08-08-2015, 09:50 AM
2015 25' FB International
Removing AC Duct Filters (Ducted AC model)
Is there a wrong way to take out the ceiling ducts for the AC system? i'm very hesitant to go pulling too hard on them; it seems they are held in place by double-sided tape and two clamps. Do you just yank them out or is there something more to do? And is that really the only filter on this system?
08-09-2015, 10:12 PM
2012 28' International
Olympia
The new issue of Blue Beret has instructions for cleaning the filters in the new ducted AC models.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
08-09-2015, 10:24 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
I assume that you are talking about the air returns for the ducted system. I have taken mine off several times to clean the foam filters.
I remove them by grabbing the end and pulling down.
Here is a picture of what they look like when removed.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
08-10-2015, 04:50 AM
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach
I too just pull down from the ends to remove. I have to pull down pretty hard to release the clips. There is no double sided tape on mine. Joe
08-11-2015, 05:33 PM
Thanks guys. Yes, that's the one. Didn't know there were foam filters in there. We spent 7 weeks in ours and I'm SHOCKED by how much dust is built up on them. We didn't even use the AC that often. There's got to be a better filter out there than foam though...? Has anyone found a replacement?
10-11-2015, 09:34 AM
Okay, I finally got around to pulling mine out. Now what...? How do you go about cleaning that sorry excuse for a "filter"!? I'm surprised to see all that wiring in the AC duct too. I don't see any way to do a better filter modification.
10-12-2015, 09:05 PM
Dave, just noticed your reply. Sorry! I'm not a WBCCI member or subscriber to the magazine. Would you mind sharing how they clean the filter?
02-18-2016, 05:23 PM
I have the same ceiling returns. I just pulled mine down and wiped clean with a paper towel. For the sponge filter I took it outside and slapped a cloth (bandana) to both sides. Cleaned up in a few seconds.
02-18-2016, 06:18 PM
I ended up vacuuming my vents and yes, slapping out the foam thing. Definitely in the market for some sort of better filtration there.
02-18-2016, 07:16 PM
1994 30' Excella
Mississauga
, Ontario
don't forget that you want to maintain an adequate air flow. Therefore the filter medium cannot be too restrictive.
Al
Al and Jean
TAC ON-3
02-18-2016, 08:51 PM
Yeah... plus I'd have to find something that small. Does anyone know if there is another filter up in the outside unit as well?
10-07-2018, 07:19 AM
Reads a lot
Titusville
Does anyone know where to buy replacement filters or part numbers? I purchased some while at JC last March but haven’t located them online anywhere. Thanks.
Lauri
She Believed She Could so She Did.
08-21-2021, 05:02 PM
2016 25' Flying Cloud
Albuquerque
, New Mexico
I've followed the instructions in this thread and still can't get the air returns off. I even used a small right angle pointed tool and got completely between the return and the ceiling skin. This tool has a handle and I can pull pretty hard, to the point that I see the skin moving also and it still doesn't budge. Are they really that hard to remove? The picture in the thread just shows a clip. I'm afraid to pull on it much harder. Any secrets?
'17 Ford F-150 Ecoboost, max tow package
'13 GMC Yukon Denali 6.2L V8
'04 GMC Yukon SLT 5.3L V8
08-28-2021, 08:52 AM
Albuquerque
, New Mexico
Just an update from my previous post. Having gotten no response on how to best remove a very tight air return duct, I decided to try a different approach. I took a small hoe, the kind you use for small jobs with a short handle of about one foot. I cleaned the head, made sure it was straight and put blue painters tape on it. With my fingers, I was able to slide the head of the hoe in between the interior skin and the duct. Then I put a hot pad between the elbow part of the hoe and the skin. I even put my fingers between the hot pad and the ceiling skin just to feel how much pressure I was exerting on the ceiling as I didn't want to dimple it. It took some doing, but finally both ducts popped off and I was able to wash the filters. It was the leverage and the width of the hoe head that made the difference. I can't believe it was so hard, but maybe the template used to cut the pattern was just a bit smaller than most.
08-28-2021, 10:46 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
The "ears" on the frames that hold the covers in place can be bent a bit. Bend them one way and they hold really tight. Bend them the other way and they are pretty loose.
Loose is good when you are pulling them off for cleaning. It's not so good when you want them to stay in on bumpy roads. Various folks (and I'd bet dealer techs) adjust them various ways as a result. I'd bet a pervious owner was pissed about them falling out .....
08-28-2021, 11:03 AM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Hi
... bet a pervious owner was pissed about them falling out .....
SNICKER! Sometimes I think the former owner of my rig was definitely "pervious" Oh, the things I have found[emoji2957]
08-28-2021, 12:14 PM
2021 30' Flying Cloud
2020 25' International
minneapolis
Once in while we get cone shaped dust collecting on the ceiling from the vents. The so called filters on the ceiling are not going to do much for filtration. While watching a video on the 2022 models, I noticed the new filtration system on the ceiling. Are we able to purchase the filter system and install it on an earlier model? Would it be worth doing?
- Stewart
08-29-2021, 08:15 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Amazing what spell check can do for you
08-29-2021, 08:19 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Given how fast the existing filters plug up, they must be doing something
If you go to a better filter (that catches more stuff), I'd bet it will plug up faster. There's only so much space there, even with some sort of pleated gizmo.
The only way to find out about a retrofit of the "new" filter would be to give JC a call.
08-29-2021, 09:57 AM
Albuquerque
, New Mexico
Uncle Bob.....being the original owner, the tightness of the "ears" came from the factory. Having read about ducts falling from the ceiling, perhaps the factory was trying to compensate. We've never had any problems with the ducts. This is a '16 model year and I think '15 was the first year of ducted air, so perhaps they were still trying to come up with the right formula for the flanges.
