Old 09-23-2018, 09:15 AM   #1
2015 25' FB International
Central , Illinois
New SRM batteries do not appear to be charging
Hi there. Very new here. Been using my camper at a seasonal site and am getting ready to move out in a month.
I had two new batteries installed and the SeeLevel ll still reads 13.6
The camper is still on shore power so I thought they should be charging.
Does something need to be reset since the old batteries were probably dead?
Thanks so much.
CanoninD is offline   Reply With Quote
Old 09-23-2018, 09:22 AM   #2
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
If you are on shore power the 13.6 you are seeing is the voltage coming from your converter/charger, not your actual battery voltage. And it is probably charging your batteries.
If you want to know your batteries state, you'll need a multimeter, and you'll need to disconect from shore power for a few hours to let the batteries stabilize. Then measure the voltage at the battery posts.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
Caffeinated is offline   Reply With Quote
Old 09-23-2018, 09:28 AM   #3
Central , Illinois
Thank you so much!
Old 09-23-2018, 11:19 AM   #4
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
As mentioned, the 13.6V reading is what's coming off the charger. If you unplug from shore power, you should see that drop to 12.7 or so. And as advised, let batteries 'rest' a couple hours to get a true reading.
However...make sure your battery use/store switch is in "USE" position. If in 'store', they will not be charging.
pcskier is offline   Reply With Quote
USB Charging Ports not charging WkendWarrior Electrical - Systems, Generators, Batteries & Solar 29 09-08-2018 08:12 PM
Cold weather suitability of Interstate SRM-24 randmscooter Full-Timing, Winter Living & Workamping 8 11-04-2017 12:09 PM
Batteries: 2013 Internation 19, Interstate SRM-24 both dead Tao Electrical - Systems, Generators, Batteries & Solar 29 03-09-2017 05:58 PM
Profile Picture Loaded But Does Not Appear man7sell Forum Admin, News and Member Account Info 2 12-18-2008 09:50 AM
After polishing, leaks appear ... brunoffrance Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 02-27-2005 10:47 AM
