10-09-2014, 11:02 PM
2011 27 FB International
Austin
Propane Tank Gauges
I own a 2011 27FB International Signature Series with dual propane tanks with a switch over valve. My question is how do I know when the tanks are going empty? There's no gauges and I'm told that gauges aren't accurate. Would love to not just run out...how do I regulate this?
10-09-2014, 11:15 PM
2014 30' FB FC Bunk
Hoover
, Alabama
I just before every trip make sure one is not empty and when it is I refill it
If I remember which tank had the switch toward it then I can see once it switches after a trip or before the next - then refill
Rate of propane use for most is quite low unless using a lot of furnace or propane for a generator I would think
I would though like to have something that could tell me how full they are but this seems to work ok
10-09-2014, 11:55 PM
1974 Argosy 20
Kooskia
, Idaho
Did you realize that you have an automatic switch over regulator on your Airstream?
On the regulator you will see a pointer on a round dial. That pointer points to the tank which is supplying propane. When that tank becomes empty, there is a green indicator which turns red and the propane is drawn from the other tank which is left on. You then turn the knob to point at the good tank and the indicator will turn green again. You can remove the empty tank and have it refiled without turning the gas off. When refilled, put it back in place and turn it on. Then when the second tank becomes empty, it will switch back to the first one, and on and on.
This can be a little confusing at first, but it works very well assuming you look now and then at the indicator to see if it is red and you are running on your second tank.
10-09-2014, 11:57 PM
2014 30' FB FC Bunk
Hoover
, Alabama
I never noticed the change in color - duhhh - thanks!!!
10-10-2014, 12:16 AM
2007 22' International CCD
Corona
Tanks with built-in mechanical level gauge...
My issue with the factory auto-switch regulator is that it only tells you the selected tank is empty.
I have seen 25-pound steel propane tanks made by Worthington at either Sam's Club or Costco that have a built-in mechanical level gauge just under the valve body. These use a float to give the level. The in-line pressure gauge type, IMHO is useless .
Transparent (ish) fibreglass tanks also exist--I'm not convinced of their safety yet...but you can see the propane level directly, and they are supposedly lighter.
My airstream has the auto switch regulator as well, but a real level gauge with a float gives a better indication of when you may run out of gas--I've missed the green-to-red color change in the dark and cold...which got me in trouble with the family in the winter--our A/C has a heat strip and can keep us warm, at the price of way too much fan noise...
Since we also have a tankless water heater, high-enough gas pressure and flow in cold conditions is also critical...suddenly cold showers in the winter are not appreciated by wives (don't ask how I know this...)
And, if all else fails, carry spare full tanks properly secured in the TV.
10-10-2014, 08:30 AM
one of those
'03 F250 PSD
, Airstream summers, Catalac winters
These stupid red green color conventions are useless for the 10% or so of us who really don't see the difference. BUT as for being able to quickly tell how much propane is in each tank, I can help.
Put a pyrex measureing cup or coffee cup about 3/4 full of water in the microwave, if you're in the "marina" and bring it to a boil. Or a pot on the stove, if you still have the propane.
You just need hot water. Doesn't have to be boiling.
Pour the hotwater over your tanks. You'll quickly and easily see the condensation line where the liquid propane level is. It's not precise mesurement of how much gas you have left, but it will give you a real good idea which tank is low. And you don't have to dismantle anything to do it.
10-10-2014, 09:29 AM
Holly Lake Ranch
I will refill the tank that has the service pointer pointing to it this afternoon, that way I know I will have two full tanks when we head out tomorrow. So it's important to have the service valve pointing to one or the other, not in the middle because then ( I guess) you would be pulling equally from both tanks all the time....
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
10-10-2014, 10:09 AM
1974 Argosy 20
Kooskia
, Idaho
Yes, point it at one or the other. The one it is pointing to is the one it will be drawing from until it is empty, then the indicator changes from green to red. Then you flip the pointer to the other tank, remove the empty one, and have it refilled. You do not have to turn off all gas when having it refilled that way, and can have continuous service.
10-10-2014, 10:36 AM
Holly Lake Ranch
I threw the (I guess) qualifier in there because while I believe that I learned that pointer info on the Forums, I didn't want to put that out there as the gospel if it wasn't correct... so thanks idroba for verifying.
Dana and Olga
2006 Safari 23
10-10-2014, 11:22 AM
2008 25' Classic
Full Time
I guess I'm lucky with my 2008 Classic 25fb I have the sight gauges with connectors to the monitor panel. On my previous trailer, 2009 Casita, I just waited until the propane switchover valve showed red but make sure the other tank valve is open so when it switches to that tank it can draw propane. I made the mistake of not turning it on one trip and in the middle of the night I was awakened by clicking. It was the refrigerator trying to relight. I had to get up and go outside on turn the valve on to the 2nd tank. Lucky it happened then because my daughter and I were to leave the next day for a 2 day backpacking trip leaving the wife and dog and she wouldn't have been able to figure it out.
Kelvin
10-10-2014, 12:00 PM
Oswego
yeah, the classics have gauges from the Department of Redundancy Department. 1)switch over indicator on the regulator 2) mechanical gauges on the tanks 3) wire from gauge to monitor panel inside.
-Rich-
10-10-2014, 12:03 PM
1981 31' Excella II
New Market
, Alabama
Old tanks had a float gage that worked well. New tanks don't have that because of the OPD valve. You can get dual bung tanks that have the valve in one hole and the gage in another. This is the best way although it is not cheap.
Perry
10-10-2014, 12:12 PM
Oswego
Perry
That's what mine is....dual bung. Had to have the LP service guy pull one of mine. It was sticking. Just turned it a bit in the bung and it no longer had interference.
-Rich-
10-10-2014, 12:36 PM
2004 28' Classic
Fresno
I just use one tank at a time until empty, then open the valve on the full tank and refill the other. This works for me, in the past I have tried using hot water to judge the fuel level in the tank but I find one tank at at time is easy for me.
Doug & Lori
Fresno
2004 28' Classic
2007 Ram 2500
11-02-2014, 05:47 PM
Corona
OPD tanks with float gauge exist
Sam's club had them for sale in the BBQ aisle this summer...$39 as I remember. They may have a few leftovers on sale...made by Worthington or Manchester I think.
I'll report when I see how well they work and if they survive bumping along on the front A-frame...
They appear to use an internal magnet to connect to a loosely-fitted indicator clipped onto the base of the valve. No dual port in evidence--float appears to be part of valve.
11-03-2014, 02:11 PM
2012 23' International
North Everett
Hey everyone. Looking for some info pertaining to the effiiciency of LP when running the furnace and the fridge.
We plan on continuing to use our trailer through the early winter and early spring here in the NW.
I realize that outside ambient temps will make this difficult to estimate but how long can the furnace run on LP and how much does the frige use?
J. Tyler Tuck
11-03-2014, 06:31 PM
1995 30' Excella
Bowie
, Maryland
The fridge doesn't use much. The furnace will suck it down. When we camp in temperatures around freezing at night, we use a 30 lb tank every 2-3 days. Obviously there are a lot of factors going into this, like the daytime temperatures. If you're going to be there a while, look into getting propane delivered in a 100lb tank.
You'll need a way to recharge your batteries, probably daily. I mention this because you said you wanted to use the fridge on propane, making me think shore power isn't available.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
11-03-2014, 07:49 PM
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
I have the pointer/green,red changeover valves on both trailers. When one goes red I change the pointer to the tank that has become the supply, fill and turn on the tank that was empty, and go on enjoying life. In 14 years, have never had to switch tanks in the rain or when half way through cooking breakfast. What could be easier?
11-04-2014, 08:29 AM
1981 31' Excella II
New Market
, Alabama
You can figure out how long it will run on a tank. Find the total number of btu's per lb of propane and multiply by 30 if you have a 30 lb tank. Now divide by 30,000 and that should give you the total run time in hrs when the furnace is running.
Perry
01-03-2015, 11:47 AM
North Everett
So just wanted to update following our New Years outing.
This is by no means the scientific approach many look for but more of a "how long will my propane last? Few days few hours?"
We spent 3 nights on the Oregon coast over New Years in lows down to high 20's and highs to very low 40's. I had 2 full 30lb propane tanks and we used 42 lbs of propane while cooking 2 meals a day and running the furnace 8-10 hours a night and the heat pump in the day as needed.
Overall I was pretty impressed at the efficiency of the furnace. It didn't run constantly and really kept us pretty warm at night.
J. Tyler Tuck
