Old 09-23-2019, 09:09 AM   #1
2014 27' FB International
spring , Texas
Replace refridgerator
I have a 2014 27FB Serenity. I am interested in replacing the fridge with a Norcold 10 cf. Has anyone replaced thier fridg with a larger one. Will it fit?
lrrathwell is offline   Reply With Quote
Old 09-23-2019, 01:21 PM   #2
1986 31' Sovereign
Miami , Florida
Unlikely. Probably taller than the 8 cu ft. The Norcold website should have the exterior dimensions of the unit you are looking at.
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 09-23-2019, 02:13 PM   #3
dvgofaz's Avatar
2005 34' Classic
tucson , Arizona
I just replaced the cooling unit on a Dometic 3682, in order to do it I had to pull the fridge completely out of its hole.
I noticed that the width of the opening in the cabinet isn't adjustable, but there are several inches of extra height available if you want to cut the cabinet face opening an inch or 2 taller. That said you will have to be conscious on how deeply set your new fridge will be so the extra height of the back edge doesn't run into the curve of the ceiling back there.
dvgofaz is offline   Reply With Quote
« Lounge sheets | Top | - »
1977 Dometic refridgerator overlander Refrigerators 30 03-14-2015 12:08 PM
Need a New Refridgerator Vent Cover John and Anne Airstream Motorhome Forums 3 07-11-2004 07:41 AM
Refridgerator was working Just Fine,...til I started messing with it MileHigh Refrigerators 2 06-12-2004 12:56 PM
1969 Sovereign Refridgerator Door jyobp Refrigerators 1 01-25-2004 05:40 PM
Refridgerator Removal DRLee Refrigerators 17 10-10-2002 12:38 PM
