Woosch is offline   Reply With Quote
Old 08-20-2017, 09:51 AM   #7
thanks,
Weight is not a issue it is lighter than the original. You do need power to inflate or deflate. Once you have your sleep number you really don't need to deflate unless you are travel from a low elevation to a high elevation. When we do that we deflate it to 50. It only take about 30 secs to inflate both sides. You can use your inverter or 110.
Old 08-20-2017, 03:23 PM   #8
2007 27' International CCD FB
San Diego , California
Order just about any foam/tempurpedic/latex/memory foam queen mattress online or amazon. As long as the dimensions are greater than the AS mattress. Then order an electric carving knife (~$15). Use your original mattress as a template to trace onto the new foam mattress. Trim as necessary. It will cut like the proverbial hot knife through butter.
I did this to replace my twins in my 27FB. Bought twin XL mattresses since the AS twins are longer than normal. Only had to trim the rounded corner. Then left the rest as normal. Mattresses are way more comfortable than the original.
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift - 6" Fan Controller
pteck is offline   Reply With Quote
A Method to Convert a Rectangular Matress to AS sgschwend Cabinets, Counter Tops & Furnishings 5 11-25-2016 05:05 PM
Axle replacement / Floor Replacement - Newbies! toesonoz Vintage Kin 12 07-02-2016 05:05 PM
UN-comfortable bed!! (Custom Rounded Matress) 99 bambi Our Community 3 04-15-2002 11:28 PM
