Old 06-02-2013, 06:10 PM   #15
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Originally Posted by J5MM View Post
Has anyone with a 2012 International Signature experienced their stove exhaust fan and light failing? I'll be cooking and running the fan for about 20 minutes and all of a sudden, everything shuts down. I then am told I need to replace the fuse. I'm going on my third fuse...
I've never had to do this on my 2006 Safari (ran the fan upwards of 4 hours while roasting a turkey) and cooking for well over two years.
Thanks in advance for any input.
I had the same issue, replaced the fuse and it happened again about 6 months later. So I put a little bit of tin foil on one end of a new fuse just to lengthen the fuse a tad and it seems to be working just fine. I think the poor contact was messing up the continuity of the circuit. Hope the electricians out there don't freak out too much. If I am going to blow the thing up, please let me know.
Jim Flower is offline   Reply With Quote
Old 06-03-2013, 12:15 AM   #16
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Since I haven't seen the fuse holder, usually there is a spring at one end.. a slight 'tug' on the spring if done carefully could stretch it a bit, thereby gaining "contact force"... similar to shimming out the fuse as you did, with a reduced likelyhood of shorting something out..
If dealer won't fix it in Texas, go Lemon Law?.. or "field engineer" the sucker with a better, US made fuse.. the electrons will only be confused for a little while..
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-04-2013, 06:02 PM   #17
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
It was a "duh" moment for me. Happens too often. Of course that is the fix. I saved the bit of tin foil for some other foolish fix. Now works as good as, well, new.
Old 06-06-2013, 05:34 AM   #18
DMT
DMT's Avatar
2011 27 FB International
East Coast , Newfoundland
There are two other current threads on this same issue. If Airstream is suggesting to increase the fuse to 5A, why are the still issuing new trailers with the old fuse? Almost everyone with the Baraldi range hood is having this problem.
I'm going to call them today and ask for new fuses. At the moment we have been managing by not running the light and the fan at the same time.
[AIR# 55762 TAC# NFL-1
DMT is offline   Reply With Quote
Old 10-12-2013, 04:13 PM   #19
2013 25' Flying Cloud
sussex , New Jersey
anybody have a part number for the 5 amp fuses?
bmark is offline   Reply With Quote
Old 01-25-2014, 09:32 PM   #20
The Cralls
thecralls's Avatar
2012 28' International
Bremerton , Washington
You can get a 5 amp fuse at radio shack. I had the same problem in my 28' International.
thecralls is offline   Reply With Quote
Old 01-26-2014, 08:40 AM   #21
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Auto Parts stores have fuses. Wal-Mart does too. The new style fuses are color coded.
TG Twinkie is online now   Reply With Quote
Old 01-26-2014, 08:46 AM   #22
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I don't have the part number, but it's a small thin old-fashioned glass tube fuse. Bring the old one to Radio Shack and you can get the 5 (not 3) from them. My dealer said AS knows its a mistake but hasn't communicated anything about it.
Old 03-03-2014, 10:14 PM   #23
streamer_a's Avatar
2017 23' International
Waukee , Iowa
Anyone experienced difficulty with the bulbs in this range hood failing frequently?
I have replaced the 3.15A fuse with a 5A - since then the fuse hasn't tripped. But the bulbs burn out monthly.
streamer_a is offline   Reply With Quote
Old 03-04-2014, 07:37 PM   #24
The Cralls
thecralls's Avatar
I took a look at the ratings for the vent hood on the manufactures label sticker. The 3.15A fuse is exactly at the load for the fan and lights. The hood is rated for a much higher power draw, and the 5 amp fuse is below the max rating of the hood and will provide the current required to run the fan and lights without blowing.
Old 03-05-2014, 05:41 PM   #25
BAB
BAB's Avatar
2015 30' Classic
Greensboro , North Carolina
....I am also considering removing the two very hot (and power hungry) halogen bulb pods from the Baraldi range hood and replace them with something else...like maybe MODERN LEDs. I (like many of you) have blown the fuse -- which I was able to replace -- and now have a spare. This is not a high quality piece of equipment, I might add. I heard an awful noise the last time I used the fan, and found that the fan had come off the motor shaft. The motor was running and the fan was hanging around loose. Diasassembly, repair and reassembly. My guess is that the folks that assembled it must have had a Chianti break or something....
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 03-05-2014, 06:26 PM   #26
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Strangely, I just answered a PM about this. If you replace the halogen with the LED replacement, it will last much, much longer, be cooler to work under, use less power when boondocking, and not blow fuses at the drop of a hat.
Old 03-07-2014, 06:48 AM   #27
richinny's Avatar
2011 34' Classic
if you touch the glass part of a halogen bulb the oil from your skin will cause the bulb to burn out fairly quickly. i wonder if steam/oil from cooking would do the same thing?.
Ricky
Old 03-09-2014, 11:11 AM   #28
streamer_a's Avatar
Waukee , Iowa
Yes, the steam/grease theory makes complete sense. I am searching for LED replacements.
2012 international
Replacement Fan Motor for Roof Exhaust Fan SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 20 01-08-2014 05:00 PM
My Search Function is Failing Jamespio Fresh Water Systems 1 10-08-2013 05:53 PM
AC Thermostat failing? VeggieBullet Electrical - Systems, Generators, Batteries & Solar 6 11-27-2011 09:45 AM
AC Failing???? VeggieBullet Furnaces, Heaters, Fireplaces & Air Conditioning 11 11-21-2011 09:39 PM
Steering Gear Leaking/Failing? swebster Mechanics Corner - Engines, Transmission & More... 6 03-19-2006 05:23 AM
